Question about Honeywell HY-048BP Tower Fan
Setting the timer
I cannot figure out how to set the time and how to get the temperature on the read out to stay at 74 degrees.
  • 22 Answers
SOURCE: cannot set heat setting by using "hold" feature
make sure it is not telling you room temp, some of the Honeywells, will display room temp over desired temp. check that, if it wont let you switch temp than buy a new one, if you dont have a heat pump a new cheap stat is around 20.00.
Posted on Jan 02, 2009
  • 56 Answers
SOURCE: thermostat does not follow the setting
If the thermostat is a digital /programmable you may want to recheck program to see if it has changed or been changed. If thermostat is not digital then it is prbably warn out and need replaced.
Posted on Feb 16, 2009
jmgldsmth
  • 1869 Answers
SOURCE: Our TH8000 just recently has started reading 80
Nothing is wrong; the air circulation in the room affects the thermosistor slightly in your thermostat, so does shade/heat etc.
Posted on Jun 12, 2009
  • 252 Answers
SOURCE: On our honeywell trolatemp universal minizone zone
sounds like a furnace problem - the zone control sounds right
Posted on Oct 08, 2009
  • 767 Answers
SOURCE: the thermostats current setting does not match the
Sounds like you have a problem with the furnace try turning the power off to the furnace and then turn it back on to see if this will get it to run. If it has a sight hole in the bottom door look to see if there is a flash code. then take off door and see what the flash code represents as the problem.
Posted on Dec 17, 2009
How do you set a hager eh010 timer
switch the timer off or disconnect
turn the thermostat setting to low
that way it will not work when the solar section is producing enough hot water and when the temperature in the hot water system falls below the thermostat setting it will switch on the power
usable hot water temperature is around 60 degrees c and anything over that will scald the skin within minutes
low thermostat setting is 55 -65 degrees c
Aug 06, 2016 | Solar Hardware & Accessories
Set thermostat at 74 heat pump will not cycle it will cycle at 75 degrees ?
check stat calibration. see if you can measure temperture at stat. the thermostat cover temperture reading is not that accurate.
Jun 01, 2014 | Goodman CLQ36AR49 Air Conditioner
Fridge not cold enough
The higher the number the colder the temp is supposed to be.
In order to prevent the formation of bacteria and other such organisms to affect food the way it does, the ideal temperature range of refrigerators has been mentioned here. Before we look at these settings, it is important to know the format in which temperatures are represented within a refrigerator. Commonly, you will notice a dial representing the figures 1-5 or 1-9 in the refrigerator, and a dial representing the letters A-E in the freezer. The ideal setting is usually in the middle of such figures.
If the dial is in such a format in your refrigerator, try a setting at 3 if the range is 1-5, and at 4 if the range is 1-9. For the freezer, a setting at C is suitable.
The ideal temperature in the refrigerator ranges between 34 degrees F - 38 degrees F or 1 degrees C - 3 degrees C. So that foods such as vegetables and fruits remain fresh and crisp, the temperature may be set around 38 degrees F or 3 degrees C.
The ideal temperature in the freezer ranges around 0 degrees F (-18 degrees C) or lower.
Read more at Buzzle: http://www.buzzle.com/articles/refrigerator-temperature-settings.html
Mar 05, 2014 | Belling Refrigerators
Where do I set thermostat when temp is 10 degrees outside?
Setting a thermostat has nothing to do with outdoor temperature, but more to do with what is a comfortable setting for you and your utility bill.
A common misconception associated with thermostats is that a furnace works harder than normal to warm the space back to a comfortable temperature after the thermostat has been set back, resulting in little or no savings. This misconception has been dispelled by years of research and numerous studies. The fuel required to reheat a building to a comfortable temperature is roughly equal to the fuel saved as the building drops to the lower temperature. You save fuel between the time that the temperature stabilizes at the lower level and the next time heat is needed. So, the longer your house remains at the lower temperature, the more energy you save.
Another misconception is that the higher you raise a thermostat, the more heat the furnace will put out, or that the house will warm up faster if the thermostat is raised higher. Furnaces put out the same amount of heat no matter how high the thermostat is set; the variable is how long it must stay on to reach the set temperature.
In the winter, significant savings can be obtained by manually or automatically reducing your thermostat's temperature setting for as little as four hours per day. These savings can be attributed to a building's heat loss in the winter, which depends greatly on the difference between the inside and outside temperatures. For example, if you set the temperature back on your thermostat for an entire night, your energy savings will be substantial. By turning your thermostat back 10 to 15 degrees for 8 hours, you can save about 5 to 15 percent a year on your heating bill -- a savings of as much as 1 percent for each degree if the setback period is eight hours long.
Hope this helps..........
Nov 23, 2010 | Goodman GMS90703BXA Heater
I dont know how to turn the heat on in my 2002 grand marquis
Try setting the climate control to "Automatic," then raise the temperature until the display reads what you want, like 72 or 74 degrees. The heat will come on automatically and adjust by itself when the temperature you set is reached. You can also push the "Floor" or :Defrost" button and this will turn the heat or defrost on manually.
Nov 10, 2010 | 2002 Mercury Grand Marquis
Max temperature for Rinnai 556WT restricted to 74 degrees
There is no way to restrict the setting and keep it UL approved. If you cannot get the heater above a certain setting you have either too small of a heater, too much outside air entering the apartment or the gas pressures are not great enough.
Oct 25, 2008 | Rinnai RHFE-556WTA Direct Vent Heater NG...
My central ac system occasionally runs too long and the temperature gets way too cold. The digital thermostat reads that the temperature is too high so the ac still runs. This doesn't happen all the time...
I have seen this is many digital thermostats. The worst problems usually come from the touchscreen thermostats. I would suggest installing a new thermostat. Make sure that you read the instructions before you even remove the old one.
Jul 03, 2008 | Heating & Cooling
Need cold air
I had the same problem...and I accidentally discovered the solution...
One thing you have to remember is that the temperature that is shown on the screen is actually the room temperature and not the "wind" temperature.
To set the "wind" temperature, press the "m" button (aka temp/timer) once...it should show a flashing thermostat and the temperature screen changes to show the default "wind" temperature (it's 74 degrees)...
Next use the "down" button to the right of the screen to reduce the wind temperature to the desired temperature and that's all you have to do. IMPORTANT: if you wish to increase or decrease the temperature of the "wind" you just use the "up" or "down" button; DO NOT HIT "m" again since if you hit "m" again, it will cycle through the "timer" and then "temp" again, and it will reset the "wind" temperature to the default 74 degrees.
May 11, 2008 | Honeywell HY-048BP Tower Fan
TEMPERATURE ADJUSTMENT
Jun 10, 2007 | Honeywell 40 In. Oscillating Tower Fan...
Honeywell HY-048BP Tower Fan Logo
13 people viewed this question
Top Honeywell Dryers Experts
Jay Finke
Jay Finke
richie46
Steve
Level 1 Expert
Are you a Honeywell Dryer Expert? Answer questions, earn points and help others
