Question about Broan-NuTone CV353 Central Vacuum
When i put hose in port it will not turn on...all the other ports work except one
    Sniper:
  • 52 Answers
Open the door on the inlet port and look inside. You should see 2 small pins. These pins are spring loaded to make contact with the metal end of your hose when you plug it in. Two low voltage wires are screwed to the underside of these pins. The low voltage wires go all the way back to the low voltage switch/relay on your central vac power unit.
Sometimes one or both of these pins will just break so that they don't make contact with the end of your hose. If you see no pins or just one then you will have to replace the inlet cover.
If both pins are present; push down on them with your finger. If you feel resistance then your inlet is probably OK.
CAUTION: IF YOUR CENTRAL VAC INLETS HAVE A 110 VOLT CONNECTION, REMOVAL/REPLACEMENT OF YOUR INLET SHOULD ONLY BE DONE BY A QUALIFIED ELECTRICIAN.
Remove the two screws in the faceplate. Carefully slide the inlet cover out. Check the two screw on wiring connections. Make sure both wires are securely attached and that there are no breaks.
If neither of the above fixed your problem, you may have a broken or disconnected wire somewhere between this inlet and the low voltage witch at your power unit.
Posted on May 22, 2010
I accidentally vacuumed up a small plastic bag. Now I have no suction. No plastic bag is visible in the canister or the hose. What do I do?
Take my word for it, the plastic bag and / or its' remains is / are somewhere in the hose. Visibility of clear plastic in the dark environs of the interior of the hose is extremely limited if possible at all. Some hoses are corrugated on the inside especially if so on the outside. Without specificity as to brand my best first shot would be to attach the hose to the vacuum cleaners exhaust and try to blow the plastic back out the hose. The exhaust is the port from which the air comes out when everything's working as it should. Even before that, disconnect the hose from the canister, turn on the machine and see if there's any suction at the port where the hose attaches. No suction at the port eliminates the hose as the problem. If your machine will run without a bag, take the bag out and momentarily turn the machine on. Suction with no bag = bad bag. Still no suction= a trip to the vacuum service / sales store
Nov 02, 2017 | Vacuums
How do you make it blow air out? trying to make air blow out,i have the hose that has controls on it. will work to **** up but when i put it to blow out will not come on.
The Guardian Canister vacuums have a blow port under the filter. So you need to remove the filter (on the Guardian Ultra, you have to open the top of the vacuum) by lifting it up the forward. Then disconnect the hose from the normal suction end of the unit and plug it into the blower port. Now turn on the vacuum. If the hose is clogged, position the other end of the hose at the suction port.
For the Guardian canister, select the high, medium or low force for the motor. Then blow the dust out from under the furniture or use to fill an inflatable. Turn off the vacuum and replace the hose in the usual position and replace the filter when done.
If you are still unable to get the unit to blow out when connected to the exhaust port after attempting to clear the hose, separate the hose, wand and handle. Look down the hose for any object that might be creating a one-way valve. Remove the foreign object.Do the same with the other parts of the unit. Also replace the vacuum bag. If the bag is sufficiently full, the airflow will be reduced through the bag to the exhaust and cause the problem you describe.
The Electrolux Guardian Canister Vacuums are part of the Aerus line. The manuals for the vacuums are available here: http://www.aerusvacuums.com/support/manuals/index.cfm . The Guardian Ultra is in the current model section. The Guardian is listed in the Older Model drop-down menu.
I hope this helps.
(many canister vacuums have a blower mode when you connect the hose to the exhaust (after the bag) instead of the suction side of the unit.)
Aug 17, 2011 | Electrolux Guardian Bagged Canister Vacuum
My Dyson DC17 is picking up on the floor, but the wand is not working. I cleaned out a clog from the port in the back, but the wand still isn't working.
If there's no suction at the end of the wand, check at the end of the hose. If none here, then there's none at the powerhead, so it's not picking up either.
Check the hose. A clog at the tank port generally result in a clog in the hose as well. If none are visible, detach hose completely, hold one end up and drop a coin in. Lifting the hose should result in the coin falling through. Not doing so means a clog. You may be able to push it through with a broom handle. If that doesn't work, try holding the powerhead end of the hose to the tank port. Turn the vacuum on. This may provide enough suction to pull the clog through.
