Question about Sun Aire Sun-Aire Air Purifier - Stainless Steel, Permanent Filter for areas up to 2,000 Sq Feet Air Purifier
Where and how can I order new filters. - Sun Aire Sun-Aire Air Purifier - Stainless Steel, Permanent Filter for areas up to 2,000 Sq Feet Air Purifier
    Guru:
  • 15 Answers
Http://instinox.com/flanges/duplex-stainless-steel-flanges/
Posted on May 04, 2016
    Problem Solver:
  • 11 Answers
You never need to ORDER new filters for your SUN AIRE purifier unit. Our pre-filter is LIFETIME/WASHABLE 0.5 micron 2-stage electro-static and NEVER needs replacement. Our pre-filter saves you about $100-200 per year in expensive replacement HEPA/charcoal/carbon filters on other units. Made in America and built to last you a lifetime- SUN AIRE purifiers! www.betterair.com
Posted on Dec 21, 2010
Need new filters
You may need to order the filters directly from Amcor unless you can find a local source
May 02, 2013 | Air Purifiers
Where can I find replacement filter for Kenmore 85500 air cleaner
I just went to the chat site for sears parts and asked them to find one. They ordered part #119010 Filter CATEGORY: Plumbing and Heating
PART NUMBER: 119010
which comes up to this page... http://www.searspartsdirect.com/partsdirect/part-number/119010..... I did order it through them.. I hope this helps anyone else looking for a replacement filter for the Kenmore #85500 with filter #85501.. With the link above you can order it online.
Feb 14, 2013 | Kenmore EnviroSense 85501 Air Purifier
How do you reset the filter reminder warning light?
Filter Replacement
Filter Replacement Indicator:
Your Defender® is equipped with a Filter Replacement Indicator located on the front
panel. Anytime this red indicator flashes, it is recommended that you call your authorized
FILTERQUEEN® Distributor to order a replacement filter. Anytime this red indicator stops
flashing and remains solidly illuminated, it is recommended that you change your filter. To
receive full benefit from your Defender® and to extend your warranty, it is strongly
recommended that you follow the filter replacement schedule suggested above. Under higher
pollution levels, your filters will need to be replaced more frequently.
The Filter Replacement Indicator is operated by filter time in use and is controlled by an
onboard timer. After 11 months of time in use of your Medi-Filter® Cartridge, the Filter
Replacement Indicator will begin to flash. It will continue to flash until the you reach 12
months of time in use, at which time the Filter Replacement Indicator will stop flashing
and remain solidly illuminated.
After replacement of your Medi-Filter® Cartridge, you must reset the Filter
Replacement Indicator's timer. When the timer has been properly reset, the Filter
Replacement Indicator will turn off.
Resetting the Filter Replacement Indicator Timer:
After replacement of your Medi-Filter® Cartridge per the instructions found on page 7, the
Filter Replacement Indicator's timer can be reset by performing the following sequence of
steps:
1 Plug unit into outlet.
2 Press power On/Off switch to the On ("I") position.
3 Allow unit to start running at low speed.
4 PRESS and HOLD both the Up and Down arrow buttons until the Filter
Replacement Indicator starts to blink.
5 Release both the Up and Down arrow buttons.
6 While the Filter Replacement Indicator is still flashing*, again PRESS and
HOLD both the Up and Down arrow buttons until the Filter Replacement
Indicator turns off.
If the steps above have been performed properly, the Filter Replacement Indicator will
turn off and not flash again for 11 months. If the Filter Replacement Indicator remains
on, repeat the steps again.
*Note that in step 6 above, the Filter Replacement Indicator MUST still be flashing when
the buttons are pressed the second time. The Filter Replacement Indicator will continue
to flash for approximately 3 seconds after the buttons are released as required in step 5 above.
Note: Under higher pollution levels, your filters will need to be replaced more frequently.
