Lexmark x5490 paper jam
How can i retrieve jammed paper in my lexmark x5490 please?
MORNING EVERYONE!!!
well at last managed to retrieve the paper jam. I had to remove the paper feeder then using long thin tweezers, i was able to carefully encourage the paper to come out but you have to be really careful not to damage the rollers.
Can't understand why there isn't an easier way. ie have easy access to the back or lift something up to get into the feeder!!!! anyway thanks for the support and suggestions, will gladly reccommend you guys to friends and collegues!!
Jacquie
xx
Posted on Mar 27, 2008
It wont feed the paper it keeps say paper jam but the paper is not even going in
Lexmark Impact S301 Printer won't take the paper -
printersquestions.com/lexmark-impact-s301-printer-wont-take-the-paper....
Dec 19, 2013 - Feeding paper is the first step of printing materials. However, what will you do when the Lexmark Impact S301 Printer won't take the paper ...
Paper Jam Troubleshooting on 2009 Printers - Lexmark
support.lexmark.com/index?pmv=print&page...en...
LexmarkLexmark Impact S301, Lexmark Impact S302, Lexmark Impact S305 ... When troubleshooting paper jams on Lemark's 2009 printer models, make sure you also ...
[PDF]Solving paper feed problems - Lexmark
www.lexmark.com/publications/pdfs/w820/eng/prfedprb.pdf
LexmarkUse the following table to find solutions to paper feed problems you are ... For detailed instructions on clearing paper jams, see Clearing print media jams.Missing: impact ‎s301
How To: Clear a Paper Jam on a Top Feeding Lexmark ...
? 2:30
https://www.youtube.com/watch?v=H1-J1xDbDsY
Jan 14, 2016 | Lexmark Impact S301 Wireless All-in-one...
Lexmark X4550 all-in-one Paper feeds only half way then jams
Frances;
I'm not Lexmark certified; however, paper motion fails are generic in nature. Paper motion fail can be a bit difficult to diagnose at a distance...
* If it jams at every sheet then check to insure there is not a bit-o-paper stuck from a previous jam.
* If it has been an issue that has been increasingly getting worse than I'd replace the pick-up roller(s)
* Lexmark's support page for your printer is below. (You can also find a service prover too)
* Parts order for your printer is also below. You can determine at the support page if your comfortable replacing pick-up rollers in that model printer.
support lexmark com Service Parts
Note:
* Frequently people tear a jammed sheet when it comes out leaving pieces behind. BAD! When you get a torn sheet in your printer insure you retrieve all the pieces. Those left behind guarantee a jam on your next try.
* Paper jams not caused by debris in the path or worn pick-up roller(s) is beyond user maintenance.
Mar 03, 2015 | Lexmark X4550 Wireless All-in-One Photo...
I've got a 4 by 6 photo paper jam in my Lexmark S405 all-in-one printer.
Please follow the steps below to fix the problem:
1. Remove the sheets of paper from the feeder.
2. Try to reach for the paper jam.
3. If paper jam can't be reached, open the printer cover to access the cartridge area. You may be able to get a better hold of the paper jam in the cartridge area.
4. Remove the paper jam and make sure not to tear or leave any torn piece of paper in the printer.
When paper jam is clear, try to print a document again to verify that the problem is fixed.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 01, 2011 | Lexmark All-in-One Printer with PictBridge
201.02 paper jam
Please open up the printer take the toner out, please there is a paper jammed in this location, Bring paper out put toner back and power on the printer
Apr 17, 2010 | Lexmark X342n All-In-One Laser Printer
Lexmark E 342 n paper jam with error code 201
According to the LexMark support page, this is most often related to not getting the print cartridge assembly properly positioned. (Left and right sides not fully in place). Another possible source is paper in the output tray when using the double sided printing feature. (This leads to grabbing an extra sheet when it tries to retrieve the paper to print the second side. Paper stock thickness will change the number of pages printed before this happens.).
I hope this helps.
Sep 03, 2009 | Lexmark E342n Laser Printer
Code 200 Paper Jam Error
Hi Mike,
This error can be caused by many reasons, some of them are:
Caused by Paper Stuck Under the Second Transfer Roll
Sporadic or Intermittent 200 Paper Jams
"200 Paper Jam" Resulting from a Possibly Damaged Tray
"200 paper jam" When Attempting to Print from Tray 2
To troubleshoot this problem, please click the links with their respective causes.
Please rate it fixya if it was helpful.
Thank you
Dec 19, 2008 | Lexmark C750 Laser Printer
202 pam jam
usually it means that a sensor in your fuser is bad. If you have a P.M. Kit replaced the fuser and clean the printer.
but before you do, make sure that you have cleared all jams, including in the fuser.
Its probably time for a Preventive Maintanence
Jun 13, 2008 | Lexmark T630 Laser Printer
Lexmark x5490
http://www.lexmark.com/publications/pdfs/2007/5400/en.html
Fallow this link, you'll get the user guide....It might help you!
It's depend on where your paper is stuck???
Mar 26, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark x4270 paper jam
Have you looked inside the roller assembly. More often then not a small piece of paper will get stuck deep inside the roller assembly. This will lead to paper jam errors. Inspect more closely. You will probably find some tiny tidbit somewhere.
Dec 20, 2007 | Lexmark X4270 All-In-One InkJet Printer
Computers & Internet Logo
75 people viewed this question
David Payne
David Payne
