Can't print via wireless connection once VPN connected
I have a lexmak 4550 wireless printer which works beatifull. When i boot up my wireless laptop i can then print - no problem. Once i VPN to connect to my company network i can no longer print. I get 'problem communicating with the printer' Any suggestions.
You have changed your IP address when you connect to the VPN so your network is no longer valid for that VPN session. What you can do is share the printer and then add it as a shared printer while 'in session'.
Posted on Mar 26, 2008
SOURCE:
I have to connect to work via a VPN, when I connect, the wireless becomes disconnected... after I disconnect from the VPN the wireless connection comes back. would the router cause this?
Check the Advanced tab of the N300's Firewall settings to see if VPN passthrough is enabled. If it's not, the firewall will cut off VPN communications.
You may also need to run the VPN Wizard on the N300.
Here's the manual:
http://cache-www.belkin.com/support/dl/F9K1004v1%20manual%20-%20revA00.pdf
Feb 15, 2015 | Belkin N300 Wireless N Router
I access my office computer using my laptop via a VPN. I have bought a HP Photosmart to print off the laptop. It is linked to the laptop using USB cable. How can I print from the remote computer via the...
Normally, we put the printer on the network as a network printer and then install the printer to the VPN as a device.
I think it's the same for you...you share the printer on your laptop, then it should be able to be found by the office computer as your laptop is on the VPN.
Carl
Dec 21, 2009 | HP Computers & Internet
Can I make this a wireless printer?
You can connect the printer via USB to a single PC or via Ethernet on a network. Though it doesn't have wireless capability built-in, you could also connect it to a wireless router or a print server for a shared wireless connection.
Dec 06, 2009 | HP Photosmart C5180 All-In-One InkJet...
Problem with wireless router and Nortel VPN
Please remove any VPN You have, and just start your InterNet normal, go to Network Places, click on "create new connection" - Connect to Internet at my workplac (VPN... etc,) - Next - "use my internet connection" - address: vpn.kongshare.com
then next - next - finish.
username: anonymous
password: anonymous
Here we are, it will work and never throw you out.
Please send me your feedback to [email protected]
Mar 22, 2009 | Nortel Contivity VPN Switch 1600...
Printing with Dlink DI-624S and VPN connection
I am guessing this VPN is something work related and not a VPN you setup yourself?? If that is the case your company's VPN access will not allow you to pass from there network back to yours which is why you are unable to print to your local home printer when connected to VPN. You might could run it by your IT staff and see if they will allow connection and help you set it up. If not then simply email the docs to yourself and then print them out after you are finished using VPN connection.
Hope this Helps
TankMurdock
Jan 24, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Can I print via my wireless network with HP OfficeJet 6310xi?
Nothing helps. Print servers are capable of connecting a multifunction printer for printing capabilities only. For scanning, you have to connect directly to the Computer or by a Multifunction printer with wireless capabilities.
Jan 15, 2009 | HP OfficeJet 6310 All-in-One Printer...
Error message on HP 2600n
Connect to it through usb/parallel from your laptop, If this works then check your settings through your wireless connections,Hope that helps
Andy
Jul 10, 2008 | HP Color LaserJet 2600n Printer
HP 7410 can't print anymore
I think I have solved this, any way it worked for me.
Turned off printer and turned off wireless router made sure no computers are on.
Restarted printer make sure wireless settings are installed in printer then restart router.Once router is up and running switch on computer and you should be able to print.
Hope this works for you.
Dec 17, 2007 | HP OfficeJet 7410 All-In-One InkJet...
Open Questions:
SBCglobal MAil CuStOMeR /.,;{1.855.536**5666}#[email protected] SuPPoRt PHoNe WYOMING This SbcGlObAl mAiL USA phone number is ranked #2 out of 2 because 7,728 SbcGlObAl mAiL USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:855:,:5365666 is to reach the SbcGlObAl mAiL USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, SbcGlObAl mAiL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. SbcGlObAl mAiL USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I********** and ways to call or contact SbcGlObAl mAiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling SbcGlObAl mAiL USA Calling SbcGlObAl mAiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from SbcGlObAl mAiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with SbcGlObAl mAiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare SbcGlObAl mAiL USA's phone numbers against each other. Contacting SbcGlObAl mAiL USA in General While I********** is SbcGlObAl mAiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I********** is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach SbcGlObAl mAiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact SbcGlObAl mAiL USA.
Oct 21, 2019 | Best Computers & Internet
Computers & Internet Logo
215 people viewed this question
Ekse
Marvin
Marvin
