Question about Canon ImageRUNNER 330s Copier
Display says "turn main power off/on" - Canon ImageRUNNER 330s Copier
  • 3 more comments
  • jbwhitt May 04, 2010
    will not change display to get into service mode
    dispaly says "turn main power off/on". I attempted to change service mode by pushing "add.fun."; "*" then "2" & "8"; "add.fun." again. The display did not change
    what is the "userbutton" ?
    display also says "E805"
    Will I have to call a tech or should I keep trying to fix
  • 1,511 Answers
Hello
E805 error code means failure of one of the many fans inside the copier. If there is not a dash with four numbers after the 805 code on the display, it is one of two fans - FM1 the transport bed fan or FM9 - the reversing fan just below the fuser assy. There are several checks that can be done but a too lengthy to be described. In the End, all the process would be worthless if you didn't got that much technical expertise (soldering/de-soldering, assembling.....)
The Error E805 is generally associated with some sub error codes, here is the list of those errors and a general way to trouble shoot...
E805 Error code details Fan rotation error
The clock signal is absent for 5 sec or more after the fan drive signal has been generated. The detail codes of the fans in question are as follows:
0001 developing fan (FM1)
0002 fixing fan (FM2)
0003 curl reducing fan (FM4)
0004 curl reducing fan (FM5)
0005 electrical unit fan (FM3)
Main cause
 The fan wiring is faulty (short circuit, open circuit). The fan is faulty. The DC controller PCB is faulty.
  • If there is any foreign matter that prevents the rotation of the fan, remove all that contamination.
  • Make sure that the wiring and connector of the fan is in working condition.
  • Check for the working of the fan by removing it from the electrical unit. If fan is Ok and still getting the problem, Replace the DC controller PCB.
Cross checking all above possibilities require technical expertise, So if you think that unfortunately you are lagging behind a bit in this area,then ultimately you need to contact professional Repair person.
Best of Luck,
Please do RATE my solution, If found HELPFUL,
Regards.
Posted on May 04, 2010
  • 1,170 Answers
That error code means that there is something wrong with the fixing unit. Try to get into service mode by pressing : The "add. Fun." "*" then the numbers "2" & "8" at the same time then press the "Add. Fun" button again. The display should change, then Press the Function on the top of the display, then press the "CLR", then "ERR" then the "OK" in the bottom coner of the display. Turn the Main power switch OFF on the right side of the copier, then back ON.
  • 2 more comments
  • Arjun Komath May 04, 2010
    Press the userbutton then press "2" & "8" at the same time and then press userbutton again.
    You will now enter service mode.
    press " Copier "
    press "function"
    press "Clear"
    press "Error"
    Leave servicemode by pressing reset button twice.
    Then, you have to restart machine.
    Do you see a E001 error code ?
    The * button
    The Error Code is related to an Over temp issue in the fuser unit.
    A few things to look at are:
    A. Thermister - The fuser Temp sensor.
    B. Composite Power supply
    C. SSR1 - Solid State Relay
    D. DC Controller PCB.
    Code error E805 in OCE copier means that you have to change the web cloth .
    Calling a Tech would be advice able, as the repair requires professional tools.
The display flashes F C then starts beeping. I turned off the breaker for 5 minutes and put back on but it started again.
Communication error detected by display board(main board), Lower oven relay board not powered up, check all power connections to the oven relay boards. Check all connections from the main board to the relay boards.
Aug 22, 2015 | Thermador SC272T Electric Double Oven
Can a tv inverter board cause tv to not display
inverter board may be used to power backlight for the lcd display. If it is similar to laptop lcd displays in functionality .
http://www.ehow.com/how_7501465_check-tv-inverter-board.html
Apr 17, 2015 | Coby 40 TFTV4028 LCD TV
My canon MF4412 is power on but display is coming turn the main power on E202-0002
my mf4412 printer displaying a problem e202-0002 and red button continue burning
Jun 24, 2012 | Canon Office Equipment & Supplies
MY PRINTER PIXMA MX310 SWITCH DOESNT TURN ON AND THE ALARM SHOWS. thier is no lcd displayed WHAT DOES ITMEAN?
Possible that the power supply is faulty as there can be a link failure to the display, Also it can be a failure of the display drivers, Possible fault in the display sub processor or even the main board.
You need to cross check and confirm with voltage checks on the power, display and main board.
May 04, 2011 | Canon PIXMA MX310 All-In-One Printer
Infotec 5221 displays a E-5 symbol
E-codes (E1-E7)are displayed im the copy counter.To display both digits of the E code press the Enter key.When service call E5 conditions occur,they cannot be cleared by turning OFF/ON the main switch for safety reasons.Ehe following procedure must be performed to clear these service call condition:
Turn ON the main switch.
Turn DIP switch 101-1 ON and OFF.
Turn the main switch OFF and ON.
Code E 52 Fusing lamp warm up error.Causes:thermistor open,fusing lamp open,therofuse open,power supply/ac drive board defective.
Code 53 Fusing lamp overheat.Causes:thermistor short,power supply defective,main board defective.
Code 55 Fusing thermistor open.Causes:thermistor open,main board defective,power supply/ac drive board defective.
Aug 14, 2009 | Ricoh Office Equipment & Supplies
On copier sow display bord "Swith main power off and on E001
When switch on ImageRUNNER 330s Grayscale Copier then no display on dispaly board. But Copier front yellow led is on. Please solve this problem.
May 29, 2009 | Canon ImageRUNNER 330s Copier
How to reset microprocessor
TURN OFF MAIN POWER HOLD DOWN SPEAKER A AND B BUTTONS WHILE TURNING ON MAIN POWER ,DISPLAY WILL BLINK A FEW TIMES THEN RELEASE SPEAKER BUTTONS.
Apr 23, 2009 | Audio Players & Recorders
Display gone, no longer functioning
Green light but no display- most likely main transformer is gone (60%), 35%- blown main fuse, 5%- bad display or power supply. You are lucky if unit is still under warranty. Solution- repair shop.
Dec 31, 2008 | Denon AVR-2807 Receiver
SC-pt750 - screen says CT-Mode wont change
Try cold start.
Power off main set manually by press power button on main set.
Unplug power cord from main set.
Wait for about 5 sec.
[Without plug in power cord] Press and hold "Power" button without release it.
Plug in power cord (must have power) to main set by using another hand [while another hand still press on main set power button]
Keep holding until u see ------ on main set FL display.
Then release you hand which just now pressed on main set.
Power on main set again by manual press power button on main set.
Result should be OK (unlocked)
Dec 06, 2008 | Panasonic Home Theater System System
Display doesn't work, but oven works
First turn the electricity off by locating the breaker to the oven and turn it off. Now wait for an hour or so and turn the breaker back on, if the display turned back on, you need a control board (other manufatures call it a clock, PCB or ECC but it's the main elctronic board with the diaplay built in). If it didn't come back on, turn the power off again and make sure all the wire harness's going to the board are connected good. Turn the power back on and it the display still doesn;t come back on you need to replace the main electronic control board. By the way double check the model number and brand because it might be wrong. Please post back.
Oct 04, 2006 | Whirlpool RBD275PD Electric Double Oven
50 people viewed this question
old marine
old marine
