Question about Toshiba Satellite A100-S8111TD Notebook
Have a toshiba satetllite laptop and i have error code 0xc000000f but was not givin a recovery cd and the old press f9 is not working. any ideas?
    Guru:
  • 109 Answers
Try going into safe mode with command line utility enabled. (F8 on bootup). in command console type chkdsk /f /r and enter y for yes at the prompt. wait for it to finish, it may take a while. If that doesn't solve it try typing fixmbr. If that doesn't work, manually load the os to boot from cd-rom. tap F1 while rebooting. in the BIOS go to boot options. in boot options change first boot device to cd. put the cd in the tray, save and exit your settings. The comp will boot from the windows disk. follow the prompts.
Posted on May 04, 2010
I keep getting error code 0xc000000f on my asus laptop and don't have the start up disc
Solved] Fix Windows 8 Boot Error 0xc000000f go here for instructions http://www.smartpctricks.com/2013/09/solved-error-code-0xc000000f-windows-8-a-required-device-isnt-connected-or-cant-be-accessed.html
Sep 30, 2014 | ASUS Computers & Internet
Factory reset toshiba A105-S4384
Put Recovery Disk 1 in the CD/DVD drive, then power off your computer, unplug everything from the unit including the AC, remove the battery, press and hold down the power button for 30 seconds, replace the battery and then AC, power on, at the Toshiba logo screen press 'F2' to enter the BIOS Setup, in setup press 'F9' to load setup defaults, press 'F10' to save and exit, now at the Toshiba logo screen press 'F12' to enter 'Boot Sequence', with the up and down arrow keys to select 'Optical Disk Drive' or 'DVD/CD Drive', you will then see 'Press any key to boot from CD/DVD drive...' with the dots counting down, press any key before the count down finishes. Assuming you get back to the Toshiba Recovery Utility menu, select the 'factory default' choice, and return your unit to its out-of-the-box state.
Jul 01, 2014 | Toshiba Satellite L655D-S5093 Laptop
How to factory reset my Toshiba Satellite A105-S4384
Jul 01, 2014 | Toshiba Satellite A105-S4384 Notebook
Error 0xc000000f while formatting hard drive
try some formating toos .. like hiran boot cd or disk or diskformater ...u can use usb bootable device to install windows, u can make ur personal pen drive to bootable pen drive.
Jun 02, 2013 | Packard Bell Computers & Internet
I have an hp dv9925nr laptop running vista home premium 64. I tried to reset to factory settings and now when I try to start up I get a boot manager error. It says \boot\bcd status 0xc000000f error...
Most of the boot up of problem because of hardware problem, registry missing or crashed, file deleted or changed.
You can boot up your Windows with Tenorshare Data Recovery WinPE.It allows users to burn ISO file to CD/DVD/USB flash drive directly.
Step 1: Download Tenorshare Data Recovery WinPE in any available computer (not from PC that can't boot up). Then launch it.
Step 2: Insert CD/DVD/USB flash drive to the computer, choose ISO image file. Here we take USB flash drive for example. Then burn ISO file into flash drive.
Step 3: Insert the burned flash drive to the unbootable PC. Run computer and press "F2", "F10" or "Delete" to enter BIOS setup.
Step 4: Use the arrow keys to select Boot tab, select Boot Device Priority and press Enter. Please choose 1st Boot Device to USB, and then press F10 to save setting. Now,you can boot up your PC.
If you have a backup for your Windows then perform a system restore to fix it.If not,reinstall it.If you have no backups for all your data,you can use Tenorshare to retrieve data under any boot up problem.You can get it from http://www.any-data-recovery.com/product/datarecoverywinpe.htm
Here is tutorial to guide you how to do --How to Recover Data from Computer Won't Boot Up?-Windows Data Recovery.
Sep 19, 2011 | HP Pavilion dv9925nr Notebook
When I try to load my recovery cd on an old toshiba tecra 9100 I get an error message about 30% of the way through the recovery . The error msg is ' Error- extraction failed'. Is this a hardware...
Sounds like software problem. Error on extracting the file from the recovery cd to the hard drive. But to make sure, run a diagnostic test for the hard drive if the recovery cd includes that option, if not, try another recovery cd.
Hope this helps.
Jun 11, 2011 | Toshiba Computers & Internet
How can i restore my asus laptop to factory settings. i have 3 recovery geek squad disk.
Just on phone with ASUS rep. We're getting error on boot on a new unit. Told me to remove battery and power line and hold down power button for 30 seconds then plug in power (not batt) and press power then immediately press F9 again and again until a recovery screen that would reinstall from partition on hard drive appeared. Sadly, F9 didn't work for me and its off to service dept with a brand new unit that worked for 2 hours. Not so sure about ASUS. Have Compaq, HP & Toshibas with only one problem Toshiba within first year of purchase.
Dec 06, 2010 | ASUS K50IJ-C1 Notebook
Winload.exe
Hi there.
When you turn the laptop on, keep pressing Alt+F10. This should open the recovery program. Follow the on-screen instructions for factory settings.
Let me know if this does/doesn't work.
Tim
Apr 19, 2009 | Acer Aspire 3680 Laptop
Cd/dvd problem on toshiba m45-S165 laptop
Is you new hard drive lager than you old on and was the disk drive a factory replacement cause with those disks if you even change just that they will not work
Dec 09, 2008 | Toshiba Satellite A45-S250 Notebook
Loading problem
try to run again the system restore cd, what OS you are using? is it old or new acer laptop?
if you have new laptop with Vista OS it should be ok.
if you have new laptop design for vista but rather installed XP maybe you will encounter difficulties loading drivers if you dont have xp driver cd (acer provided)
if you have old laptop with XP OS it should be ok.
if you have old laptop w/ lower memory and trying to install Vista it will not work or you will incounter difficulties
Mar 16, 2008 | Computers & Internet
Toshiba Satellite A100-S8111TD Notebook Logo
277 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
