Question about Electrolux EIFLW55HIW Front Load Washer with IQ-Touch Controls
Electrolux EWF1495 - LCD dead, door locked no knob function
I was attempting to put a second load of washing on tonight. I turned the knob to a different setting and the machine completely died. At first i had no functionality or what seemed no power at all. Screen would not light up, door would open and shut & the dial would not make any changes at all. I turned the machine off at the mains. Turned it back on about 20min later the LCD screen is still not functioning and the door is now locked with the orange led on the door on and i cant open the door. Turning the dial to differnet setting made the machine make a grinding noise at first but now i have nothing but the door light on and the door permanently locked. Any ideas on what the problem is ? I purchased this machine in 2006.
5 Suggested Answers
  • 641 Answers
SOURCE: electrolux washing machine xc6 aquacycle 1400
Maybe that the door is shut "mechanically" but the micro-switch that indicate the control unit that door is shut,is faulty.
Posted on Jul 25, 2007
  • 51 Answers
SOURCE: My Electrolux Washing machine has fault code
www.electrolux.com.auGo here and type in the model in the search bar and download the manual for the machine this will help
Posted on Jun 12, 2009
  • 6277 Answers
SOURCE: EWT806SA? the machine displays an error
(manual first then a possible cause of the 'EF')
I'm so sorry but this forum is not able, nor in a position, to supply any type of manual, installation instructions, electrical or schematic diagrams direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
Also members on Fixya are not 'affiliated' to, or representative of, any manufacturer at all, just using their experience gained probably over many years.
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
'EF' = Error Filter (?)
I do not have this error code in my list for Electolux washers, however I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If these have assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Posted on Jul 31, 2011
  • 6277 Answers
SOURCE: The washing machine seems to have stopped during
From your desciption it seems to be indicating that there is a problem either with the door lock or more likely the door locked sensor requiring a service call, sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
John C
Posted on Sep 19, 2011
Testimonial: "straight to the point"
How to do a electrolux washing machine ewf1495 reset
If you mean "reset program" than turn program selector to "OFF" position and than choose new one, otherwise unplug from wall socket.
Dado
Jul 26, 2015 | Electrolux Washing Machines
Model EWF10843. How do I select diagnostic mode?
Electrolux Diagnostic Mode
* Press the Cancel button to enter standby mode and enable diagnostic entry.
* Within 10 seconds after pressing Cancel , press any button to wake up the control.
* Within 5 seconds of wake up, turn the selector knob to the far left cycle and press and hold Cancel and far left
button under the display simultaneously for 3 seconds to enter the diagnostic mode.
To save time at wake up, the Welcome screen can be bypassed by turning the selector knob.
1. Upon entering diagnostic mode, all lights should flash for 1¼"x2" display models and all lights on for the 1¼" x
4 3/4" display models.
2. Turn the program knob (1) click clockwise from the start position. The hot water solenoid will activate and hot water
should enter through the detergent compartment.
3. Turn the program knob (2) clicks from the start position. The bleach water solenoid will activate and cold water
should enter through the bleach compartment.
4. Turn the program knob (3) clicks from the start position. The bleach and the wash water solenoids will activate and
cold water should enter through the softener compartment.
5. Turn the program knob (4) clicks from the start position. The prewash solenoid will activate and cold water should
enter through the prewash compartment.
6. Turn the program knob (5) clicks from the start position. The door lock solenoid will deactivate and the loading door
can be opened. When the door is opened, the drum light should turn on.
7. Turn the program knob (6) clicks from the start position. The door lock will activate and the washer will fill then
tumble. Once tumbling has started, the boost heater will turn on.
8. Turn the program knob (7) clicks from the start position. The drain pump will activate draining out any water in the
tub and the washer will operate in high spin.
9. Turn the program knob (8) clicks from the start position. This is a free position.
10. Turn the program knob (9) clicks from the start position. The control will signal the last 5 error codes with E00
being no error.
11. Turn the program knob (10) clicks from the start position. Latest software version will be shown.
12. If applicable, turn the program knob (11) clicks from the start position. This is a free position
Exiting Diagnostic ModeA) Unplug the power cord, wait 5-8 seconds, then reconnect the power cord or
Turn the program knob clockwise back to the start position. Press the Cancel and far left button under the display
until the LED's stop flashing
Jun 08, 2015 | Electrolux Washing Machines
Electrolux EWF 1495 won't spin.
The belt could be stretched or the tension idler could be malfunctioning.
Feb 12, 2015 | Electrolux Washing Machines
Electrolux EIFLW55HMB Front-Load Washer With IQ-Touch controls won't open
Try unpluging for a few minutes . wake the washer up by turning knob then at the same time press and hold start cancel error will display . take off top and you will find a tech sheet on left side and that should help. you can manually unlock the door after taking top off and reach down to door lock you will feel a plastic switch to pull
Feb 17, 2013 | Electrolux EIFLW55HMB Front-Load Washer...
Washer makes very loud humming noise in spin cycle but does not spin..I removed clothes thinking it was very heavy and it did spin out but when I put clothes back it returned w/no spin and loud noise..now...
Either the control board or the motor has gone bad. Here is the diagnostic mode to run to look for the errors.
