Question about Goldstar MV-1501 Microwave Oven
Light stays on & turntable spins when not in use
  • Goldstar Master
  • 9,047 Answers
If it's actually cooking when it shouldn't, it'll need to have the control circuit board repaired. Details on that are here.
If just the fan / turntable / light (or some combination of those) are on, but it's not cooking, then its probably a bad door switch or mount and this file will help you.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Posted on May 04, 2010
Why does the turntable spin when the door is closed ?
this is normal thats the way they heat from in to out
now if you open the door the light is on
if it does not just change the bulb 10w 120 vac e14
Sep 16, 2015 | Microwave Ovens
My microwave heats & shuts off with timer But it comes back on when I open the door (not heat) just turntable spins in opposite direction, and fan & light come on.
OOHH this could be dangerous to use, seems your door interlock switch is not operating , Id unplug it right away and refer it to a qualified service center
microwaves on live flesh (such as your hand) could explode !!!!!!!
Feb 20, 2015 | In Microwave Ovens
I have a Russell Hobbs RHM2018 microwave oven with grill and the turntable will not stop going round and the light stays on until I unplug it? Once plugged back in it carries on in the same way? If I
The switch for the turntable does not disengage anymore. Could be a relais, could be an electronic switch. When opening the door, a second switch, in series with the other one, connected to the turntable motor disengages, stopping the motor. The light is switched on, because you opened the microwave. Perhaps you never noticed this, but it is the normal way that should work.
Aug 31, 2014 | Microwave Ovens
Turntable does not spin, no heat
HV fuse has failed. Possibly caused by door switches or Diode Pack failure. Do not attempt a repair unless you are competent to do so. Extremely hazardous voltages inside!
Feb 27, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
Turntable and light operating on its own.
It will be the door switches. The control board cannot control the motor and light on their own.
Jun 03, 2017 | Whirlpool Microwave Ovens
When I shut the door, the light stays on and the turntable keeps spinning, even though the microwave isn't on.
Issue with safety swich Door, and Relay Control on the main board ....Refer to Professional Microwave Repair ...Do not attemp to fix CAUTION HAZARD VOLTAGE INSIDE...
Sep 30, 2010 | Hotpoint RVM1435 Microwave Oven
Light and fan stay on and turntable no longer work
Not sure if your model has a belt driven turntable or gear driven. The cause of your problem is most likely a worn or loose drive gear or a drive belt which is worn or has come off.
Best have this checked at your local repair shop.
Best wishes,
Graemevm
Jan 24, 2010 | GE Profile Spacemaker Over-the-Range...
Microwave turntable works intermittenly - also no light
if you have on the key pad turn table on/off it may be the pad itself / I would ck the connections on the prosser . as the get film (correded ) you can use a spray cleanner for this . and it may correct the problem . flickering light may be the element and it may fail . (soon ) ****
Jan 09, 2010 | Samsung MW1030WA Microwave Oven
Dacor dcm24s.light, fan, and control panel work but turntable and heat do not
Most likely the bottom door switch. Dacor units are built by Sharp and that switch is a very common problem. You'd either need to check the switch with an ohm meter or remove the cover of the switch to see if it's burned inside.
Oct 20, 2008 | Sharp R-930AK Convection/Microwave Oven
Goldstar MV-1501 Microwave Oven Logo
61 people viewed this question
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
