Question about U-Line Icemaker
Model No ULN-CLR-60B-00. My ice maker makes ice and dumps two or three times and then there is a sheet of ice forming on top of the blocks and it won't dump again.I have changed the control board and the thermostat as recommended by the technician but no luck. Can you advise?
    President:
  • 1,554 Answers
The sheet of ice is forming on top of the blocks because the amount of water being supplied to the ice maker is exceeding the maximum level to avoid this issue. Ice forms between the blocks and connect them together as a big block. Either replace the water inlet valve supplying the ice maker or adjust the water supply valve in such a way that only correct amount of water is supplied to the ice maker.
Posted on May 04, 2010
Water collecting in the water compartment
what is question as well as make ,model of unit
Nov 13, 2016 | Refrigerators
Top ice maker in Samsung RFG298AAPN does not make ice. No water cycles into icemaker. Icemaker has been reset, nothing after 2 days. Should I replace the icemaker or the water valve.
On these models I've noticed that the temperature in the ice maker area warms up due to a ball of ice forming inside the freezer compartment ice maker fan that has vent going to the ice maker. Until it is found whether or not that ball of ice is blocking the vent and fan you won't be able to go to the next step. The switch on the ice maker will test the ice maker by filling it with water and rotating the Forks that dump the ice into the ice bin Appliance 911 Sea Breeze
Aug 31, 2016 | Samsung Refrigerators
My uline keeps running and soda in cans freeze. Thermostat setting is at lowest but I also tried midway. Model ULN-CO75FWH-00
your thermostat is bloked or didn't see the reeal temperature, it must be replaced whit similar new one.
Feb 21, 2010 | U-Line Uline Origins Series...
Ice maker will not harvest
As crazy as this sounds, turn the temp control a little warmer (counter clockwise). On this model, this control needs to switch to harvest the ice. A warmer setting should fix this issue.
Dean
You can also go to:
www.u-lineservice.com
Jun 05, 2009 | U-Line Refrigerator Ice Maker
U-line model ulr-60b
hi,
periodical clean can smooth the operation of your ice maker.
at this link you can have the ice maker cleaning guidelines:
http://lib.store.yahoo.net/lib/usappliance/echelon-icemaker-manual.pdf
Sep 09, 2008 | U-Line Refrigerator Ice Maker
NO POWER GETTING TO UNIT
realized that there was nothing wrong with the unit....It is suposed to drain out water when running and need to jump start it...so alls good thanks for getting back to us...now were chilling.E.Bates
Jul 07, 2008 | U-Line Icemaker
U-Line Model ULN-CLR60B-00
call 1-800-779-2547, U-Line's tech support.
Has to be a bad a switch, wiring issue or maybe a control board. pull the service cover and see if the red light is lit on the board (or flashing). Light on (no flashing) indicates the board is powered up and no errors are occurring.
http://www.u-lineservice.com
Jun 09, 2008 | U-Line Icemaker
U-Line Icemaker Logo
151 people viewed this question
Top U-Line Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
