Question about Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM Combo Drive
I am unable to find my CD icon on my PC. It was fine till today morning. Now under Device Manager, it is showing a yellow exclamation, Can u help
    Guru:
  • 109 Answers
Windows Vista loadTOCNode(2, 'resolution');
  1. Click Start , and then click All Programs.
  2. Click Accessories, and then click Run.
  3. Type regedit, and then click OK. If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
  4. In the navigation pane, locate and then click the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
  5. In the right pane, click UpperFilters.
    Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 8.
  6. On the Edit menu, click Delete.
  7. When you are prompted to confirm the deletion, click Yes.
  8. In the right pane, click LowerFilters.
    Note If you do not see the LowerFilters registry entry, unfortunately this content cannot help you any further. Go to the "Next Steps" section for information about how you can find more solutions or more help on the Microsoft Web site.
  9. On the Edit menu, click Delete.
  10. When you are prompted to confirm the deletion, click Yes.
  11. Exit Registry Editor.
  12. Restart the computer.
Windows XP loadTOCNode(2, 'resolution');
  1. Click Start, and then click Run.
  2. In the Open box, type regedit, and then click OK.
  3. In the navigation pane, locate and then click the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
  4. In the right pane, click UpperFilters.
    Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 7.
  5. On the Edit menu, click Delete.
  6. When you are prompted to confirm the deletion, click Yes.
  7. In the right pane, click LowerFilters.
  8. On the Edit menu, click Delete.
  9. When you are prompted to confirm the deletion, click Yes.
  10. Exit Registry Editor.
  11. Restart the computer.
Posted on May 05, 2010
Compaq presario v2000 wireless card not showing up in device manager
In Device Manager click the tiny arrow beside Network Adapters. This where the wireless card should be listed.
Next, locate the row of small icons just below the View tab at the top of Device Manager window.. Click the icon on the right "Scan for Hardware Changes".
Check again under Network Adapters to see if the wireless card is listed.
Or, check for any yellow exclamation marks in Device Manager list. An item might be named Unknown Device. Double-click it and select Update Driver.
Jul 01, 2014 | Compaq Presario 700 470024-192 Notebook
Not detected wireless
I will do my best to help you with this concern.
1. go to Device Manager and check all drivers if nothing is missing...if yellow exclamation point.. found-update specified driver
2. In device manager under network adapter is where you check the driver if there's no icon on it like exclamation point..
3. if all drivers are updated-tried to connect to the network.
4. if this is a laptop. make sure the radio button/ wireless switch is on.. in connecting the network.
5. if this is a desktop, make sure the wireless adapter is working fine.
6. if still unable to connect try to contact your service provider and make sure you have the right WEP/ network key to connect to your network.
I hope this will help you.
May 30, 2011 | Microsoft Windows Vista Home Premium...
Windows reports that the mscank device is not working properly. How to solve this problem plz. help me in detailed. thanks in advance.
click Start button-Control Panel,System and Security,under System, click Device Manager. Now check if any device has any yellow exclamation mark on it.Once you find any device with any mark, right click on that device click on Uninstalloption,rstart the computer and check if it works.If you are unable to find any device with any marks then check by enabling hidden devices.In the device manager click on View and later click on show hidden devices and check if you find any device with exclamation mark and uninstall it.
Dec 04, 2010 | Computers & Internet
HL-DT-ST DVDRAM GSA-T40L ATA DEVICE has run problem error code 39
1. Using Device Manager
To fix this error, first try to update the driver from the Device Manager. To open Device Manager, right-click My Computer on your Desktop, and then on the Hardware tab, select the Device Manager button.
In the Device Manager window, identify the CD or DVD drive item (with Yellow exclamation mark), right-click on it and select Update Driver. Follow the screen instructions to update the device driver and restart your PC.
if can't try this:
2.To fix the error by editing the registry, perform the following
steps:
1. Exit and close all applications currently running on your PC.
2. On Start > Run type Regedit and press the Enter key.
3. Next, navigate to the following registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\ Control\Class\ {4D36E965-E325-11CE-BFC1-08002BE10318}
4. Delete any of the following registry entries if they exist under this key:
* LowerFilters
* LowerFilters.bak
* UpperFilters
* UpperFilters.bak
5. Restart your PC and open My Computer to ensure that the CD-ROM drive is visible.
6. Also, open the Device Manager again to ensure that the yellow exclamation mark and the error code is now gone.
7. Restart your PC and open My Computer to ensure that the CD-ROM drive is visible.
8. Also, open the Device Manager again to ensure that the yellow exclamation mark and the error code is now gone
Jan 02, 2009 | Computers & Internet
Network adapter
have you made any software/hardware changes off late?do look in the device manager..right click on the my computer icon on the desktop..go to properties..on the top left under taks u will see device manager and look for network adapters..anything with and yellow exclamation means its missing/corrupt..hope it helps..
Oct 30, 2008 | HP Pavilion Notebook
Dvd rw
Please go through the below provide steps.
Fixing Code 39 Error
If your CD-ROM drive is not visible in My Computer, you may see the following error message displayed with the CD or DVD drive item in your Device Manager. (Steps to open Device Manager are discussed later in the article.)
"Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)"
Using Registry Editor
If updating the driver does not resolve the problem, it indicates that there is a problem in the registry. To fix this problem, you may have to remove a few keys from the registry.
Note: Be careful while working with the registry editor because changes done to the registry using the Registry Editor are irreversible and mistakes can leave you with more problems than when you started. Therefore, it is recommended that you make a backup of the registry before proceeding with the changes.
After you have removed the registry keys listed below, you will have to reinstall all applications that you use for CD or DVD recording to make them work properly.
To fix the error by editing the registry, perform the following steps:
    • LowerFilters
    • LowerFilters.bak
    • UpperFilters
    • UpperFilters.bak
  8. Also, open the Device Manager again to ensure that the yellow exclamation mark and the error code is now gone.
Thank you........
Sep 18, 2008 | Computers & Internet
Packard bell CD rom
Cheak cd rom data cable pluge in maight be cable is unpluged and verify the port connection also
Jul 01, 2008 | Packard Bell GCD-R580B (gcdr580b) Internal...
Laptop s infrared device, serial cable using IrDA Protocol problem
Sound has nothing to do with infrared devices.
The yellow exclamation mark that you see under the device manager is due to drivers of the infrared device not found or is not installed properly.
There might also be a possibility that the device is not getting recognized by the computer due to corrupted drivers so the drivers of the particular needs to be installed again with the CD.
Jun 04, 2008 | Gateway Solo 5300 Notebook
Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM Combo Drive Logo
81 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
