Question about Acer Aspire One Netbook 8.9" Notebook
Mouse will not double click to open, or right click to save etc
    Scholar:
  • 63 Answers
Hi Verify first whether your system is affected by "TROJAN" or any other viruses
If "YES" Remove the smae by using "ANTIVIRUS" S/W (Preferably AVG !!)
Go to C:\Windows (O.K how to open C or C:\Windows is your questions ..Correct !! MAy be try to right click and use open with option..and select C:\Windows\Explorer.exe OR system may open show openwith window..click on browse and select c:\windows\explorer.exe)
Open REGEDIT file
Find "MOUNTPOINTS2" using Ctrl + F
Delete the same
Repeat the process unless all the "MOUNTPOINTS2" are deleted.
I hope this will solve your mouse problems.
If not, try this method too
Open up regedit.exe by using Start\Run and then browse down to this registry key:
HKEY_CLASSES_ROOT\Directory\shell
Double-click on the default value and set it to “none” without the quotes, as seen here:
This will restore the normal behavior.
Hope it solved your problems...!! Thanks.
Posted on May 04, 2010
Differences between right click and double click
In Windows based system, the double click (of the left mouse button) selects an icon and send the run or execute command. The right click (of the right mouse button) opens up contextual menu options, i.e. menu options that are related to what you are doing on the windows that has the focus.: if it is a disk it may offer you the choice to explore, format, erase. For an executable file it might offer you to run it, or to delete it, etc.
Oct 23, 2013 | Nikon COOLPRINT Thermal Printer
Windows run doesn't keep my work history
you have to physically save any work
save the history to a usb drive in case you have computer failure
Plug the flash drive into your computer's rectangular-shaped USB drive.
Wait for Windows to recognize the system.
Windows operating systems use "plug and play" technology, which means that computer peripherals like USB flash drives can be recognized instantly by the system without further need for device configuration.
Open the drive on your computer.
Open the "My Computer" directory if using Windows XP or the "Computer" directory if using
Windows 7 or Vista. Locate the flash drive letter and icon under the section named "Devices with Removable Storage." Double-click the flash drive icon to open it.
Transfer files to the flash drive.
Click the "Restore" button in the top-right corner of the "Computer" or "My Computer" directory to shrink the window so that you can view your computer's desktop background.
Open the folders or locations of the files which you want to save to the flash drive.
Click and drag with your mouse each of the files and folders you want to save to the flash drive over to the empty space in the "My Computer" or "Computer" window.
Release the mouse button to let the files "drop."
Close the windows and directory locations when finished.
Save files directly onto the flash drive. From an open file (i.e. text, spreadsheet, image files. etc.), click the "File" menu and "Save as" option.
Select the "My Computer" or "Computer" directory in the drop-down menu at the top of the "Save As" box. Double-click the flash drive letter under the "Devices with Removable Storage" section.
Click the "Save" button to save the file onto the flash drive.
Close the windows and files when finished
hope this helps
Oct 17, 2012 | Microsoft Windows XP Professional Full...
How do i adjust the sensitivity of my touch pad for my Toshiba laptop PSLB8U-05202F
1.Turn on the computer and log into Windows as normal. Open the "Start" menu and click on the option labeled "Control Panel."
2.Double-click on the icon labeled "Mouse.". The "Mouse Properties" window will open. Navigate to the tab labeled "Device Settings." Click on the button labeled "Settings." A window labeled "Properties" will appear.
3.Examine the left panel of the "Properties" window and expand the option labeled "Sensitivity." Click on the option labeled "Touch Sensitivity."
4.Reduce the touch sensitivity setting by moving the slider to the right, towards the "Heavy Touch" label. Experiment with different levels of sensitivity until you find one suited to your needs.
5.Click on the button labeled "OK" to close the "Properties" window; repeat with the "Mouse" control panel. Your new touchpad sensitivity settings are now saved.
Sep 14, 2011 | Toshiba Satellite L305-S5908 Notebook
Need driver
http://www.softwarepatch.com/utilities/logisetpoint-dl.html
Click on the Link above
It'd prompt you to run or save a file after few seconds Click Save. That would open up a save as Window and Selct Desktop there on the left. Click save again on the right bottom corner. After its completed downloading, double click on the file and follow the on screen instructions.
Mar 31, 2010 | Logitech Cordless Mouse
The left button fails to function when I double
On Mouse Property, try faster on 'Double click speed'
Oct 18, 2009 | Microsoft Wireless Laser Mouse 5000
Hi HP touch smart mouse double click won't open the linkes, I have to press right then open link etc one
Check the mouse settings in control panel. This also has a small mouse test area for tesing dbl click speed and mouse tracking speed. Make sure that the left mouse / right mouse button assignment is correct.
Hope this helps
Mark
Aug 21, 2009 | HP Touchsmart IQ524 PC Desktop
Changing how to open drives
2 things...go into ur Control panel and in the MOUSE area change the way ur mouse clicks to run things..then save those settings.
OPen Real Player options or preferences. Look for an option to how it handles running things. then uncheck it. save those settings.
May 24, 2009 | Microsoft Windows XP Home Edition
Saving text which is entered into a text feild
Select text by holding the left mouse button down while moving over the text you want saved.
Then right click the mouse and select "Copy".
Open a blank document (Word, Notepad, Works, etc.) and right click anywhere in the document and select "Paste".
Then click File>Save As... and save it to whatever name you decide.
Oct 22, 2008 | Computers & Internet
Printing a selection from a text
Hilight the text by using the mouse, and right click and select copy.
On your desktop, right click and select NEW, then select either Word (if you have it) or Wordpad.
A new document will appear on your desktop. Double click it to open, click in the body of the document, right click and select paste.
In the file menu select print. Once done you can either save the document or if it's just temporary exit without saving.
Leaving the new empty Word document on your desktop to use for next time isn't a bad idea. You could even rename it to "Temp Word Doc" or whatever you like.
Dec 09, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Hhhhhhhhhhhhhhhhhheeeeeeeeeeeeeeeeeeeeeelllllllllllllllllllllllllpppppppppppppppppppp
-Open Word -Enter your text. -Using your mouse right click on File from the menu bar at the top of your Word window. - From the menu that appears right click on Save As?.. -From the Save as box that appears right click on the My Computer icon on the left hand side. -In the right hand side of the Save As box select the drive you wish to save the file to by double left clicking on it. -Click on the Save button. Done.
Jul 22, 2007 | Microsoft Windows XP Professional With...
Acer Aspire One Netbook 8.9" Notebook Logo
97 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
