Have a daewoo dlt37c3ftb stuck on stand by - Televison & Video
Engine number location 1999 daewoo lanos
wow, this is a complicate question. i just take for a look:
YELLWWORS Welcome to visit our site
Jan 10, 2016 | 1999 Daewoo Lanos
My dwd m 12c6 daewoo washing machine will not spin
Blocked drain pump and or drain outlet hose. Check the inside of the pump as well. Daewoo are common to get coins etc stuck in the tub to pump hose and foreign material stuck around the impellor in the pump. If it cant pump out, it wont spin.
Jan 05, 2015 | Daewoo Washing Machines
My Daughters Daewoo lacetti has an intermitent battery drain when standing, can go for weeks with no problem then find the battery completely drained sometimes after only standing for 2 hours. it allways...
if batt ovr 3yrs-u need a new one--may have connection issues too-inspect cable/wires----alternator can drain battery if it has a diode or voltage regulator matter--dont go to a dealer
Aug 18, 2013 | Daewoo Cars & Trucks
Tv is stuck in stand by mode.
sounds like electrolytic capacitors in power supply examine for swollen or split cases replace with same capacity but higher voltage rating if possible they are only cheap so you could change them all dont forget to observe the polarity
Aug 11, 2012 | Daewoo LCD37INT 37 in. LCD Television
My Daewoo TV is stuck in standby mode
All you've got to do is get your remote and press the "stand-by button." As simple as that. Thanks
Sep 07, 2011 | Daewoo DTQ-20U4SC 20" TV
Where do i fill my gear oil for cielo daewoo 1.5 i L 1998 model
From what I heard if you stand in front of the car there is a place looking down the gearbox you'll see a place to add it half way down
Mar 24, 2011 | Daewoo Lanos Cars & Trucks
My tv is stuck in teh stand by mode...how can i fix this
Have you tried unpluging it for a few minutes, then plugging it backin?
Sep 08, 2009 | Daewoo DVN-14F6N 13" TV
2000 Daewoo Lanos 16v sx sport How do you know when the timing is out because car jerks alot . When I stand at a robot ,the CAR REV'S on it's own.
i need to change daewoo nubira engine model 2000 sx 1.6 with the gear box so which engine and gear should i search for tks
Aug 07, 2009 | 1999 Daewoo Nubira
Daewoo leganza
if you stand in front of the car, it is on the right side of the radiator at the bottom, you can turn it with your hand
Sep 28, 2008 | 2000 Daewoo Leganza
Televison & Video Logo
134 people viewed this question
Top Televison & Video Experts
Electro Med Services...
