Question about Toshiba 19HLV87 19 in. LCD HDTV
No picture,sound.Power light comes on (green light)when switched on with side switch or remote but now unable to turn off,need to disconnect plug from wall socket. Have been informed by TV repair station requires some kind of power circuit board,replacement cost at least $200.00cdn.Is this normal Toshiba quality for a 2 yr TV used only occassionally in bedroom.Never purchased Toshiba prior and probably will never again. Barry from Ontario
  • 308 Answers
Welcome to the world of HD TV sets. Many will last only a few years, regardless of brand. The cheaper ones last only till the warranty runs out and some of those only have a 90 day warranty.
Sounds like a power supply problem but can't be sure without opening it up. The repair cost is almost as much as a replacement set. Many choose not to repair and sell the set to others to try a repair on their own. Options are, pay $200+ for the repair, find another same set with a different problem (broken screen) and use it for parts to fix yours, or sell it as is for someone else to try and fix it. Let me know if you want to sell, I am in Ont also.
Posted on May 04, 2010
Magnavox 37MF23ID, would not turn on. Power button only blinks (green light). We have switched power cords and nothing happens. No picture, no sound.
if the power light comes on but the screen stays black, then your TV might be on the wrong input Channel. for example: you switch inputs when you play games or watch dvds vs. watching regular tv. Try to change the input
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/laura_08254539050d64db
Dec 27, 2014 | Magnavox Televison & Video
Green light stays on when trying to turn off tv. picture go's off when cable remote is used but green light stays onand you can see that screen is still on?
You need to set up the cable box remote for your TV , now you are just turning off the cable box. Some cable boxes have a switched plug on the back that will turn on and off with the box. If yours has the switched receptacle you can use that to turn the TV on and off by plugging your TV into the switched receptacle. Make sure the TV power is on, the receptacle will kill the power so the clock on the TV wont work. Otherwise you need to set the code for your TVs remote and use the system power button.
Apr 23, 2014 | Mitsubishi LT-46153 LCD TV
Toshiba regaza 37rv635db wont turn on
seems like capacitor problem, chack them and if thay have exploded replace them.
Aug 25, 2013 | Toshiba 37RV635DB Regza 37-inch Widescreen...
My hyundai plasma turns on, but has no sound or picture. It's a 2006, Model E420D.
Power supply is likely but if master power and not just the regular on off has to be used set is having a control problem. Power supply would be first place to look---even if green light remains no sound might mean control (main board) or power supply issue.
Nov 05, 2012 | Televison & Video
Sony bravia screen just stays on black and wont go to picture.
It sounds like a main board failure but could be a power supply issue as well. The set will need to be diagnosed
Oct 01, 2012 | Sony Bravia Kdl - 60Ex700 60 inch 1080P...
My pltv 26 plugs in i have turned the switch near the power plug on the standby light comes on but when i push power it turns green for a second or two then shuts off
Sounds like a built in protector kicking in. Something probably has shorted. Try disconnecting the inverter (should look like this: http://marcoselectronics.com/images/48.V1448.001.JPG) to see if you can get the TV to power on without a picture. Be careful - this is a high voltage board.
Sep 26, 2010 | Protron PLTV-26 26 in. HD-Ready LCD...
The tv's green "on" light continues to blink on and off. when we turn it on at the remote or at the on/off switch on the side, it won't turn on. we have unplugged it and the light continues to blink. We...
Try pressing and holding the remotes "Power on" switch as it may be a child lock that is activated. Otherwise try holding the tv "Power on" switch. Hope this helps.
Jun 19, 2010 | LG 42LC2D 42 in. LCD HDTV
Green light on front rapidly blinks after power outage. No picture, or can't turn on
This unit, when first plugged in or after power interuption takes 70 to 90 seconds for the digital module to boot up. During the time the LED blinks green and the set will not respond to anything. After the appropriate amount of time the blinking should stop and the set should operate normally. If the blinking never stops then you have to have the Digital Module repaired.
Apr 25, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Sanyo vizon dp42746 problem
Anyone have a suggestion for this? This thing is a year old and is kaput.... anything????
Oct 01, 2007 | Televison & Video
Toshiba 19HLV87 19 in. LCD HDTV Logo
332 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
