Question about Sony STR-DG800 Receiver
I have a low frequency hum coming from my STR-DG600 A/V Receiver when it is in standby mode. When I turn the power on the hum goes away.
3 Suggested Answers
remington870
  • 48 Answers
SOURCE: Sony STR-D460Z receiver
I have had this problem several times with Sony receivers in the past. The issue may be frustrating but these receivers are idiot proof. It is doing you a favor by tripping and not setting your house on fire as well.
Explanation:
Many things like improper wire crossing or touching due to too much of the insulation stripped off can cause this. Thunder storms and power surges as well have been known do this to Sony receivers.
Solution:
Unplug the unit and remove the cover. Look for any blown fuses as sometimes this is the problem. Take the fuse to a Radioshack to find new ones. However, it is likely you will need to take it in for repairs. This usually costs around $100. Find a local electronics repair shop in your area ( "TV Reapir in the yellow pages") or call Sony to send it to them.
I hope the latter works.
Posted on Mar 31, 2009
mlapres
  • 757 Answers
SOURCE: My Sony STR-DG600 Receiver constantly goes into Protect Mode when using FM or XM.
Check to see if the antenna is firmly connected and not making contact with the receiver chassis or other inputs/outputs.
Posted on May 09, 2009
Why is there low humming in the receiver sub channel(only?)
Sounds like a shorted capacitor in the sub out circuit.
May 04, 2015 | RCA Audio Players & Recorders
The subwoofer output on my Kenwood VR-606 has suddenly stopped working. I have tried the "setup" several times, turning the subwoofer off and back on. Also, when I first power up the system, it emits a low...
It sounds like the problem is not with your VR-606. If you hear a hum from the sub, the problem is more likely to be in the sub's built-in power amplifier. However, it is worth resetting the amplifier to factory presets. To do this, unplug the power cable from the mains supply and reconnect whilst holding down the power on/standby key. If the hum persists, connect any powered speaker to the sub-out socket, power on and listen for the hum. If no hum then suspect the powered sub amp. Turn the sub on with no connection to the Kenwood VR-606. If hum persists, the sub has a problem and will need to be replaced or repaired. By the way, you said there is a low frequency hum through the 'speakers' for about 30 mins. Is that all speakers or just the sub? Hope this helps.
Cheers, Don.
Jul 06, 2014 | Kenwood VR-606 Receiver
Can not get surround sound to work
Your Protection System probaly come on for some reason,Sony Is Known for that problem, Check on your screen if a red lit warning Staying (protect) Is on.If there is, Try hiting the reciever on the sides or the top of the cover fairly hard when it is turned on, Some times this will work to turn the protect light back off, Sony is bad for there amps end recievers going into the protect mode,
Sep 19, 2012 | Sony STR-DG600 Receiver
My sony str-dh710 constanstantly goesinto protect if the volume goes above 15-20....all connnections to speakers are good.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Apr 27, 2011 | Sony STR-DG600 Receiver
Sony STR-DG600 ticking sound defect bug. There
Replace the IC 1101 with Part No. 6-806-144-01. This Ic will have updated software on board to fix the problem.
Mar 27, 2010 | Sony STR-DE597 Receiver
May 09, 2009 | Sony STR-DG600 Receiver
Receiver goes into protector mode
Nope, power supply it would not even power up.  The capacitors are fried
Jan 04, 2009 | Sony STR-DE635 Receiver
Low frequency humming noise
sounds like you have a bad bearing buddy.
Dec 16, 2008 | 1999 Pontiac Grand Prix
Proper way to hook up a 5.1 speaker system
To make it simple, it is called a receiver simply because it can "receive" signals. Plug your devices into the appropriately assigned and labeled places on the rear of the receiver labled "in."
Dec 05, 2007 | Sony STR-DG600 Receiver
Display dims on certain menu items
The display will dim for certain features that are not available for use in your current configuration or current operation.
For example; if you do not have an antenna plugged in then the selection for the tuner will be dimmed on the display.
Oct 26, 2007 | Sony STR-DG600 Receiver
Sony STR-DG800 Receiver Logo
59 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
