Question about Samsung L210 Digital Camera
My Samsung L210 won't work anymore. When i turn it on it beeps 4 times and then it shuts off. Someone knows what is wrong with it?
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on May 04, 2010
Testimonial: "#7 totally worked! thanks for the advice! I'm glad i don't have to purchase a new camera now :)"
Samsung trouble shooting
Your problem - Zoom not work -
If you want to repair yourself - use this documentation -
L210
Aug 20, 2014 | Samsung L200 Digital Camera
How can i get my fridge to stop beeping?
Good Afternoon Friend,
I understand you want to know how to make your Frigidaire refrigerator, model# FRS3R5EMB, stop beeping. Please try pressing the "On/Off" button on the Fresh Food Temp side of the control panel. If that does not work, I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 05, 2014 | Frigidaire FRS3R5EMB Side by Side...
Gateway GT5648E PC won't power up - continuous beeping.
hi, on the motherboard there is a ATX connector from the power supply now there is a problem with the actual switch or the power good to the motherboard otherwords the power supply if one of the components is not getting a voltage or the right level of voltage you will get this bleeping now if it's always 25 times then works i would point the finger at the power supply can you check that the devices attached such as the harddisk etc are getting power from the power connector ? i have seen this problem before and it was the power supply and power switch regards
Dec 16, 2012 | Computers & Internet
When I power on our Samsung L210, it turns on for about 4 seconds, beeps 3 times then turns off. What is the issue?
Sometimes the LENS can get stuck inside of it or outside of it. I would wiggle the lens around a little bit, putting a bit of pressure on it while doing so and see if that fixes it. Make sure you're attemping to turn the camera on while doing this.
Apr 05, 2011 | Samsung L210 Digital Camera
My Thinkpad G41 does not boot up, nothing comes up
Hello
Have you tried swapping out ram modules? This would probably be the cheapest. And, a faulty ram module gives a beep code. Try it, and let me know.
Kind regards
Andrea
Apr 21, 2010 | IBM ThinkPad G41 Notebook
My camra beeps 4 times and shuts down. what could it be ?
maybe u need to charge it or put in batteries most cameras do that
Apr 04, 2010 | Samsung L210 Digital Camera
I turn camera on. Lens comes out. beep 3 times. turns off.
Everytime I try to turn it on, the lens comes out for about a second, the camera beeps 3 times, the lens retracts and the camera shuts off. The battery is completely charged and the camera is only 4 months old. HELPP :(
Jun 17, 2009 | Samsung Digimax S500 Digital Camera
Digital camera starts then shuts down
yeah its broken sorry mate
suggest a new camera
Dec 15, 2008 | Cameras
Problem with camera
The lens is sticking, I had same problem, thought it was the battery. It kept doing 4 beeps and turning off, but the lens would be out.
Lightly lube the lens area with WD 40 worked, be real careful and don't use alot of it. My camera works fine now. I actually read the solution someone on this site, can't find it now, but wanted to post that it worked for me. I love the camera and was bummed it wasn't working. Works great now!
Aug 04, 2008 | Samsung NV10 Digital Camera
Camera beeps 3 times the shuts off
I've decided to send the camera in for possible repair.
Feb 17, 2008 | Samsung S630 Digital Camera
Samsung L210 Digital Camera Logo
538 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
