Question about Garden
I have an 18 hp twin 2 model 422707, it keeps surging at low idol and slightly at high idol I removed carb jet and blew air through re assembled and still have same problem any tips? Dale
  • 198 Answers
Sounds like you need to take off the float bowl and clean the bowl and the inlet valve. make sure when the bowl drops the gas will flow in smoothly
Posted on May 04, 2010
18 hp twin 2 modle# 42a707 type 2238e1 rpm revs up & down
Typically it is dirty passages inside the carburetor. Basically fuel flow is slightly restricted so the carb is working outside of its normal calibration - the governor is not controlling well outside the normal calibration. This is most common after long winter of no use.
I use carburetor cleaner. I carefully disassemble things like the fuel bowl (preserving the gaskets) and spray cleaner down the jets, through every air passage etc. (there are small air bleed holes in the carb venturi). Wear eye protection because it will squirt back at you sometimes!
Mixture screws... Screw them all the way in, counting how many turns until they bottom out. Then screw them all the way out and remove them. Spray cleaner down there as well. Re-assemble screws by bottoming them out and backing out the number of turns you counted.
Never use drills or wires to clean out passages on a carburetor. Hard metals will wear on soft brass fittings. Carburetors are calibrated! Carb cleaner in a spray can is relatively safe.
It will run 100% better (and start better as well).
Next time use fuel stabilizer (I put it in every tank because I can never predict when the 'last' time I will use it will be).
Jul 12, 2011 | Briggs & Stratton Briggs Stratton Intek V...
Carb wont pump gas
If gravity feed works to the fuel line on the carburetor, then the fuel pump is bad. Repair or replace fuel pump. I am looking for fuel resistant sealant to repair fuel pump diaphragms. Has anyone tried Permatex 85420 or something else to achieve this? My application is antique and the part is no longer available at a reasonable cost.
May 04, 2010 | Briggs & Stratton Briggs Stratton Intek V...
My engine is pulsing I removed the jet and cleaned with compressed air and cant figure out why it still surges at low rpm
it is a govenor problem i would just lift the revs slightly and try adjusting it out with air mixture screw
Bike wont idol below 2 grand
Hi and welcome to FixYa,
Almost always, the described idling problem would be a carb issue. The carbs set has to be pulled down, fully dis-assembled, all non-rubber parts soaked in carb cleaner and cleaning be done specially on the jets and pin holes.
In some instances high idle could be caused by a vacuum leak in any of the rubber coupling between the carbs and the intake manifolds.
Good luck and thank you for asking FixYa.
Apr 09, 2010 | 1992 Yamaha FZR 600
My Briggs 18 hp v-twin is starved for fuel. It
A more likely cause is a clogged jet in the carb.
Remove disassemble and clean Carb, the High speed idle jet is clogged.
If you had a fuel pump problem it would not run even in the Choke mode.
This tends to happen when an engine sets for long periods of time with out a fuel inhibitor id is even more likely to happen if you use fuel with ethanol.
Hope this tip helps.
r/David
Jan 23, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Oh318 (tecumseh) Runs for a few minutes then cuts off. Starting fluid makes it run for a few sec. then it cuts off again. replaced whole bowl assembly. Cleaned carb in carb cleaner. Blew it out. Checked...
Fuel Starvation - Float Bowl Carburetor
1) remove air filter assembly
*be cautious of tearing the mounting gasket. If it does tear, you HAVE to replace it. It is part of the priming system
2) remove the float bowl fastener. This is the main jet
3) carefully remove the float bowl, the rubber o-ring/gasket will not be able to be used if it is removed, you WILL have to replace it
4) using a spray 'carb cleaner'
spray up thru the center of the carburetor
spray and clean the main jet with cleaner and 'tag' wire
(tag wire is very thin, and can be used to clean the hole in the center of the main jet)
5) clean any debris from inside the bowl or carb body
6) re-install bowl and center bolt, air filter assembly
*if you need gaskets, your Briggs dealer can supply. The kit is cheaper than individual gaskets, and all the parts needed to finish the above repair are in the kit.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Nov 21, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
My 18 hp twin cylinder Briggs and Strat. Craftsman lawn tractor moter surges and dies. I cleaned the carbuetor body and the goveror linkage. No problems found. I rebuilt the fuel pump rubber and...
Hi..my name is Keith...and the engine is running too lean..and with you choking it..it richens the mixture..so its a carb problem..and that could be several things..1)..is the main metering jet needle on the bottom of the float bowl needs to be turn out until the engine runs smooth..or 2) the carb to engine gasket is bad and its sucking air..or 3)..the passage ways in the carb is stopped up..i hope one of these will help..if not please write me back
Jul 10, 2009 | Garden
Need carburetor adjustment
I had a similar problem with my 23 hp briggs. While cleaning the carb I found that the great gas we get today had eaten the seal around one of the jets in the throttle body causing it to fall out. Replaced the jet and now runs like a champ. Hope this helps.
May 05, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
284 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
