Click this link: http://www.tp-link.com/en/products/details/?model=TL-WN321G#down download the correct software and drivers from the TP Link support page for your WLAN adaptor, also this adaptor is also compatible with windows 7, you may just need the correct drivers. Which i have linked you to. Goodluck
You will have to open up your network connections Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark!? you will need to update or install the driver or it could be firewalled. Make sure your antivirus program is not blocking the internet connection. If you are trying to connect through a modem/router you it should have come with a disk then you might have to connect the usb lead to your modem to get a connection then Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamationmark! or a red Xright click install drivers. The driver might be on the disc supplied by your ISP internet service provider or the motherboard disc You only need to check the BIOS if you cant install the driver
Make sure you Ethernet/internet is enabled in biosrestart your computer during the boot up process you will see on your screen a certain key to
press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigateto integrated peripheralslook for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its "Enabled"
Hi! Yes you can download it online, just type cd installer tl-wn321g free download er. Just select among those choices. Check which of them will work on your computer. Compatibility check.
Hi.. this is for the question "i need the drivers for the panasonic Pv-dv851d"..... here is the link to answer your question,,, you can also download the manual for any further questions...
Hi, after looking at the manufacturer's site, I didn't see a download for a specific driver for the pv gs15. However, you might try to run a free scan here for Panasonic drivers and see if it has the driver you are looking for. Good luck, hope this helps!
Hi, I managed to down load mine by connecting with a firewire and setting the camera to playback mode (not PC), opening imovie, turning the camcorder on and selecting file -' import from camera". a screen came up then I started playback on the camcorder and was able to select import from the screen on the imac.