Note: To order replacement filters, call your authorized FILTERQUEEN® Distributor, or call
1-440-846-7800 for the Distributor nearest you.
http://www.filterqueen.com/pdf/defender.pdf
Mar 02, 2011 | Filter Queen Defender Air Purifier
In what order do the filters go back in after I've cleaned them?
The honeycomb goes in first, followed by the mesh, then filter sponge, then the other mesh. Then you attach the filter lock plate. Hope this helps you.
Jan 27, 2011 | Ecoquest Fresh Air Air Purifier
How do I care for my charcoal filter? When do I need to change from normal to auto and what does that mean?
Charcoal filter can be brushed off with a soft brush or vacuumed. Soaking or using cleaner of any kind is not recommended. Order a new one from the company when it gets too dusty to clean out, when it's bent, when it looks "thinner" or has empty spots, or when you've used it for 2 or 3 years. The carbon helps absorb odors, and gets "used up" after time.
I need the name/model of the machine to tell you what normal/auto means. In any case, daily operation should be in the "normal" setting.
Jan 24, 2011 | Alpine Air Purifiers
Can't locate parts for Ecoquest Breeze AT in N.Z. I need glass filters.
The plates (which you referred to as filters) are now actually ceramic. Call Vollara customer service (new EcoQuest name) at 800-989-2299. Or go online at https://www.vollara.com/shop/environmental-purity Scroll down to "Full ozone plate single dot." Use dealer referral #16618 if you are no longer in contact with the registered dealer who sold you the machine. You may wish to order several, since I'm sure postage will be high for you.
Make sure you use ammonia/water in a 1/1 ratio to clean the plates, and dry them with air (no towels or cloth.) Do not touch the screen part with your fingers.
Jan 18, 2011 | Ecoquest Breeze AT Living Air Purifier
How do I change out the air filter for the 2200 model? Not sure where to open it up in order to check the air filter and if needed change it out. Thank you.
After you pull out the filter case. There is a tab on the bottom and on the top that holds the ends in undo these.lift out the combs and the filter. Open the new filter and hook it onto the tabs of the filter case and close the ends back up. Get one of the combs in all the cracks of the new filter then slide the next comb in right next to the one that is installed and slide it down to the furthest slot where the combs go. and do this for the rest of the combs until they are all inserted. once they are all in replace the filter case into the cavity be sure to line the slots up on the case and the cabinet and put the door back on.
Jan 03, 2010 | Aprilaire 2200 Air Purifier
Change Filter LIght
take somthing with a small tip, above the light there is a small hole stick it in lol. good luck!!!!!!!!!!!!
Nov 11, 2008 | Honeywell HHT-081 Air Purifier
Screw top stuck
Sit on the top, and pull on the handle very hard. It will pop off, and most likely not break.
Then you will need to take the nut off with some pliers, and glue it back into place.
Most likely some water got into your filter at some point, and it rusted. Making it nearly impossible to screw out. So when you turn the top it spins the nut instead of screwing out. Mostly due to the circular type nut that Honeywell poorly chose.
Oct 29, 2008 | Honeywell Enviracaire 12520 Air Purifier
Flair
You need to order two ceramic plates and a lint filter. The lint filter is the one that goes on the back. The two glass plates are what ionizes the air. They do not make them from glass anymore. You will need to go to the ecoquest website nd order the parts. It will run you right about $75. Ecoquest bought Flair out a few years ago. Hope it helps.
http://www.airpurifierrepair.com/index.aspx?id=38&gclid=CIuXr5H1mJYCFSCcnAod_GOy7A
Jul 24, 2008 | Ecoquest Flair Air Purifier
Sun Aire Sun-Aire Air Purifier - Stainless Steel, Permanent Filter for areas up to 2,000 Sq Feet Air Purifier Logo
360 people viewed this question
Top Sun Aire Air Purifiers Experts
Are you a Sun Aire Air Purifier Expert? Answer questions, earn points and help others
