Question about InFocus ScreenPlay 4800 Multimedia Projector
Light blinking 3 times red - InFocus ScreenPlay 4800 Multimedia Projector
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 269 Answers
Bad lamp.
Posted on May 19, 2010
Replaced bulb in kdf-50e2000- when powered on green light flash 3 times & fan engages, 2 seconds later fan quits and i get a 3 red light blinks
impossible to actually see if lever is Fully engaged---with door off try to engage with a match stick or something not metal--see if set comes on that way.
Apr 20, 2012 | Televison & Video
The power button has a blinking red light, what does this mean?
4 flashing red light = av cable not connected. double check id av cable is connected properly. try using different av cable.
3 flashing red light = hardware problem . may require repair
2 flashing red light = overheating
1 flashing red light on bottom right LED with error code = hardware failure may require repair
Jul 04, 2011 | Buck Legendary: The Box for Xbox 360
Tv light standby red just keeps blinking after replacing bulb
If red light was not blinking before lamp replacement and after that it start blinking 3 times then pause for three seconds and again blink, check lamp cover that has not been fixed on tv or it is not fixed/ seated correctly there.
Lamp cover is first thing that you removed from tv to replace lamp.
Hope these info will help. If red light is blinking other than 3 times, let me know how many times it is blinking along with tv model number written at rear to provide you helpful info.
Thanks.
Jan 27, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
I have a 4 year old Sony KDF-E42A10 television - the power/standby light blinks red 5 times, pauses, blinks red 5 times again, etc. I have replaced the lamp previously when the light was blinking red 3...
5 blinks means there is a problem with the video board. It could be as simple as unplugging everything, includding power. Wait 3 minutes then plug power only back in. Or it may be a damaged component that requires replacing.
Hope this helps
TV_Doctors
Jan 05, 2011 | Sony Televison & Video
When charging battery green light flashes then red 3 times
KODAK Easyhare digital camera light status
1. Blinking green light(or blinking blue or white light in some models) - Means camera is performing a power up procedure. Note: Wait a few moments to see if the camera displays a solid green (or blue or white) light or a blinking red light.
2. Solid green light(or blinking blue or white light in some models) - Means Camera has sufficient power
3. Blinking red light - Means camera batteries are weak or need replacement; If battery are new and still red light camera needed to be repaired
For futher assistance contact Kodak support line 1 800 235 6325 (23KODAK)
Nov 21, 2009 | Kodak EasyShare M863 Digital Camera
3red lights how do i find the code
Press and hold the sink button then press the eject button 4 time
and note the 4 digit code .
4 blinking reds = 0 3 blinking Reds = 3 2 blinking reds= 2 1 blinking red=1
The code doesn't relay matter ,the problem is broken solder connections.
under the G.P.U 90% of the time , and that chip need to be re-flowed.
if you have any questions just comment and ill respond.
Rob
Oct 19, 2009 | Microsoft Xbox 360 Console
Series of 3 blinking lights. manual says lamp door isnt fastened properly. it is. i tried unplugging tv, have opened and closed lamp door 3xl. still blinking.
After I unplug and then plug tv to reset I get a solid standby light,then when I push the power button I get a green light that blinks 6 times then it blinks red 6 times and then red 6 times continuosly with a slight delay between the 6 blinks of red.
Oct 11, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Light blink 3 times
If this is a Sony dlp then check the lamp door for warp, if this is not a Sony need model and brand. Or if it is a Sony but not a DLP then still need model.
Sep 13, 2009 | Sony KDF-50E2000 50" HDTV
Kdf-60xbr950 - red light blinks 3 times for a minute and tv turns off
same problem as others 3 blinking green lights then orangey colors then 3 red blinking lights afterwards shuts down fan runs for about 2 mins solution check your door cover for warpage or deformed just a bit under set screw there is a push in switch try and push it in with q tip while holding turn on tv if it works then that door is deformed and defective change it
thanks for solving my issue tv works again very helpfull thanks
Feb 13, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
InFocus ScreenPlay 4800 Multimedia Projector Logo
225 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
