Dell Dimension 4700 - Power light starts flickering as soon as power is plugged in.
  • 20 Answers
Sounds like the power supply is failing.
Posted on May 05, 2010
Green power light comes on but disk drive lights keep blinking and my screen is black on my dell dimension 4700
Remove ALL media from the machine DVD, CD, USB, etc. Check/reseat all Monitor cables. Reboot. If that fails, unplug , plug back in in 30 seconds or so. reboot, if you get a Dell Logo, Open the boot Menu and select Boot from HDD first.
Dec 23, 2012 | Dell Dimension 4700 PC Desktop
What's your problem?a way to turn the SATA ports to ON in the BIOS
You can go into the bios and on those drives that are not found you can turn them OFF or N/A. They are probably set to AUTO or ON.
If that does not work I would say remove the power cord, remove the cover, then remove the main power to the motherboard then plug the main power to the motherboard back it. The main power will run from the power supply and the end of it will be about a 2 inch strip that plugs into the board. Press and hold the little catch on it then pull it out of the socket on the board. Put it back in firmly. Reboot and see what happens.
Apr 04, 2012 | Dell Dimension 4700 PC Desktop
Dell desktop 4700 problem
Flashing Amber power LED indicates a bad power supply.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817822008&cm_re=atx_power_supply-_-17-822-008-_-Product
If the LED Is SOLID amber, it is likely either a component connected to the Motherboard or a bad motherboard
May 15, 2010 | Dell Dimension 4700 PC Desktop
Qiuck orange flash light when i start my dell pc
that means that its has problem recieving power or a power supply could be going out soon make sure it is plugged in directly to the wall outlet on no power strip or multi-outlet.Check the black power cable in the back computer . Make sure its tight in there.
May 14, 2010 | Dell Dimension 4700 PC Desktop
Have a dell dimension 4700 with orange steady light?
Turn the machine off and unplug the AC power then hold the power button in for about 30 seconds to drain any residual power. Plug it back in and turn it on, when you see the Blue DELL word press CRL+ALT+D and this should run a diagnostic on the hard drive. If it runs ok you will get a pass or fail on the hard drive. If you cannot get the diags to run you might have a bad power supply or motherboad/processor. I would find a known good power supply and try it before the motherboard.
Mar 09, 2010 | Dell Dimension 4700 PC Desktop
I turned on my Dell Dimension 4700 computer,but the amber light started to blink . I held the start up button for 5 seconds and the light went out. I tried to start it up again and got the same thing,...
Vaughn it sounds like the power supply is going bad, try another known good working power supply. If that doesn't work then the motherboard would need to be replaced. If the power supply isn't giving the correct voltages that could cause the computer not to turn on. If the motheboard isn't able to convert the voltages properly then the motherboard could be faulty.
Dec 23, 2009 | Dell Dimension 4700 PC Desktop
Dimension 4700 series does not power up??
make sure the power cord is plug in tight, or try another power cord.
make sure the fan at the power supply comes on. if it still doesn't power up, then you need to check the power supply with a voltmeter at the output pins.
Mar 17, 2009 | Dell Dimension 4700 PC Desktop
No display and wont boot
A Blinking Amber or Yellow power button means that the power supply is receiving power from the source but is unable to properly distribute it to the components. This can be caused by a defective power supply or a defective motherboard. Power supply is easier and cheaper to replace.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 12, 2008 | Dell Dimension 4700 PC Desktop
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
