Question about Belkin Wireless G Plus MIMO (F5D9010)
I have belkin g plus router and dont want people steal my interent usage how do i stop others from usen my interent also what do i do if i only want others in my house to use our interent
    Sergeant:
  • 166 Answers
To make sure your interenet is secure on a wireless router, consult your owners manual for the device (you can also download the PDF from belkin.com support page if you need.)
You will need to log into the router setup from a connected computer, and in the setup either set a WEP or WPA key. Once set you simply go to your wirless and choose connect to the router and enter the key, make sure you check the box to save the key and then you should be good.
BE SURE to write the key down somewhere for your reference so you don't have to keep changing it if something gets changed on one of the computers.
Posted on May 04, 2010
Where is the administration located?
You need to encrypt your wireless router.
Connect a LAN cable from Belkin to your laptop/computer's LAN port, open a browser on your laptop/computer and enter the Belkin's configuration URL. http://192.168.2.1
The default PW = blank (just press Enter) You can now change the default admin password.
You can now configure the wireless settings to protect your wireless network and Internet from unauthorized access. Now configure the wireless card in your computer/laptop with the router's wireless settings. To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Jan 22, 2013 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I am using a Belkin Wireless G Plus Router connected to my Virgin cable. I have had no problems with the router for 3 years however in the last month it stops working. To reconnect it needs powered off and...
From your explanation what i got is the router is not working and needs to be rebooted to start working. There is no changes done into the configuration.
In this case i suspect some software bug in the router.
I will recomend to backup your configuration and then reset once the router.
Remember if you reset the router the router will go to factory default settings and will loose all the configuration. you need to reconfigure that from the configuration backup you have taken recently.
Oct 31, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
How do i block someone from illegally stealing my wireless intern
You have two options to stop someone from stealing your wireles connection.
The first is to use a more secure encryption.
Use WPA2 personnal with AES encryption.
You can set this security mode by logging on to your router and changinhg the wireless security.
The next solution is to turn on MAC filtering and make sure her computer is not listed as a safe MAC address.
This is also turned on from the router.
Hope this helps.
Thanks,
Pat
Apr 26, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
How to put a password on Belkin GPlus Mimo 180170
you log on to the router usually an address like 192.222.222.2 etc should be in your manual and go into security then you will have an option to create a password. once this is done you will then need to re connect to your router and put the password in.go on to control panel then network connections.
Jan 19, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
The interent will work for everything for a day but...
Hello, Bobby.
Either your router or the service to your router is a problem.
Contact your provider for testing. You may need a new router.
Hope this helps.
Dec 13, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin wireless stopped working.
Well you can try to contact to belkin tech support and ask for online assitance hope they will fix your problem and you will be good to go.
Nov 10, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Wireless router
first connect the devices in this way
from us inter net modem to belkin routers inter net port connect a ether net cable rj45-->then connect another ether net cable rj45 from pc to -->ethernet port on teh belkin router>and reboot the router and modem if u r using cable inter net then immediatly that will work>and open a browser window type this in address bar http://192.168.2.1 u can see the belkin login screen and follow this link
http://www.gorge.net/help/wizard/belkin/f5d7230-4_pppoe.htm
rate me solved if its helps
Nov 18, 2007 | Gateway Belkin 54g Wireless DSL/Cable...
My Belkin Wireless G Plus MIMO Router has intermitint connection with the wired computer
the inter net light should blinks dont worry>
delete all teh temp cookies and files and clear history>and change the ether net cable
change the dns to global like
start-->control panel-->network conn-->right click on local area conn-->click on properties-->and highlight tcp/ip-->click on properties-->and select use the current following dns
type
DNS 1) 4.2.2.1
DNS 2) 4.2.2.2
click ok>and restart the pc and rate me solved if its help full thx
Oct 30, 2007 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Help
Replace the router.
Aug 04, 2007 | Belkin (F5D7231UK4) Wireless Router
Computers & Internet Logo
54 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
