Question about Hampton Bay 24002 Ceiling Fan
I have a hampton fan 5 blades, is the proper way to connect for the lights to is to connect the blue wire to the white wire or the black wire
    Guru:
  • 351 Answers
If you nare adding a light kit to the base of a ceiling fan, you will connect the blue and black wires together ,, and then the two white wires ..
Posted on May 06, 2010
I did not make a diagram when replacing the light switch
Red from switch goes to two blacks, blue from switch goes to two blacks and the black wire goes thru top of light and attaches to blue fan light wire. If you want a good fan, look for blade pitch(13 degree or higher)Or CFM's above 5500 on high.
Oct 02, 2013 | Hampton Bay 24002 Ceiling Fan
I need to know how to connect wires for ceiling fan Hampton Bay model #crc 552 nm (ch) pb Coming from my ceiling are black/white/red wires Fan has blue/white/black wires. Fan won't work but, I want to have...
if you have a single switch for the outlet (I mean no separate switch for the fan) then on your fan you couple the blue and black wire and couple it to the black out of your outlet. The white (hot lead) to the white on your fan.
The red wire out of your house outlet may be for another control, but you should also ground the fan.
Use an electrical twist CAP for the red wire.
This configuration will turn everything on the fan and lights and allow you to use the pull cords to control the features.
NEVER LEAVE EXPOSED WIRES anywhere. Even if the insulation does not expose the wire, cap it.
(ps, I have this fan, and installed. It is heavy so make sure you have good support. After installation, make sure you balance the blades.)
good luck.
Sep 27, 2010 | Hampton Bay AC434-NI Ceiling Fan
Trying to connect a ceiling fan light kit. I connected the blue wire from the fan kit to the black wire in the light kit and then connected the white wire from the fan kit to the white wire in the light...
Those connections sound OK ,, now you have to go to the canopy and see if all the wires for the fan/light are connected to a house wire. If there are two switches , then the blue fan wire would connect to the red wire .. it may be capped off in the ceiling. If there is only one control switch , then the blue wire from the fan will connect to the same ceiling wire as the black fan wire does.
Please Vote !!
May 30, 2010 | Hampton Bay 24002 Ceiling Fan
I bought a Hampton Bay ceiling fan and I have
Hi ,, the usual wiring for the fan / light is that in the ceiling the white wires connect together , the black house wire connects to the black fan wire, the red house wire connects to the other fan wire, usually blue or black with a blue stripe. If this does not resolve the issue, then check the wall switches and see that there is a power wire to each switch and that there is a red wire from the fan on one switch and the black wire from the fan on the other switch ..
Apr 07, 2010 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Wiring light kit to ceiling fan
connect the white wires from light kit filter to the white wire labeled "for light" from fan. then connect black wire from light kit filter to blue wire from fan. use wire nuts to make the connections
Jan 17, 2010 | Hampton Bay 24002 Ceiling Fan
Trying to rewire a hampton bay light fan. I have
Try switching the red and white wires
But it should be working if the light is.
Make sure all the wires to the remote are connected good. You may just have defective remote.
Nov 29, 2009 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Wiring Hampton Bay Fan
The blue wire is for the light.This should connect to the other switch instead of being combined with the fan switch.
Sep 09, 2007 | Westwind Classic Hugger Polished Brass 52"...
Installing ceiling fan with two switches AND a remote
in your ceiling box should be three wires. a red goes to the three way switches, a black goes to the hot and the white is the neutral. the fan wires are black, blue and white. since you have a remote, connect the [fan] blue & black together with the [line] black. connect all white wires together. the remote will now ramp up your lights from off to full on and the fan remote will let you choose lo med high and off. just tape up the red wire in the box.
Aug 17, 2007 | Hampton Bay 04383 Calibre Ceiling Fan
Hampton Bay 24002 Ceiling Fan Logo
108 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
