Question about HP Computers & Internet
How-to install a display screen in a HP G71-340US
  • 1,170 Answers
Here is a link to a detailed tutorial for replacing the Laptop LCD : http://www.instructables.com/id/DIY---Replace-Broken-Laptop-LCD/
Posted on May 04, 2010
How do i reduce the text and icons on my laptop display/screen
Assuming you have a Windows system:
  1. First make sure you don't have the type size and icons set to a large size. Right click on your Desktop and choose 'Personalize'. Then in the lower left choose 'Display'. Make sure that you have selected 100% as the size of text and icons. If you have, proceed to #2
  2. Make sure that you are displaying at the native resolution on your laptop. If Windows doesn't have the right software drivers (instructions) for the display it will use some generic drivers which will work but will make everything appear large and potentially slightly fuzzy. Verify the potential resolution of your laptop with HP by looking up the model on their website and then checking the screen resolution. Then right click on your Desktop and pick 'Screen Resolution' from the context menu. Verify that the resolution is the same as the HP's listed resolution. If not, change it to match. If you can't change it to match that means you don't have the correct video card driver installed on your notebook. Go to #3
  3. To install the correct video driver for your notebook, go to the HP Support site and click on 'Detect my product'. This will install some HP software that will recognize your system and load the appropriate updated software drivers for all components. You want to specifically find 'video drivers' but it will probably be OK to let others found by the website be installed. Install the video drivers and then if the screen isn't displaying at the correct manufacturer resolution, go back and repeat the instructions in step 2 to manually set it.
That should get everything displaying at the correct size.
Drivers Downloads
Feb 18, 2015 | HP Pavilion Computers & Internet
Can I configure an on-screen monitor since my display in not working on my hp cp1700
If you install the HP Color Inkjet CP1700 Toolbox software it will give you all the on screen monitoring you need in lieu of a defective LDC display.
Dec 30, 2010 | HP cp1700 Color Inkjet Printer
My HP 9311 Tx does not give display on its LCD screen
after loading Operating system just press F5 and wait for 2-3 seconds. if display not appear try 1-2 times. it will come. plz replt if ur problem solved
Apr 10, 2009 | HP Pavilion dv9000z Notebook
HP creen display Multiples vertical windows
http://www.nerdmodo.com/2009/04/repairing-the-display-problem-in-hp-dv2000dv6000 -series/
Mar 29, 2009 | HP Pavilion dv2000t Notebook
F380 All-In-One won't print
first of all you need to install the software..these are the steps to install the software please follow the steps below
Two installation options are available when installing the software and drivers from the product CD. The recommended install installs everything your device requires to work, including a suite of software recommended for your installation. The custom install allows you to choose what software to install. The recommended install is designed to work for most users. Use the custom install only if you have one of the following reasons:
  • Low hard disk space on the computer.
  • You do not want the additional software.
  • Errors occur during the recommended installation. NOTE: If errors occur during the recommended install, fix them before doing a custom install.
Recommended install Complete the following instructions to install the software: CAUTION: Do not connect the USB cable until prompted to do so during software installation. HP recommends using a USB cable that is less than 10 feet (3 meters) long. NOTE: Choose unblock or accept on all firewall messages or the install will fail.
  1. Insert the software CD into the CD-ROM drive of the computer. The software installer starts automatically. NOTE: The User Account Control screen might display. Click Continue .
  2. Click Install on the Thank you for purchasing from HP! screen.
  3. Click Next on the Welcome to the Install Wizard... screen.
  4. Click Next on the Do Not Block HP Install Wizard Processes screen.
  5. Select Yes or No on the Automatically Check For Updates screen and then click Next .
    • Choose the Yes (recommended) option to check for updates through an Internet connection.
    • Choose the No option if you do not want to check for updates.
  6. Select Recommended on the Installation Options screen, and then click Next .
  7. Follow the instructions on the screen that displays to finish installing the software.
Custom install CAUTION: Do not connect the USB cable until prompted to do so during software installation. HP recommends using a USB cable that is less than 10 feet (3 meters) long. NOTE: Select unblock or accept on all firewall messages or the install will fail.
  6. Select Custom on the Installation Options screen, and then click Next .
  7. Select which software to install by selecting or clicking to clear the check box next to each item on the Custom Installation screen. Click an item to see its description and the required disk space. NOTE: You must install the drivers and the HP Imaging Device Functions for the buttons on the front panel to be functional.
  8. Follow the instructions on the screen that displays to finish installing the software.
  9. once the software installation is complete try to print that should work
Mar 09, 2009 | HP DeskJet F380 All-In-One Printer
I Have a Hp Deskjet F380 ALL-In-ONE Printer-Scanner-Copier,I Need Know How to install a print driver for my Hp Deskjet F380 Printer.Thank You, I Need Help????
How do I download and install the software? To download the software, do the following:
  1. Click here to go to the Software and Drivers page for your product.
  2. Click your operating system.
  3. In the Driver section, click the appropriate software driver.
  4. Follow the instructions on the page that appears to download and install the software.
How do I install from the CD? Two installation options are available when installing the software and drivers from the product CD. The recommended install installs everything your device requires to work, including a suite of software recommended for your installation. The custom install allows you to choose what software to install. The recommended install is designed to work for most users. Use the custom install only if you have one of the following reasons:
Aug 19, 2008 | HP Office Equipment & Supplies
I can conect my printer D1420 to the computery
May 27, 2008 | HP Office Equipment & Supplies
No display on screen
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=bpl10237
Remove and re-install memory and dimm cards - follow the instructions above on their location
Apr 08, 2008 | HP LaserJet 4100dtn Printer
Computers & Internet Logo
23 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
