Question about Eureka 2904AZ Maxima Upright Vacuum
I have Eureka 2904AZ. Need Manual and attachments
I have Eureka 2904AZ. Do you have a manual? What is the part number for a wand and crevice tool?
  • 10865 Answers
SOURCE: Need user/owners manual for Eureka Whirlwind Big Cup model 4686
hello chris. here is the link to use to get your downloadable manual
http://www.eureka.com/owners_guide.jsp
Posted on Jun 19, 2009
Agent Don
  • 310 Answers
SOURCE: no power in power nozzle
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19674&thid=493359
No power in power nozzle
Posted by pjs5451 on Apr 06, 2008
Vacuumed with power nozzle one day working fine took attachment off to use crevice tool reattached power nozzle and no power whatsoever.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Rainbow E Series Canister Wet/Dry Vacuum. The Rainbow Power Nozzle does have a reset button on the newer model on the top of the power nozzle, just push it and it should reset, or check all your pigtail connections to make sure they are connection and the cord leading to the actual Rainbow Vacuum itself. Out in left field might be that the power nozzle motor could be shorting out or not working or dead and might be in need of replacement. Check the cord for any frays or bad connections. If you have a problem please feel free to contact your local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
The Rainbow / RexAir Factory phone number is listed below:
http://rainbowvacuum.com Customer Service
1-248-643-7222 Monday thru Friday from 9:00 am to 5:00 pm EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 12, 2008
SOURCE: No suction for use of crevice tools, running hot, then shut off
Obviously no suction in hose would indicate a blockage, over heating is a breaker that shuts off the machine when it over heats. There is no way to clean hose the on this model because the hose does not detach at either end, therefore I had to employ the use of the good old wire hangar. Job complete up and running, with good suction. It is amazing what a prayer to God can do.
Posted on Nov 20, 2008
  • 52 Answers
SOURCE: Need manual for Eureka Powerline Plus Model 9730
Maybe you have already solved the problem this late in the game. Manuals for Eureka products can be found on http://www.eureka.com. Your local hardware store will have a bunch of different sizes of plastic caps in the plumbing section normally used for capping pvc tubing. If the outlet is round like an upright I had a few years ago you can pop one of these on and it'll do the trick. The cap shouldn't be more than a dollar or two, plus if you ever do want to use the tools again you didn't do any permanent damage to the port. Hope this helps!
Posted on Feb 11, 2010
  • 4 Answers
I found it at www.vacpartswarehouse.com for $4.79 + sh
Posted on Dec 23, 2012
Eureka True Clean vacuum cleaner manual
Contact Eureka local dealer , or go to Eyreka Website , for info.
Mar 16, 2015 | Eureka Vacuums
How to put on attachments
Hi there, it's Jack at Dyson.
DC14 includes a Stair tool, Dusting brush and a Crevice tool. These are push-fit parts and will attach either to the end of the wand when additional reach is needed, or into the hose cuff for cleaning in confined spaces.
I hope this helps, but if you need further information you're welcome to call us directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Sep 03, 2014 | Dyson DC14 FS Telescope Full Kit HEPA...
Remove handle from hose electrolux
You don't have to "remove" the handle from the hose to attach other attachments, just depress the tab at the end of the hose and pull the upper wand loose then use the "adapter" to use the dusting brush or simply snap the crevice tool in place to use. If the handle won't come loose from the upper wand, then the described "tab" needs replaced as it's locking up the parts. Hope that helps!
May 17, 2014 | Electrolux Vacuums
How to attach crevice tool
Hi! Below is step-by-step instructions for attaching your crevice tool.
1. Place unit in an upright position. Push release button forward, then pull handle from unit.
2. Remove floor tool from nozzle.
3. Attach crevice tool by inserting into nozzle. To remove gently pull apart.
Hope this helps out!
Apr 26, 2014 | Dirt Devil Simpli-Stik 3-in-1 Bagless...
How do i get something unstuck from the suction tube on ambassador
I assume you're referring to the tube in the power nozzle. Unless you're acquainted with taking the pn apart and putting it back together properly, don't try.
Disconnect wand from pn, get a pair of needle-nose or long nose pliers, and try to reach the "something". Do so gently so as to not poke hole/s in tube.
You can also attach the hose to the exhaust port of the vacuum, attach the crevice tool, and attempt to blow out the clog.
Aug 25, 2010 | Electrolux Vacuums
Is there a floor attachment that will fit my extention wand?
There is a Bissell Tool Dust Upholstery combo part # 2031099 or you can purchase a crevice tool part number # 2031063.
There is also a floor tool that goes to a different model, but it should fit if the diameter is the same it is part number B-2032081
You can find them here (use the search field to find the floor tool by part number)
http://www.usavacuum.com/category-s/314.htm
Feb 22, 2010 | Bissell 6594 PowerForce Bagless Upright...
Electrolux Home Care 60E 6-Piece Deluxe Tool Set
The Eureka part # 60F for the tools ( hose, wands, converter, & attachments). It runs about $20.00.
Nov 20, 2009 | Eureka 1934 Bagged Upright Vacuum
The attachment that holds the Dyson crevic tool broke. What part do I order to replace it?
You need to replace the wand. To find the wand appropriate to your machine, visit http://www.espares.co.uk/dyson/dc04/p/1086/716/4
Aug 10, 2009 | Dyson DC14 Bagless Upright Cyclonic Vacuum
Eureka 2904AZ Maxima Upright Vacuum Logo
114 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Alan Matzke
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