If not, and you have access to a shop vac or air pressure hose and generator, try blowing the clog out with one of these. Or you can buy an air mattress pump and try that.
Mar 09, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
How do i change from vacuum to blower?
In order to change from suction to blowing, insert the hose into the
exhaust port of the vacuum cleaner.
The vacuum cleaner should have two ports, one which is for suction,
the other is an exhaust port. The exhaust port can be used for blowing
when the hose is inserted into it.
After inserting the hose into the exhaust port just turn on the switch.
Jan 17, 2011 | Black & Decker UV200 Wet/Dry Vacuum
How do you hook up the hose
Hello There,
Here's instructions on how to use the hose assembly on your Hoover SteamVac Dual V:
UNPLUG THE UNIT FROM THE WALL.
Attaching The Hose
  1. Open Hose Connection Port (Figure A).
  2. Insert Short Hose End, Matching the tabs on the hose with the same-sized slots in the connection port.
  3. Plug Hose into Port and twist to lock it in place.
  4. Plug the solution Tube that protrudes of the suction hose into the solution connection port (Figure B)
Removing the Hose
  1. Squeeze Latches (Figure C) on top and bottom of the hose. Remove hose from port. Close the Hose port door.
  2. Remove the solution Tube from the Solution connection port by pressing on the white latch.
I hope that this answered your questions. If you have any other questions on hose to use your hose, please feel free to use the comment box at the bottom of the page. I'm always happy to answer any of your follow up questions. If you found this repair helpful, please be so kind and rate the repair helpful, or by leaving feedback. This is very appreciated by the FixYa community and is what keeps repair experts like myself continue to answer free questions, instead of just answering the premium questions in which you have to pay. Thanks so much.
Chris Jones
GoVacuum.com
Jan 07, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
I have an electrolux central vacuum in my house. My central vac hose has something stuck in it, I think, maybe a sock. I tried to put a long dryer wand down it but the hose is just too long. Does this need...
The best way to clear an obstruction is to blow it out by attaching the wall end to the exhaust of a shop vacuum, or using an air compressor.
You can try holding the wand end of the hose directly to the CV in port and turning the machine on. This provides essentially the same action as the previous method.
If neither of these work, try a combination of the two. Or using a shop vac, hold the wall end to the exhaust of the vacuum and the wand end to the in port of the shop vac. Turn shop vac on and the obstruction should come out.
Borrow a good strong shop vacuum if you need to.
If these methods fail, take it to an authorized Aerus Electrolux store and have the service tech try to clear it. Care must always be taken when trying to clear an obstuction with a long object, especially if it's pointed. I've seen many hoses that have shorted out and even caught fire due to the wiring accidentally being "nicked".
Jan 03, 2011 | Electrolux Central Vacuum
How do you unclog a hose on a Bissell proheat powerlifter
Detach the hose completely.
Plug wrong end of hose into in port of vacuum.
Turn on. This should remove the clog.
If not, try using a vacuum with an exhaust blower to blow out the clog. Most canisters have these. An air pressure hose may work as well.
Nov 23, 2010 | Vacuums
My vacuum won't pick up anything how do I clean it out
1. Replace bag if needed.
2. Check hose/s for clogs. You'll need to detach both ends of the hose, check for visible clogs first, then try to roll a marble through the hose. If it doesn't go all the way through, there's obviously a clog that needs to be removed. Blowing it out with a machine that has an exhaust port usually works for me.
3. Check tube in powerhead and intake on vacuum for clogs. Remove if necessary.
4. Clean filter.
5. Leaky hoses will also cause extreme loss of airflow/suction. No fix for this, except to replace the hose.
Aug 23, 2010 | Eureka 12 Amp Capture Vacuum Upright...
How do i change from leaf blower tovac? vac will only blow i need to cahange it to vac mode
fell on top of vacum for the place where the air is being sucked in that is the vacum port put hose on this port
Oct 22, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Broan-NuTone CV353 Central Vacuum Logo
287 people viewed this question
Top Broan-NuTone Vacuums Experts
Steve
Gerry Harvey
Gerry Harvey
JoeVacs
Are you a Broan-NuTone Vacuum Expert? Answer questions, earn points and help others
