Question about Vizio GV47LF Television
I have a gv47l fhdtv10a lcd. it made a loud pop and went blank. i replaced the fuse on the power board. the tv will power on but the screen stays black and the tv will not power off unless you unplug it. please help
    Problem Solver:
  • 5 Answers
Thanks for the suggestions. I had same symptoms and it turned out to be fuse f3 on the mainboard, this fuse is on the top right near fuse f1.
Posted on May 23, 2010
  • Thomas Rodano May 23, 2010
    problem fixed by replacing fuse f3 on mainboard
  • rquin_rquinl Jun 09, 2011
    anyone have a picture of fuse location please
Check the f1 fuse on the mainboard, it is a very tiny 1.5 amp ceramic fuse in the upper right corner, and can be fixed by soldering a radio shack fuse to bypass it.
Posted on May 05, 2010
  • 308 Answers
Something on the power supply board has failed. One or several of the voltages is bad and you don't have full control, no off, no screen voltage, etc. Unless you can troubleshoot switching power supplies, its best left to a repair shop.
Posted on May 04, 2010
Gv471 fhdtv10a
help my pliss
Feb 07, 2014 | Televison & Video
I'm have a vizio TV model gv47l fhdtv10a,I need
call any tv place they have new installation kits thatyou can buy
May 17, 2013 | Televison & Video
VIZIO GALLEVIA modle VIZIO GV47L FHDTV10A
Most plasma TV's have secoundary power boards, witch can be the cause, now I would try if I where you is to unplug it and let it set a hour or two, if that did not work then the tv will need to be looked at locally. The cause can be a bad power board inside the TV witch is a major cause why a Tv would have a power light put no function at all.
Hope this helps if you have any questions as to what parts to buy www.partstore.com is a best resource.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Oct 18, 2011 | LG 42PG20 42 in. Plasma HDTV
Vizio GV47L not turning on after a pop noise
screen went black due to power supply failure. check also inverter.
May 30, 2009 | Vizio GV47LF Television
Vizio GV47L screen went black and is now unresponsive
Could be the power supply gone bad.
No easy solution I'm afraid.
May 20, 2009 | LG 47LC7DF 47 in. LCD HDTV
check your power board, most likely that's the part that is causing the problem.
Feb 09, 2009 | Vizio GV47LF Television
Loud pop Blank screen 42 inch Viore Plasma
Unfortunately, that board is the inverter board. And for this model the inverter board is only supplied with the the PDP panel. The panel is quite expensive, here's a link if needed:
LG 42PX5D Replacement Part PDP Plasma Display Panel
Dec 26, 2008 | LG 42PX5D 42 in. Plasma HDTV
Vizio GV47L FHDTV10A
sounds like a lamp failure.
Dec 03, 2008 | Televison & Video
TV's on. No Picture...No Sound
Have a problem with Zenith 37 HDTV. Medel number: Z37LZ5D As wathcing TV, along with 'pop' sound, TV went dead. LG service center gave an advice to unplug the power cord and press ON/OFF power switch about 1 min. Then plug power back and turn on the TV. Well, the green light blink for a while and solid green, but still no screen, no audio. Search the Web and someone suggested to replace Power Supply Board which will fix the problem. Again, search the Web and came out with Power Supply Board. LG Electronics/Zenith 'Power Supply Assembl' with $124.95 from PartStore.com. Is it the right solution? Do I have to replace entire Assembly Board? not just replacing some fuse? Any cheaper way to do? If I have to replce PSA board, any suggestion to how? Comment posted on Apr 22, 2009 I have a basic knowledge of electric and electronics, such as rewiring entire house for renovation and assemble entire computer from scratch.
Actually, the TV belongs to my father and the problem that I stated was based on what he told me.
So the question is based on the symptom that I posted, how sure are you that the problem is the Power Supply Board?
Is it good to order PSB? Comment posted on Apr 23, 2009 Purchased 2 and half years ago. Expired one year warranty. Comment posted on Apr 23, 2009 Zohail,
This is LCD TV.
There is no problem with the wall socket nor current.
I put other appliances on same wall socket and worked.
It has to be internal problem.
As I mentioned on the main post, there was a 'pop' sound while watching and TV went dead.
Turn on remote control, there is blink green light and then green stays on, but no sound, no screen.
Turn off remote control, light turns red. Comment posted on May 14, 2009 I fixed the TV.
Orderd power supply board which cost me $136.51 total.
Replacing was simple.
Just removed the rear panel cover then electronic board housing cover.
Took power supply board with all the connector cables and replaced with new one.
Problem was a transformer connector which got burned and blow up the plastic cover.
But no problem with fuse and capacitors.
Thanks all for advises.
Jan 01, 2008 | Zenith Z37LZ5D 37 in. LCD TV
Vizio GV47LF Television Logo
827 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
