Question about Intel DG33BU G33 Express Socket 775 mATX Motherboard w/Video & Sound
Why when windows restart, the cpu refuse to boot except if I disconnect the power and reseat the power cable again.. ?
  • maxcastle255 May 11, 2010
    Be more discrete. Please explain completely. Its hard to understand what the problem is.
  • 59 Answers
I think your operating system is corrupted. please check
Posted on May 08, 2010
Bis failure, media cable and insert boot disk
first step to check whether its a hard ware or software issue .........disconnect all the external devices and disconnect the power cable from the back of the computer , then press and hold the power button for 10-12 secs with the power cable disconnected and then reconncet only the power cable and restart the computer and check whether it restarts or not.................shut down the computer and while u restart the computer keep on tapping f8 key on the keyboard and on advance boot options select last known good configuration and hit enter and see whether it restarts or not .......................after that shut down the computer and while u restart the computer keep on tapping f9 key on the keyboard and do the diagonistic test and see wat error do u get if u get any biohd-8 then the hard has gone bad , if u get any other error then jast open the tower and reseat the hard drive and the sata cables , the hard drive cable will be jst below the dc/dvd driive looks lik a bunch of multi colured cables .............and also reseat the sata cables i.e a red ribbion like cables and restart the computer and see ....
Jun 08, 2010 | MPC Computers ClientPro 345 G PC Desktop
I plugged in the power cord and I get no power at all. No lights/nothing? Thanks.
HI
ITS PROBLEM OF COMPUTER SMPS (SWITCH MODE POWER SUPPLY) REPALCE IT ..
TNKS
RABBANEES
Nov 05, 2009 | Dell OptiPlex GX260 PC Desktop
Problem booting into Windows.
This could be a hard drive problem. The hard drive is looking for the boot sector on it, but the boot sector is broken. Computer shuts down and tries again but your hard drive can't find the boot sector so it shuts down tries again etc.
Hank
Sep 24, 2009 | ECS C51GM-M Motherboard
My Dell Dimension would not Boot when I try to Boot the power light jush flashes if I remove the yellow and black cable from the power surploy you can here it booting but there is no video
hi there,
well,unplug your pc, try to put back cable supply,try to configure your hardisk on cmos/bios set up,if the hardisk have detected by your cpu,refresh your hardisk,disconnect hardisk ide cable from motherboard and put it back.then try to run again.if windows does not
come out,reinstall your windows again on your cd installer you can fix from repair your system.have a nice day
Jul 06, 2009 | Dell Dimension 1100 PC Desktop
All I see is a black screen when I start my computer. No Bios, no Windows, nothing! Probable cause ? Thank you.
try to disconnect everything except mouse,keyboard and monitor, turn off computer, unplug power cable and turn it on again..if it wont turn on or still does the same,you need to reseat your memory modules..try using a different monitor as well or reseat monitor cable
Oct 09, 2008 | E-Machines Computers & Internet
No boot up
Try removing all memory except one board. If it does not come up switch boards. Still no luck, check power supply if you can or switch it with another. A power supply checker is pretty cheap, 10 to 15 dollars, and well worth the investment, although it is not foolproof. Try switching PS off, physically remove the BIOS backup battery, then replace it and try again. That should have cleared the BIOS back to factory defaults. It sounds like a memory problem, but as a last resort, you might reseat the CPU. The CPU fan runs, yes? Can you get some other memory to try? Well good luck!
Sep 25, 2008 | ASUS A7V333 Motherboard
Motherboard
Sounds like you tried everything except reseating any other hardware that may or may not be placed in another socket such as PCI, AGP, etc... Like a Modem, Network adapter, Sound/Graphics card, Wireless card, etc... This is probably a wasted post as if you knew to check each stick of memory seperatly then you've probably already reseated all socketed hardware. Though, you could remove all non essential hardware such as I mentioned above and try installing Windows again?
Good luck and keep us posted.
Sep 06, 2008 | Dell Dimension 8400 PC Desktop
P4m800-m7a motherboard
Disconnect all the cables from the Back of your Computer.
after disconnecting all the cables press the Power button and hold it for 30 seconds, after that connect power cable and monitor cable and turn it on, if it turns on then turn it off and connect mouse and keyboard and turn it On, if it works then you can connect rest of the cables, if it coes not work then you need to open the CPU and Reseat the Ram and try to restart the computer, if that doesnot work there could be any hardware problem.
Jul 09, 2008 | Biostar P4M800-M7A Motherboard
Prior to closing Notebook I ran a registry clean program "CLEAN & FIX" that I have used for the last year or so. During the the fix process some error was encountered and I assume the...
Check whether the hard drive is detected in the BIOS or not.
Remove the hard drive & wait for 3 minutes and reseat the hard drive.
Check whether all the cables are connected properly.
Try doing flea power & the power cycle.
1. Disconnect all the peripherals like keyboard,mouse,printer, scanner & monitor and power supply from the CPU.
And press & hold the power button for 1 min, it will release the flea power from the mother board.
Restart the system & check.
2. Disconnect everything.wait for 5-10 minutes and then connect every thing & start the system.
Restart the system.
In this case you can make use of the system restore.
For XP :
Boot in to safe made by pressing F8 key(function key 8) can be found on the top row of the keyboard.
login to your account & start the system restore from start-all programs-accessories-system tools-system restore.
select the date on which it is working fine.
After completion the system will restart automatically.
Now you can boot normally.
For Vista :
Open this link to know how to do that :
http://support.microsoft.com/kb/940765/en-us
If the system restore doesnt help reinstall the whole OS.
If the hard drive is detected then you can now install the OS by changing the boot priority device to the cd.
Good Luck.
Live, Love, Laugh.
May 11, 2008 | Computers & Internet
Bios Beeps and no boot
Remove and reinsert the dimms
reseat the video card also
put everything back and try agailn
If this dont work reseat the cpu and repeat steps above
If the above fails to fix
If it will boot into safe mode
and use the standard vga as
you did before and restart
and try to reinstall the drivers
You are sure you installed the rilght
drivers for your OS
It may be that the card is not compatible
wilth your mobo.Try checking compatability list
for your OD
Nov 16, 2007 | ASUS A8N-SLI Deluxe Motherboard
Intel DG33BU G33 Express Socket 775 mATX Motherboard w/Video & Sound Logo
62 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
