Question about Cfm Kenstar Turbocool Major Portable Swamp Cooler - 2000 - Cools Over 700 Sq. Ft. Air Conditioner
How could i clean the air cooler, i used have a bad smell when i switch on the cooler fan
  • Cfm Master
  • 8,220 Answers
What you do is remove the hog hair and replace it. Then clean out the pond. Then remove the blower and take it apart, oil the motor and wash the wheel.
Posted on May 04, 2010
Bad smell in cellulose pad
These all smell when new.
Run the unit on high for a few hours and the smell will eventually go... New celdeks smell like wet nappies when fiorst used.... dont panic its normal.
Jun 16, 2011 | Mastercool 67471 Evaporative Cooler Air...
SSR-EP75 Ingersoll Rand SERIAL # F15525U95286 320 CFM i CONTINUE TO ADD OIL GOES OUT ON HIGH AIREND TEMP. SOMEONE TOLD ME THERE WAS AN ADJUSTMENT FOR THIS. CAN YOU TELL ME WHAT TO...
Mike, an EP 75 Should not use more than 3 to 5 parts per million of oil. Your oil issue sounds like you have a separator that needs replacing or a plugged scavenge line. The separator is located in the oil tank. the scavenge line and orifice come from the bottom of the separator filter to and Thur the oil tank lid. then to the air end. In this line approx. 1ft from the lid should be the orifice. make sure its clean. your high air end temp can be from several different problems. 1- low oil level from separator or scavenge line plugged. 2- A plugged oil cooler. Dirt and debris pushed against the cooler by the the cooling fan. This needs to be cleaned using a pressure washer. Wash in the opposite direction of air flow. Be careful with the pressure washer. You can damage the cooler. Low oil level and dirty coolers are the most common problems when getting high air end discharge temp shutdowns. However you could also have a bad thermal valve located where the three cooler lines come together. you will have to remove one line and 4 bolts. inside is the thermal element. You may also have a bad HAT switch (high air end temperature). It is located in the end of the air end and simply unscrews. I do not know of any adjustment.
Feb 12, 2011 | Air Tools & Compressors
The fridge and freezer smell like a dead animal. cleaned the inside with bleach but still smells for weeks. model w10212088
There are two reasons for bad smells. 1. Long time not being used. 2. Lack of cleaning inside compartment.
Solution: Unplug fridge. Keep open fridge door. Dip a dry cloth in soap water and start cleaning each and every compartment. Keep freezer door also open. And then clean with another dry cloth. Keep both doors open for nearly 5 hrs. It will be enable fresh air to **** the smell inside fridge.
After 5 hrs close the fridge and run on empty for one hour. Keep food items after one hour. Please keep all food items closed vessel. Not only it's avoid odor but also be hygienic.
If you use to keep fish items in freezer, clean fridge once in a week.(Spray roo spray in the room when you keep fridge door opened. Don't spray into fridge.)Helpful.
Jan 30, 2011 | Whirlpool Refrigerators
Unit has been operating in a wine closet and just stopped working it there anything I should check or clean? swaney167@aol.com
does the 'closet' have any ventilation? if not the unit could have overheated and shut down or , worse, burned up the motor. any 'electric smell to it? under the unit, should be a fan, it that stopped it will not cool. look for lint build up under the unit or around any air vents. How old is the wine cooler? can you get any info from the Wine cooler's mfg web site? www.danby.com/products/wine__beverages -
Dec 26, 2010 | Danby DWC440 Wine Cooler
Ive got a mildewy smell coming from my evaporative cooler how do i get rid of it?
This unit needs to be serviced. Try replacing the pads with the sponge like pads.Drain the old water and clean up the pan and pump area. Go down to a pool supply store and buy some chlorine tablets and add to the water. In fact, they make these tablets just for the evaporator units. There are 3 states to water, solid, liquid and gas,
. This will get rid of the smell.
Sincerely, shastalaker7
Oct 28, 2009 | Mastercool 67471 Evaporative Cooler Air...
We can only play movies
make sure your fans are coming on. Buy canned air and blow the fans out. Sometimes dust collection will make it overheat because air is not circulating properly.
Jul 20, 2009 | Sony PlayStation 3 40GB System
New Mastercool pads smell bad
The cellulose pads in a mastercool are glued together and usually the adhesive is what you smell. It may take a while for it to go away. Strange as it may seem, as the pads get more mineralization and you use it more the smell will go away. Do not use a cooler for your whole house without plenty of exhaust through a window or an updux. Coolers work best when there is plenty of freely moving air.
May 14, 2009 | Mastercool 67471 Evaporative Cooler Air...
Sunpentown SF-609 Evaporative Air Cooler - no cool air
Sometimes there is a separate switch to turn on the water pump. No water=no cooling. Check to make sure the cooling pads are wet! If they are completely wet and the fan is blowing it should cool.
Jul 06, 2008 | Sunpentown SF-609 Air Cooler Fan
Cfm Kenstar Turbocool Major Portable Swamp Cooler - 2000 - Cools Over 700 Sq. Ft. Air Conditioner Logo
725 people viewed this question
Top Cfm Heating & Cooling Experts
Dan Webster
Dan Webster
David Payne
David Payne
Brett Duxbury
Brett Duxbury
Are you a Cfm Heating and Cooling Expert? Answer questions, earn points and help others
