Question about MSI Wind U100-030US Laptop
Startup has 25 second before entering into windows...How do I disarm this?
    President:
  • 524 Answers
Here's the institution on how to decrease the startup time in Windows.
Click on the Start Button from the bottom left corner.
And then choose RUN
Type in MSCONFIG in the text box
Go to the tab STARTUP
Uncheck the program that you know for sure you don't need or won't be using for long time.
Save your changes and restart your computer.
Also Defrag your computer
Navigate to Start Menu > Accessories > System Tools > Disk Defragmenter. Click Defragment now... This can take quite a while so be patient and go eat a bagel or something :) When it's over you're all done. If you're still having serious speed issues at the start up, you may want to consider reformatting your computer.
There are few other things that can help your computer to fast boot up but for this you have to know what you are doing otherwise you could mess up your computer.
  1. ~Disable Startup Services~
    Click on the Services tab at the top. Now, check the "Hide all Microsoft services" box toward the bottom. Disable any services you don't want to start up with windows. Be careful not to disable anti-virus, anti-spyware, and firewall related services. Close the System Configuration menu when you're done.
  2. ~Edit Registry Startup Entries~
    Press the Windows Key + R to open the run dialogue box, type regedit, and hit enter.
Posted on May 04, 2010
  • CIROC TECH SUPPORT
    CIROC TECH SUPPORT May 04, 2010
    - Delete startup entries
    Navigate to :
    HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run and delete unwanted startup programs in the right hand pane of the window. Navigate to HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run and do the same. This is a good way to get rid of stubborn programs that don't have an MSConfig entry.
Bike will not turn over, security icon flashes alone with the turn signals. Battery test OK.
Have you used the new PIN to manually disable the security system?
Do not turn handlebars, straddle seat or lift motorcycle off the jiffy stand. During a PIN disarm, if the security system detects motorcycle motion the system will activate.
Turn ignition to IGN.
If armed, the odometer window display will read: ENTER PIN and the security lamp will be flashing at a fast rate. The headlight will not be on.
Press and release the left turn signal switch.
In the odometer window, a flashing 1 will appear.
Increment the digit by tapping the left turn signal until the odometer window displays the first digit of the PIN.
The first digit in the odometer will be the first digit in the PIN.
Press right turn switch 1 time.
The first digit is stored and the next digit will flash.
Increment the second digit using the left turn switch until the digit reaches the second digit of the PIN.
The second digit in the odometer will be the second digit in the PIN.
The second digit is stored and the next dash will flash.
Increment the third digit using the left turn switch until it reaches the third digit of the PIN.
The third digit in the odometer will be the third digit in the PIN.
The third digit is stored and the next dash will flash.
Increment the fourth digit using the left turn switch until it reaches the fourth digit of the PIN.
The fourth digit in the odometer will be the fourth digit in the PIN.
The fourth digit is stored and the next dash will flash.
Increment the fifth digit using the left turn switch until it reaches the fifth digit of the PIN.
The fifth digit in the odometer will be the fifth digit in the PIN.
The fifth digit is stored. The security system indicator lamp stops blinking.
Smart Security System is disarmed.
If a mistake is made while entering PIN, turn the ignition Switch to OFF before entering the last digit and then start the procedure from the beginning.
If the procedure fails to disarm the security system, wait two minutes before attempting another PIN disarm.
The security system will remain disarmed until the ignition is turned to OFF.
Apr 04, 2014 | 2005 Harley Davidson FLHTCUI Electra Glide...
I HAVE A 2007 HARLEY DAVIDSON CLASSIC SOFTTAIL. SECURITY SYSTEM PROBLEM. I HAVE REPLACED BATTERY & KEY FOB STILL COMPUTER WILL NOT ALLOW ME ENTRY TO DISARM & WILL NOT CRANK. DID STEP BY STEP OWNER...
If you do not know the security code, you can reset it to your own choosing.
With the fob present, turn IGN switch:
IGNITION-OFF-IGNITION-OFF-IGNITION
Press LEFT turn signal switch 3 TIMES
Press RIGHT turn signal switch 1 TIME and release
Turn signals will flash 3 times. Current PIN will appear in odometer. The first digit will be flashing.
If changing PIN, enter first digit (a) of new PIN by pressing LEFT signal switch (a) time(s) i.e., for the number 1, press one time. for the number 5, press 5 times.
Press RIGHT signal switch 1 TIME and release.
the new digit (a) will replace the current in odometer window.
