Question about Dell W5001C 50 in. Plasma HDTV
Won't power on
I have a 27" flat screen TV. Not working all of a sudden. Is there a fuse or reset button. Have no manual.
  • 2 more comments
  • nasmoore4 Nov 29, 2008
    when u plug it up it clicks and turns the screen blue or almost black . is there a way to reset or replace a fuse because all that happened was i plugged a phone line into the service plug trying to hook it to my pc
    thank you
  • dcortez Dec 25, 2008
    My W5001C 50" plasma will not accept power. The outlet is a known good one.
  • safirepits Dec 27, 2008
    I try to power my television, but nothing happens. It just has a black screen.
  • dcortez May 11, 2010
    W5001C 50" Dell plasma
Hi I have the same problem with a symphonic cst-l2006a any idea where to get a service manual?
Posted on Jun 02, 2008
  • Dell Master
  • 8,617 Answers
Yes all sets have a fuse, But its unlikely that if the fuse is blown replacing it will fix the set, as usually a short exist when a fuse blows. Post the make and model of your set and i should be able to post a link where you can get a service manual and some free support to help you diagnose your sets condition.
Posted on Mar 26, 2008
SOURCE:
Our Proscan TV was working just fine then suddenly just lost power, there is power in the cord but the light won't turn on, is there a reeset button or fuse?
No the TV has failed. most likely the main PCB has failed or is shorted. To repair this will be close to the cost of a new TV at current prices.
Aug 19, 2016 | Proscan Televison & Video
Where is the reset button?
Sanyo TV reset button location? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jul 27, 2007 - Does anyone know where to find the reset button on a 32" Sanyo TV? The thing is just totally dead and I am thinking maybe if I push the reset it ... how do i reset my sanyo flat screen television?
Dec 26, 2010
Sanyo DS32224 TV Problem!!?
May 21, 2009
More results from answers.yahoo.com
EASY MOST COMMON TV REPAIR EVER!!! - YouTube
? 13:13
https://www.youtube.com/watch?v=SXqSg2A5b7I
Jan 6, 2012 - Uploaded by Tampatec
Must See TV FIX EASY COMMON Samsung TV Repair Repairing LNT LCD PLASMA TV ... video tutorial television flat-screen model # kdl ln lt lnt hp ht LINK for TV boards & Parts ... 1. soft reset - is just turning tv off & back on ..... the source by using the on/off button on the side panel, remote does not work.
Dec 29, 2015 | Sanyo Televison & Video
This is a 32" flat screen TV that doesn't work. This has been going on for a while. Changed batteries in remote, nothing, put in different wall socket,
Bringing a flat-screen TV back from the dead - CNET
www.cnet.com > Tech Culture
CNETJan 19, 2011 - There are few technology tragedies as sad as a dead big-screen TV. ...good reason to upgrade to a new flat-screen doesn't come along every day, and I ...and eventually got the set working by replacing first, a blown fuse and ...
Flatscreen TVs - ConsumerAffairs.com
www.consumeraffairs.com/flatscreen-tvs
A TV repairman says today's flat-screen TVs are poorly designed ... "The TV wasworking fine up until Saturday, when it suddenly developed vertical .... is you can have it fixed for free under the warranty (if it doesn't run out - buy extended).
Top 5 Best Cheap Flat Screen TVs ' Heavy.com
heavy.com/tech/2014/10/top-best-cheap-flat-screen-tv-4k-deals-hdtv/
Oct 27, 2014 - Read on to see which cheap flat screen TV sets made our list. ... or secondary TV, but it also works great as a monitor or as a screen for console gaming..... an elderly family member who doesn't want or need those features
Dec 19, 2015 | Televison & Video
My Sony Bravia suddenly went off and I rebooted it, but although it gets power, there's nothing on the screen.
Something has failed internally, either a fuse or control board or power supply board. I gather it doesn't have sound either?
Jan 05, 2015 | Sony BRAVIA Televison & Video
Can't locate fuse on my Olevia TV...what does it look like? 27 inch flat screen
The fuse is located on the power supply. You have to remove the back cover of the LCD in order to get to the power supply. The fuse should be near the AC power cord jack. If the fuse is blown, you may have bigger problems than you anticipated.
Nov 07, 2011 | Olevia 227-S11 27 in. LCD TV
Brand new LG plasma stuck on test screens
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Hope it may help you;
Regards;
VOTIT
Jan 29, 2009 | Televison & Video
Tv will not turn on after sudden power outage
you most likely blew a fuse the only "reset" is to unplug the t.v. and leave it unplugged for a few mins, then make sure that you hold down the power button to drain the power out of the t.v.then turn it back on.... only other reset sequence is for removing the parental code
Jun 24, 2008 | Zenith C27A24T 27" TV
Dell W5001C 50 in. Plasma HDTV Logo
439 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
