Question about Samsung SGH-d807 Cellular Phone
Samsung SGH D807 Charging Problem and no screen display
1. My phone is not able to start charging when I am inserting the charge plug. I need some repetitive effort to start charging.
2. Sometime my phone is not taking charge though it's showing charging movement. As soon as the charge plug is out it switches off due to low battery level.
3. The screen is not showing any incoming call. It just rings and the screen is black.
    President:
  • 1,561 Answers
Have you try to use another similar charger to charge your phone to see if it ill charge? because it could be that your charger is bad,. But if you have done that and it is same thing, it means the charging port of your phone is malfunctioning, that is why you have to use repetitive effort before it can charge.
Your battery is not charge due to the bad charging port of your phone, so your phone battery can not hold charge.
To resolve 1 and 2 problem of your phone, all you need to do is to change the charging port of your phone in other for your phone battery to charge and for your battery to charge.
Replace the charging port as said and you will see that your phone battery will charge.
For your screen, is it that the entire screen is black that you cannot see anything, not even text or see names from your contact? if it is, what you need to do is to change the flex on the the screen of your phone and you will see that your screen will display as you want it.
Take care.
Posted on May 04, 2010
Phone not charging
did you check your charger?9 9% of not charging problem is on the charger itself,investigate the wire near the charger body and near the plug or pin.t is better if you can test your charger to another fon thats why you can simply find out if your charger is working or not..But if the problem is not on your charger,the defect is on the celphone connector or its ging regulator.
Nov 24, 2009 | Samsung SGH-d807 Cellular Phone
Only charges... nothing else works on my Samsung
It should be fine to call when the phone is charging. It could be that the phone was "sleeping" as it charged and then the sudden energy draw of the phone call while it was charging screwed up the battery. I think you should take it to the shop.
Aug 23, 2009 | Samsung SGH-d807 Cellular Phone
I can't turn off my Samsung SGH - D880
Yesterday I also got the same problem on Samsung DUOS SGH-D780!
I found temporary solution how to drop this error message and run the phone normally, but after next reboot it often become again. I will ask Samsung tech. support about this, but now here is the emergency solution:
1. Turn OFF the phone (by removing the battery)
2. Move out all the SIM cards from the phone
3. Insert the battery again (BUT DON'T TURN ON THE PHONE, just insert the battery)
4. Insert a charging cable into the phone and insert the adapter in wall outlet
(then I see the loading screen for the short time and after that CHARGING icon appears)
5. After that turn ON the phone. It will start in no-sim mode.
6. Turn OFF the phone
7. Remove battery, insert SIM-cards, insert the battery.
8. Turn ON the phone
After that it gonna be work good until next reloading...
Feb 27, 2009 | Samsung D880 Cellular Phone
Samsung sgh p310 wont charge
check to make sure it is connected properly and whether the pins in the phone's charging slot are not broken, because I have a samsung SGH-D807 and I forced the charger in the slot and the pins got broken, it won't charge. I have to repair it.
so connect it properly and check to see if the pins are broken, if not, try another power socket to plug the charger in, not all sockets are compatible with a charger.
Dec 13, 2008 | Samsung SGH-P310 Cellular Phone
Not charging
got same problem ??? did u get it sorted  ??? if so how ???
Dec 22, 2007 | Samsung SGH-D600 Cellular Phone
Charging port connector
You can get it fixed at a place in Los Angeles Tel: 323-651-5555
Nov 18, 2007 | Samsung SGH-d807 Cellular Phone
Phone loses charge really fast
try ur phone's batery in other h set might be problem with battery of ur h set good luck if problem persists then contact ur samsung service centre GOOD LUCK !
Oct 13, 2007 | Samsung SGH-d807 Cellular Phone
SAMSUNG d807 WONT CHARGE
Same thing happened to me with this phone and a brand new one (same model). I suggest getting a different phone.
Sep 19, 2007 | Samsung SGH-d807 Cellular Phone
Samsung SGH-D807 problem
try taking the battery out and reinserting it.
Aug 25, 2007 | Samsung SGH-d807 Cellular Phone
Samsung SGH-d807 Cellular Phone Logo
564 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