Enter second digit (b) with LEFT signal switch.
Repeat until PIN is set.
Once PIN is set (either new or old PIN), to disarm security system, DO NOT sit on seat, lift bike off kick stand, or anything else that will activate the security mode!
Turn IGN to IGNITION.
Quickly (within 2 seconds) hold BOTH turn signal switches until confirmation signal (KEY icon flashes at fast rate, in odometer window, a flashing "-" will be followed by 4 more dashes = "----")
Enter 1st digit (a) in PIN by pressing LEFT turn signal switch (a) times (i.e., 5 times for the number 5)
The 1st "-" will become the 1st digit (i.e., "5")
Press RIGHT switch signal 1 TIME.
The 1st digit is stored and the dash will flash.
Enter 2nd digit (b), and repeat sequence until done.
After the 5th digit is entered, the KEY icon stops blinking, and the system is disarmed.
The system will stay off until the IGN switch is turned off.
If at any time during disarming sequence an error is made, wait 2 minutes before trying again.
Feb 28, 2013 | 2007 Harley Davidson FXSTC Softail Custom
Doesn't enable virtualization
To determine whether your PC supports hardware virtualization:
Step 1. Does my PC have a CPU with support for hardware virtualization?
Download and run the Hardware-Assisted Virtualization Detection Tool
If you receive the message This computer does not have hardware-assisted virtualization, your computer does not meet the hardware requirement for Windows Virtual PC, but you can still use Windows 7 XP Mode by running this hotfix. Be aware that XP Mode will run much better if hardware-assisted virtualization can be enabled.
If you receive the message Hardware-assisted virtualization is not enabled on this computer, go on to Step 2 below.
If you receive the message This computer is configured with hardware-assisted virtualization, download and install Windows Virtual PC and Windows XP Mode.
Step 2. Does my PC BIOS support hardware virtualization, and is it turned on?
Instructions to turn on hardware virtualization in your PC BIOS are specific to OEM models. It is important that after changing your BIOS settings the PC is completely shut down at the power switch before restarting so that the new BIOS settings can take place.
Examples for some models of some computer manufacturer's BIOS settings are below:
Sample instructions for your PC
Expand all
Dell systems
Depress the F12 key when boot menu text appears at startup
Select BIOS setup and depress the Enter key
Using the mouse, expand the Virtualization Support menu item by clicking on the plus to the left of Virtualization Support and select Virtualization
Check the Enable Intel Virtualization Technology checkbox
Click Apply
Click Exit
Fully shut down (power off), wait a few seconds, and restart your computer
HP systems
Depress Esc key when prompted at startup
Depress the F10 key to Configure BIOS
Scroll to System Configuration using the arrow keys
Select Virtualization Technology and depress the Enter key
Select Enabled and depress the Enter key
Depress the F10 key to save and exit
Select Yes and depress the Enter key
Lenovo ThinkPad systems
Depress the blue ThinkVantage key when prompted at startup
Depress the F1 key to enter the BIOS setup utility
Using the arrow keys, scroll to Config and depress the Enter key
Scroll to CPU and depress the Enter key
Scroll to Intel Virtualization Technology and depress the Enter key
Depress Enter key to continue
Depress F10 key to save and exit
Acer
PCs capable of supporting Windows XP Mode have already been enabled and do not require additional configuration.
Asus
Samsung
Panasonic
Depress the F2 key when boot menu text appears at startup
Select Advanced menu in Setup Utility
Change "Intel Virtualization Technology" setting from Disable to Enable
Depress F10 to exit Setup Utility
Select Yes in confirmation menu
Depress Enter to exit confirmation menu.
Please note the instructions above may not work in all cases and consulting with your computer manufacturer may be necessary. Additionally, we expect hardware virtualization to become more available when Windows 7 is shipped, particularly in business-class PCs. For those PCs that come pre-installed with Windows XP Mode we recommend the computer manufacturer turn on hardware virtualization before shipping the PC.
Once you have confirmed your PC supports hardware virtualization
Download and install Windows Virtual PC and Windows XP Mode
hope this helps
Aug 08, 2012 | Computers & Internet
Lost key fob how to turn off alarm?
You'll need the PIN number.
If you don't know it, you'll have to change it to a 5 digit PIN number you select.
Nov 06, 2011 | 2008 Harley Davidson FLHR Road king
Black screen, Blinking cursor for 25-30 seconds after HP logo at cold boot.Restarting PC does not add this extra step before windows startup screen. Booting from power off condition has this condition...
