Question about Brother MFC 240C All-In-One InkJet Printer
Brothers MFC-240C not printing in color??? - Brother MFC 240C All-In-One InkJet Printer
  • 903 Answers
Do you have it set to print in black and white as the default? Go into the print driver, under Color Management, and select Color.
Posted on Jun 02, 2010
Can my brothers mfc 240c printer be used to print from more than 1 computer in my house wirelessly? how do I set this up?
The MFC-240C does not have a wireless interface, so you can't connect wirelessly directly to it. What you would have to do is set up a print server, which can be a standalone device or can be one of your computers, and then the other computers would print through that one connected computer.
Jun 26, 2010 | Brother MFC 240C All-In-One InkJet Printer
Need to replace drum kit in a 240c brothers printer
drum unit is part of laser printer and MFC-240C is inkjet printer
parts that you might replace is print head, ink cartridges, ink absorber box
Jun 13, 2010 | Brother MFC 240C All-In-One InkJet Printer
My brothers mfc 240c printer wont print because one ink is not full but it has black
You need to have ink in all cartridges to print. You can put a small electrical tape over the little window on the cartridge to print with empty inks, but you risk an air bubble in the ink tubes. If you don't care about printing color at some time, just cover the window on empty carts.
Apr 20, 2010 | Brother Multi-Function Center MFC-240C...
My mfc-240c won't print red, even with a new cartdrige.
Try running a few cleanings on the color.
Press the ink button and select cleaning,, do about five cleanings. Print the ink quality test page (from the ink button as well) and see the quality if it improved.
If it still doesnt print its possible the ink is clogged and may need servicing to replace the printer head
Apr 06, 2010 | Brother MFC 240C All-In-One InkJet Printer
Hi.. My Brothers MFC-290C printer is printing in pink. I need it to print black
Have you tried to clean the printer heads? usually there is a software application that will offer the ability to clean print heads, align the printer, shows the estimated ink level. This sounds like only one shade of your color head is coming thru.
Brian
Mar 01, 2010 | Brother MFC 240C All-In-One InkJet Printer
Black ink on my Brother MFC-420CN is faint and streaky
You said you replaced the cartridges. Were they Genuine Brothers' Cartridges?
My Brother MFC-240C, does not like Generic Printer Cartridges. That sounds like your problem. Also I had with Brother's was problem with Color. Color that should be Yellow, will turn out Green, or Blue Green, etc. The Generic Cartridges, also printed lines thru the words. That's what the Companies do., so they can keep selling the ink cartridges.
Some Printers, are able to use Generic, but you have to fill them up yourself and I heard, quite MESSY, or Take them to have them filled.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for the PRINTERS.
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Jan 03, 2010 | Brother MFC 420CN All-In-One InkJet...
Cannot print blue/green colors.
I think your cartridge is defective, you need to replace a new cartridge.
May 22, 2009 | Brother MFC 240C All-In-One InkJet Printer
Then your point is i should buy a new set of color cartrages like the 3 colors before the printing should take place then how can i set my brothers printer mfc-240c into black cartrages only no need to buy...
First - read the manual as regards printing. I notice that you can print in Black and White but I cannot find anything to say that you only need the Black ink to do this (therefore I think that I am right in saying that you need the colour cartridges).
Question - Has it worked with only the black ink before now?
As a final solution - Contact Brother direct and check out their FAQ's and/or send them an email asking if you can run the printer with Black ink only installed (I suspect the answer will be no).
If the answer to the above questions comes back as "Yes you can use Black only" (they may tell you how to set this up in which case ignore my next comments), then please supply some more information as regards what happened immediately before it stopped printing. This will help to drill down to the problem.
May 11, 2008 | Brother MFC 240C All-In-One InkJet Printer
Problem with Ink Cartridge
If you only want to print in b/w and do not use the color ones there is a workaround.
Please notice that you will destroy the C/Y/M part of the print head because the ph needs the ink to prevent a dryout!!!
Simply stick some adhesive tape around the window in the middle between the ink-outlet and the valve. The flag inside signals the printer the inklevel (and also the cartridge being installed).
Nov 24, 2007 | Brother MFC 240C All-In-One InkJet Printer
Brother MFC 240C All-In-One InkJet Printer Logo
205 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
