Question about Frigidaire ATF6000ES Front Load Washer
Seems to be going through the cycles but when it gets to the drain it makes a noise and the water doesn't drain - it is a front load stackable
  • 8 Answers
Might be something in the pump...its pretty simple to check....just disconnect the washer, lean the washing machine back against the wall.....make sure its stable of course and take the clamp off...its to the right...then get a flashlight or put your fingers in and check...
Posted on May 05, 2010
  • sandyfgomez May 10, 2010
    Forgot to mention.2 things...disconnect it of course and make sure you have a mop and some towels ready..water might come gushing out as it did with mine....also, if someone can tell me if i can post a pic and how, i'd love to do it so you can see what im talking about as far as the pump.
MY LG MODEL F1403FDS5 IS SWITCHING OFF AFTER 6MINUTES WHEN ON 30MINUTE CYCLE BUT IF YOU SELECT RINSE AND SPIN IT FINISHES THE CYCLE.
check the ibnlet screens for the water valve,they may be plugged, also make sure the drain hose is above the washer so it dont siphon out as it fills
May 06, 2014 | LG WM2077CW Laundry XL Front Load...
I have the ATR6700FS1 front load washer. It goes fine until the spin cycle. It pauses & when I hit restart it makes a noise & doesn't spin. If I hit cancel & go to the spin cycle it
Hello Deanna Lytle - Often when a unit does not spin, it is because the unit cannot properly drain and dispose of the water and detergent solution. Does the unit make a humming noise? If so, the drainage hose/pump may be clogged and needs to be cleaned. If not, the washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
Mar 29, 2013 | Frigidaire ATF6000ES Front Load Washer
My servis washing machine makes a loud grinding noise when the water drains whilst drum turning.
could be something in the pump as opposed to drum bearing fault....Try cleaning filter/check pump blades.....
Feb 24, 2011 | LG WM2077C XL Front Load Stackable Washing...
My LG front loading washer makes a train noise during the rinse cycle. What could be the cause?
if it is right after the drain cycle; it then goes into a spin. It then starts to fill with water for the rinse while the tub is still turning. The water entering the tub while the tub is spinning, cleans the tub of soap and the water going through the holes in the tub are causing the noise. It is normal if only in the rinse cycle.
Aug 29, 2010 | Frigidaire GLTF1670A Front Load Washer
Kenmore front load washer #44072 drum banging noise
I have the same problem...the solution is called new washer. I was told it could be overhauled to the tune about $600...barrings are going out. Mine is just 7 years old and that's disappointing.
Mar 29, 2009 | Kenmore 44072 Front Load Washer
Frigidaire stackable front load washing machine
ok we have to take bottom front panel off,,theres three torex head screws..now straght in front of you is the pump ,,remove the filter turn it counterclockwise,,theres always a little water in it so be prepared...remove clogg and we should be good all coins are mine,,onthejob
Feb 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
GE Front Loading Washing Machine seems to be holding water....
The high speed spin of a front load washer should normally do a good job of getting squeezing out the water but if there is an oversudsing condition that makes it hard for the drain pump to operate then the suds and water will just stay there. First make sure there is no actual clog in the drain line then run a load with no soap or detergent and see what happens. It's always better to use a low suds detergent with this type of machine
Mar 08, 2008 | GE WSXH208A Front Load Washer
Thumping and banging
washing machine making noise, remove water but doesn't spin
Jan 25, 2008 | Kenmore 98702 Stacked Washer/Dryer
Stackable Washer will not drain.
check if there is a low humming noise when on drain. if so there may be a foreign object trapped in pump. otherwise have you checked filter?
Apr 02, 2007 | Whirlpool LTG6234D Front Load Stacked...
Frigidaire ATF6000ES Front Load Washer Logo
168 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
