Question about Dell Inspiron 1525 Notebook
I turned off my dell inspiron 1525 and it wont turn back on !!! Also my power adapter has a light on it .When I plug it in it turns off so I bought an extra one a few weeks ago and the same thing happens the light is on but when you plug it in it turns off ....
  • bcp317 May 04, 2010
    SMPS ???? lol sorry I dont know what or were that is on the laptop ...Is this something I can buy at a store?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 162 Answers
Your smps is not working just change it and it's works
Posted on May 04, 2010
Dell inspiron 1520 won't turn on.
Remove the battery from its compartment on the side of your Dell Inspiron laptop computer.
Remove the power adapter from its plug on the side of the Dell Inspiron (if your laptop is currently plugged into a wall outlet).
Press down and hold the "Power" button on the laptop for one to two minutes. This will dispel the excess electrical current that is built up inside the laptop.
Put the battery back inside the compartment of your Dell Inspiron.
Plug your power adapter back into the side of the Dell Inspiron. Press "Power." Your laptop computer will now turn on.
hope this helps
Oct 08, 2012 | Dell Inspiron 1420 1501 1520 1521 1525...
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
Last night with I turned on my Dell inspiron 1525 notebook..the screen when white and shut down...I turned it back on and it kept going throught this routine over and over..I was able to keep it on long...
here are some troubleshooting steps: like before remove the battery and the AC adapter, then connect just the AC, see if the LED on the adapter goes out or stays on. If it goes out, see if another adapter (known good is available) or see if you can try one at Bestbuy or such. If the system powers on, then replace the AC adapter.
If no power with a known good AC adapter, then the failure is likely the motherboard or the power board. You can try the powerboard 1st
http://shop.ebay.com/?_from=R40&_trksid=p3907.m570.l1313&_nkw=inspiron+1525+charger+board&_sacat=See-All-Categories
motherboard 2nd
http://shop.ebay.com/i.html?_nkw=inspiron+1525+motherboard&_sacat=0&_odkw=inspiron+1525+charger+board&_osacat=0&_trksid=p3286.c0.m270.l1313
manual here
http://support.dell.com/support/edocs/systems/ins1525/en/SM/index.htm
Sep 10, 2010 | Dell Inspiron 1525 Notebook
Dell inspiron 1525 battery not charging
Try to isolate the battery by plugging the power adapter to it. Then remove the power adapter & press/hold the power button for 5 seconds. Insert the battery, turn on the pc & insert the power adapter , check if the battery is charging. If it is still the same, contact their Dell Inspiron tech support 1-800-601-3355 for battery replacement possibly...
May 28, 2010 | Dell Inspiron 1525 Laptop Jet Black
Dell inspiron 1525 does not power up. i powered
Hi
Thank you for yuor query
Please can you try the following
1) Remove battery
2) Remove wall charger
3) Press and hold the power button in for 30 seconds
4) Plug in wall charger only
5) Retry powering the laptop and if it switches on plug battery in after 5 minutes
Regards
Shauqat
Apr 28, 2010 | Dell Inspiron 1525 Laptop
Dell inspiron 1525 won't turn on
Try to take out the battery and just use the adapter to power it on,
If your done with that then try just using the battery to turn it on, if it still won't give a single light.
If you can borrow an ac adapter for that laptop try it ,
If it still doesn't work. You'll need to replace the motherboard. Just make sure the ac adapter your gonna use is working good.
Feb 12, 2010 | Dell Inspiron 1525 Laptop
When i push the power button, inspiron 1525, it turns
try this.... go to start | run | control
go to power options
on the advanced tab there will be a option called
"when i press the power button on my computer"
select the "shutdown" option
click apply and ok
then try shutdown your machine using the power button
Dec 22, 2009 | Dell Inspiron 1525 Notebook
My inspiron laptop wont turn on after I replaced
Verify that you obtained an exact replacement power adapter for the Dell. If it is an exact replacement then try this. Disconnect power adapter. Remove battery. Reconnect power adapter without the battery. If it turns on, then power off and place battery back in. Then try again. If problem returns, there could be a problem with the battery itself.
Sep 28, 2009 | Dell Inspiron B130 Notebook
Can I use ther Targus Adaptor for Inspiron 1525
On the long term, a power adapter with a bigger amperage can damage battery and battery charger.
Better to get an adapter with same specs as the 65/70W one , or an original replacemant:
Dell Inspiron 1525 New AC Power Adapter Supply $14.29 - Buy.com Dell Inspiron 1525 65 Watt Original AC Adapter $25.00 - parts4nb.com Dell Inspiron 1525 Power Cord PA-12 $16.95 - AmeriMax Advance
DELL Inspiron 1525 DC Power Laptop Adapter ... £25.23 - B2C Shopping UK DELL Inspiron 1525 Laptop AC Adapter power adapter £38.99 - Very Good Battery Dell Inspiron 1525 Ac Adapter Charger Power ... £16.50 - eBay UK
AU/NZ - DELL INSPIRON 1505 E1405 E1505 AC Adapter Power Supply
Dell : Lind Electronics 70-Watt DC Power Adapter for Dell Inspiron
Apr 22, 2009 | Dell Inspiron 1501 Notebook
Dell inspiron 1501 work fine turn off last night now wont turn on
You mentioned trying a different battery, try a different AC adapter.
When plugging in the ac adapter to the wall, see if the POWER LED comes on on the adapter, then when you connect it to the computer, see if the LED stays on.
If the issue occurs with both AC adapters (No battery installed) then the motherboard has failed. If one ac adapter works but the other doesn't then the adapter is bad
Feb 01, 2009 | Dell Inspiron 1501 Notebook
Dell Inspiron 1525 Notebook Logo
158 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
