Question about Sharp AL-1641CS Color Copier
H4 error code
Power went out and when we turned it back on it gave me this error code H4
  • 59 Answers
H4 00 Content Heat roller low temperature detection
Detail When the fusing temperature is lower than
150C° after 55sec from the start of warming
up.
When the warming up complete temperature is
not reached in 30sec from reaching 150C°.
100C° after 20sec from ready start.
145C° when printing."
Cause Thermistor abnormality
Heater lamp abnormality
Thermostat abnormality
Control PWB abnormality
Check
and
remedy
Use SIM 5-02 to check the heater lamp blinking
operation.
When the lamp blinks normally.
Check the thermistor and its harness.
Check the thermistor input circuit on the control
PWB.
When the lamp does not light up.
Check for disconnection of the heater lamp and
the thermostat. Check the interlock switch.
Check the power PWB and the lamp control
circuit on the MCU PWB.
Use SIM 14 to clear the self diagnostic display.
Posted on May 05, 2010
Gree air conditiones H4 error code
Not answer my question is what is the solution for wall mounted unit Model number 18cith1 has error H4 this error meaning here mention system protection.
Apr 30, 2014 | Heating & Cooling
Hi, it show a code: H4-00
H4-00 error code - The temperature does not reach the specified level within the specified time after turning on the power relay. abnormal.
Upgrade the firmware.
Jun 21, 2011 | Sharp AR-M277 All-In-One Printer
Sharp ar 5516 printers error h5. h4
hi,I have error code L h on my coppier sharp 5516. your help please.
Aug 05, 2010 | Sharp AR-5316 Advanced Digital Imager...
SHARP AR M-205
Hello sir; this error code require reset the procedure as follow;
1, press "#", "interrupt", "clear", "interrupt".
2, enter 14, press start.
3, turn power off and back on
Feb 07, 2009 | Sharp AR-M205 Copier
Code H4 comes up when the sharp copier ar-5316 is switched on. it cannot be use. what shall I do to solve this problem of error code H4.
Hello sir; H4 code require reset procedure as follow;
1, press"#" "interupt" "c" "interupt" these 4 keys.
2, enter 14 , then press start
3, turn power off and back on .
Jan 28, 2009 | Sharp AR-5316 Advanced Digital Imager...
Xerox pro 215, error H4 please help
H4 is a fuser error....not getting up to temperature.
Press [C] (Clear), press [Image Quality], press [C] (Clear) again, press [Image Quality] again.
If this doesn't bring it back to operations then the fuser lamp needs to be replaced.
Jan 17, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Error code H4-01
This mean you have low temp. on heat lamp 2 program interput clear interrupt 14 print may clear this code. if not you can look at the fusing unit and reset thrmo breaker that may be pop off.
Jul 26, 2008 | Sharp AR-C160 Color Copier
H4 error code
H4 is a Fuser Unit heating problem.
This reset is for another model sharp, see if it will work for you.
Press "Clear", "Auto Exposuer", "Clear", "Auto Exposure", the display will go dead... then press "14" (Like your going to make 14 copies), then press "Start".
Hope this works.
Good luck,
Mac
Feb 10, 2008 | Sharp AL-1551CS Printer
H4 error code
H4 codes are related to the fusing unit. Specifically a low heat condition. Follow the reset procedure below. If that doesn't work further diagnosis of the fusing unit an peripherial circuits may be warranted.
Error code reset:
Perform the following key procedure
"#" key, Interrupt key, "C" key, Interrupt key
"1" key, "4"key
Start key, "CA" key.
See if unit cycles and comes back up. If not turn off and then back on the main power.
If error reappears on site technical service may be required.
Jan 06, 2008 | Sharp AR-5320 Black and White Copier
Cant get rid of blinking error message, nothing works
The [H4-00] system error popped up when the power went out of the house. I called Sharp tech support (1-630-378-3590) and was talking to their tech support in less than a minute.
The FIX? Just press the following keystrokes:
# * C * This will clear the display error, now press…14, then press the green button twice. This should let your printer start to warm up and you have fixed your problem.
Dec 20, 2007 | Office Equipment & Supplies
Sharp AL-1641CS Color Copier Logo
155 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