The diagnostic test is performed by using the Program Knob. To START THE TEST: • On non-digital display models, turn the Program Knob to start position, Drain/Spin. • On digital display models, turn the Program Knob to start position, Touch Up. • Press Pause/Cancel to turn off LEDs. • Within 5 seconds, press and hold the Option and Pause Cancel buttons until LEDs start sequentially chasing, then release buttons. 1. All the LEDs will sequentially light. Pressing a button below a light cluster will light all the LEDs in that cluster at one time to confirm functionality. 2. Turn the program knob (1) click clockwise from the start position. The hot water solenoid will activate and hot water should enter through the detergent compartment. 3. Turn the program knob (2) clicks from the start position. The bleach water solenoid will activate and cold water should enter through the bleach compartment. 4. Turn the program knob (3) clicks from the start position. The bleach and the wash water solenoids will activate and cold water should enter through the softener compartment. 5. Turn the program knob (4) clicks from the start position. The door lock solenoid will activate. 6. Turn the program knob (5) clicks from the start position. The door lock solenoid will deactivate and the loading door can be opened. 7. Turn the program knob (6) clicks from the start position. The washer will fill and tumble. 8. Turn the program knob (7) clicks from the start position. The washer will fill and spin (leakage test). 9. Turn the program knob (8) clicks from the start position. The drain pump and door lock solenoid will activate and the washer will operate in high spin. SAFETY WARNING: If power is removed during this test, the door can be opened. To prevent injury, DO NOT put your hands inside when the tub is rotating. 10. Turn the program knob (9) clicks from the start position. The control will signal the last error code.
Repost the error codes here.
Feb 12, 2011 | Frigidaire Affinity ATF7000E Front Load...
Have Error Code E20 - won't drain. How do I approach?
The diagnostic test is used to check individual component function only. TO START THE TEST: • Turn the Program Knob to the start position, Spin Only. • Press Start/Pause to start the cycle and save it. • Press Cancel to stop the cycle and turn off the LEDs. • Press Cancel again to turn on the LEDs. • Within 5 seconds, press and hold the Options and Start/Pause buttons until LEDs start sequentially chasing, then release buttons. 1. All the LEDs will sequentially light. Pressing a button below a light cluster will light all the LEDs in that cluster at one time to confirm functionality. 2. Turn the program knob (1) click clockwise from the start position. The hot water solenoid will activate and hot water should enter through the detergent compartment. 3. Turn the program knob (2) clicks from the start position. The bleach water solenoid will activate and cold water should enter through the bleach compartment. 4. Turn the program knob (3) clicks from the start position. The bleach and the wash water solenoids will activate and cold water should enter through the softener compartment. 5. Turn the program knob (4) clicks from the start position. The door lock solenoid will deactivate and the loading door can be opened.When the door is opened, the drum light should turn on. 6. Turn the program knob (5) clicks from the start position. The washer will fill and tumble. Once tumbling has started, the Boost Heater (if so equipped) will turn on. 7. Turn the program knob (6) clicks from the start position. The drain pump & door lock solenoid will activate and the washer will operate in high spin. 8. Turn the program knob (7) clicks from the start position. The control will signal the last error code. Exiting Diagnostic Mode There are two options for exiting theDiagnosticTestmode and returning the washer to normal operation: a) Unplug the power cord, wait 5-8 seconds, then reconnect the power cord OR b) Turn the program knob clockwise 2 or 3 clicks after the start position. Press Options and Start/Pause buttons together for a few seconds until wash cycle LEDs appear.
Dec 26, 2010 | Frigidaire Affinity ATF7000E Front Load...
Unusual display on panel (padlock) machine can't be programmed door is not locked however
i just went through the same thing.......you need to hold the option and extra rinse buttons simultaneously for 6 seconds, this will unlock it.....so turn the machine on and press the two icons, dont worry about the beeping and flashing after 6 seconds the padlock symbol will go and you can use the machine as usual.....i wish they put that 'minor detail' in the manual...cheers!!
May 31, 2009 | Electrolux EW1000i Front Load Washer
Machine stops and the Start light is blinking
It might be teh same problem I have. in my case, teh machine works for a few seconds and then stops i.e. nothing else happens. no alarms go off either. In my case it appears that teh door interlocking device is faulty. You can by this spare part for around 22 euro. Replacing it is a bit tricky because you need to take off the locking device(the slot where the door locks into) and redo wiring. DONT mess up teh wiring becasue then you will need an engineer. Before you go looking for a spare part, you can take off teh interlock adn manual try to operate it. do this by turning on a wash and pressing teh two metal parts together on the lock.
May 18, 2009 | Electrolux Washing Machines
The door will not open on my Electrolux washing machine
How much trouble do you want to go to?
If you just want to preserve the washing, then simply put it on another cycle tonight and that will keep it fresh until the callout turns up to fix it.
The next clever step is to power the machine off at the mains for 10 minutes. Depriving it of power MAY release the interlock door switch even if the cycle didnt.
Final attempt to get to it... Turn off power, unplug at the mains. drag the machine out so you can see the back. Remove the 2 screws that hold the top on, pull back or tap the top forward (depending on the model) to unclip it. Peer inside. You will see the door switch inside the chassis exactly in line with the door handle on the outside. See if you manually make the mechanism release, or if you have a stubby philips screwdriver, you can probably unscrew the switch complely.
If you trust yourself NEVER to open the door in the middle of a cycle, the machine will of course function without a switch. Just so long as you recognise that you will flood the place if you do open it with water in. Also if you put your hand inside dirung a wash (Or worse still a spin) the power of the motor combined with the weight of the wet washing will rip the arm clean off a fully grown man, so if you doubt yourself or you have kids (or kids may visit) don't leave it like this.
Jan 09, 2009 | Electrolux EW1000i Front Load Washer
Electrolux front loading washer - door is locked, won't unlock
I have an Electrolux front loading washer. I just got done washing a load of laundry and the door will not unlock. I tried washing it for a second time thinking maybe it would open again. No luck.
Nov 09, 2008 | Washing Machines
Electrolux EIFLW55HIW Front Load Washer with IQ-Touch Controls Logo
211 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
