Question about Toshiba Satellite Pro A200-EZ2204X Notebook
Toshiba Satellite Pro A200. Screen has gone very dim. I can attach an external monitor and everything seems to work fine. Have tried increasing brightness but it has no effect. Is this something that can be fixed? Please help!
    Sergeant:
    Champion:
  • 452 Answers
Most likely the backlight gone bad. It could also be the inverter. but try the backlight first, it's cheaper and easier.
Posted on May 04, 2010
After changing the converter on satellite M305D-S4830 the backlight still very dim
i'm sure you ment inverter..if its working on external screen? it would seem. that you still need it replaced have u checked the ribbon cables?
Nov 23, 2013 | Toshiba Satellite M305D-S4830 Notebook
Toshiba satellite pro A200 board dosn't display
In that case it is The Video Graphics Card near the processor ic. Have you tested it with a external monitor? that will prove if the chip is good or bad.
Apr 11, 2012 | Toshiba Satellite Pro A200-EZ2205X...
Toshiba Laptop A200-AH5. My computer seems dead and there is only the blue (I think battery light) light that is on. Nothing else works. I hope my laptop didnt crash? Please help me.
Most likely the problem is related to the board. Also most likely the light you are seeing is the power light. Do you get any blinking lights? Try also an external monitor and see if that works.
Apr 14, 2011 | Toshiba Satellite A200 AH5 (4400 mAh)
Hello, What cable or adaptor do I need to transfer all data from the hard disk of my Toshiba Satellite Pro A200 to my new laptop via USB port? Thanks.
You won't be able to transfer hard drive data by plugging one computer into another via USB. In order to transfer data, you will need to remove the hard drive from the Toshiba Satellite Pro, use an external hard drive enclosure, and attach that to your new computer with any USB cable.
The hard drive can be taken out by removing screws on the bottom of your laptop. The drive can be found in the bottom left of this picture: http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/big/toshiba-satellite-a200-a205-02.jpg
Here is an example of the exclosure you would need: http://www.newegg.com/Product/Product.aspx?Item=N82E16817816013
Mar 14, 2011 | Computers & Internet
Hi< I have an a200 sattalit pro and I have
use external mouse instead or any wireless device..
Mar 02, 2010 | Toshiba Satellite Pro A200-EZ2204X...
My Toshiba Satellite Pro A200 works fine if I use a battery charged on an identical machine, with the same mains charger. With the mains charger plugged in it either shows 'plugged in not charging' or...
It sounds like the connector from the A/C adapter to the motherboard is loose or the inside of the adapter plug that attaches to the motherboard is defective.
Jan 08, 2010 | Toshiba Satellite Pro A200-EZ2204X...
Laptop screen is damaged
you can continue using your external display or purchase a new screen and install it . check out this site for good step by step instructions, just find your model. Good luck to ya
Jun 11, 2009 | Toshiba Satellite Pro A200-EZ2204X...
Toshiba Satellite Pro A200 prob after Antivirus 360 trojan remove
it seems that some files are still there and it is not allowing IE to work properly.
try to install Firefox, opera or avant browser and try to browse.
or in other case try to ping from command prompt
and check the IE properties.
hope it will help you
Mar 24, 2009 | Toshiba Satellite Pro A200-EZ2204X...
Screen stays black on startup of toshiba satellite L300
have you tried either switching between external and internal monitor usally Fn + F5 on toshiba or try plugging a monitor into the back and see if it displays.
if you get a display on the external monitor then its probably a screen or inverter fault if you donot get a display to an external screen then it is likley t be the graphics on the board itself.
hope this helps
Feb 22, 2009 | Toshiba Satellite Pro L300-EZ1501 Notebook
Toshiba Satellite Pro A200-EZ2204X Notebook Logo
338 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