AS YOU ON THE SYSTEM AND EVEN BEFORE WINDOWS STARTS KEEP PRESSING THE F8 KEY CONTINUEOUSLY. A MENU WILL APPEAR. SELECT SAFE MODE AND ENTER. WINDOWS WILL LOAD IN SAFE MODE. THIS WILL SOLVE SOME OF YOUR PROBLEMS. NOW RESTART THE SYSTEM IN NORMAL MODE.
IF THIS DOES NOT WORK SELECT "LOAD WINDOWS WITH LAST KNOWN GOOD CONFIGURATION " AND THEN RESTART. THIS WILL SURELY SORT OUT YOUR PROBLEM.
PLS REPLY OR COMMENT. THANKS
May 02, 2011 | HEWLETT-PACKARD Hewlett Packard HP ENVY...
I have a viper alarm on my car that wont shut off nor i cant start the car..and i have tried the button under my dash, how Can i shut it off??
was it a professional or shade tree install? the following is off vipers website:
disarming without a remote control
This feature allows you to disarm the security system without the
Remote Control should it be lost, damaged, or disabled. In order to
disarm the system without a remote remote control, you must have
the vehicle’s ignition key and know where the Valet button is
located. Be sure to check with the installer for the location and the
number of presses of the Valet button required to disarm the system.
To disarm the security system,
turn the ignition to the ON position.
Press the Valet button the
preset number of times (one to
five times) within 15 seconds. After five seconds the system will
disarm. If the system does not disarm, you may have waited too long;
turn the ignition off and on and try again.
if that doesn't work try this other
valet mode
You can prevent your security system from automatically arming
and triggering by using Valet Mode. This is very useful when
washing the vehicle or having it serviced. In Valet Mode, the
security system will not arm, even with the Remote Control, but
all convenience functions (door locks, trunk release, etc.) will
continue to work normally.
To enter or exit Valet Mode:
1. Turn the ignition on.
2. Turn the ignition off.
3. Press and release the Valet
button within 10 seconds.
The status LED will light solidly if you are entering Valet Mode,
and it will go out if you are exiting Valet Mode.
May 08, 2010 | 1994 Honda Civic
Boot mgr Is missing on a tobisha laptop
Method 1:
Use the following procedure to repair the file system on the hard drive:
  1. Turn off the computer and wait at least 5 seconds with the computer in a full off state.
  2. Turn on the computer and press the F8 key repeatedly as the computer starts. An "Advanced Boot Options" screen opens.
  3. Select Repair Your Computer and press Enter.
  4. Select a keyboard layout that matches your country/region and click Next.
  5. When the login prompt appears, select the user name with Administrator rights (not Administrator) from the User Name drop down. The user name with Admistrator rights is most likely the first user name that was entered during the initial computer setup.
  6. Type the logon password into the Password field and then click OK.
  7. A System Recovery Options window opens.
  8. Click Startup Repair.
A Startup Repair window opens and automatically scans for startup problems.
  1. Perform the actions suggested by Startup Repair: system restore, correct damaged or missing files, or other action.
  2. After Startup Repair has been used, try to open Windows.
    • If Windows Vista opens, you are done.
    • If Windows Vista does not open, perform the first portion of this section again to open the Startup Recovery Options window and continue.
  3. From the Starup Recovery Options window, click Command Prompt.
  1. Enter the following at the command prompt:
bootrec /fixboot
bootrec /fixmbr
  1. After the bootrec tool has been used, close all open Windows to restart the computer and open Windows.
    • If Windows Vista does not open, continue using these steps.
  2. Perform a full system recovery using recovery discs. For more information refer to the HP support document Performing an HP System Recovery in Windows Vista .
If the recovery cannot be completed from recovery discs, replace the hard drive.
Sep 13, 2009 | IBM ThinkPad T43 Notebook
Security system FOB inactive, battery good, no pin. Need to disarm. What can we try next?
Sep 05, 2009 | Harley Davidson FLSTFI Fat Boy Motorcycles
Computer beeps and won't startup
try to open your cpu, and fix some hardware inside, maybe theres something lose there like video card or your RAM, i encountered also that problem. try to do this.maybe it can help.
Jan 21, 2009 | Computers & Internet
Telko s002 manual
Nesecito manual programming! s008b of Telkes. Thank you now!
Sep 12, 2007 | RCA 25110RE3 Phone
MSI Wind U100-030US Laptop Logo
131 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
