Question about LeapFrog LeapSter L-Max Console
Where do you type in the codes for leapster. we have the tinkerbell cartridge and have 2 webcodes to type in. . .
Leapster restarts select cartridge game
Try this
Ensure that a cartridge is not inserted
Hold down the Hint (?) button while turning the unit on. Continue to hold the Hint button down until the LEAPSTER menu appears.When the LEAPSTER menu screen appears, press the A button.Touch each of the crosshairs that appear with the stylus, Restart unit
Aug 13, 2014 | LeapFrog Leapster 2 Learning System
When clicking on leapster cartridge in Leapster 2, Leapster reboots itself. There were possibility of dirty cartridges-how does one clean the cartridges if they're in tiny slots?
If the cartridges can be removed, pull them out and try spraying an electronic contact cleaner, power off, and make sure it is safe for plastics, onto the cartridge pins. Then, Gently, slide the cartridge in and out of the socket several times to clean both the socket and cartridge. May have to do this a couple of times.
Jan 01, 2014 | Leapster 2
Leapster explorer cartridge won't fit
You have to make sure it is compatible. There are different types of Leapsters. Leapster 1 and 2, Leapster GS, Leapster Explorer and Leappad. Take it back to the store they may give you a refund or store credit.
Apr 19, 2013 | Leapster Learning System
I turn on my daughter's Leapster 2. I sign in. I click "Cartridge Game". The screen goes black & then It goes back to the "Leapster 2" screen, followed by the "if you...
You have to make sure that your Cartridges is clean. Try to vacum of blow both of the cartridge hole and also the place where you put the cartridge, Sometime very small tiny dirt will makes that the cartridge cannot be recognise by the console.
Instead of 1 starter game and a few demo game that you get from Leapfrog Connect, you can also get more downloadable games for your Leapster 2. You can get it here:
leapster-2.blogspot.com
Jun 08, 2011 | LeapFrog Leapster 2 Learning System
Cartridges are not being read
May 31, 2011 | LeapFrog Leapster 2 Learning System
When we inserted a new game cartridge (Pet Pals made for Leapster & Leapster 2) we get a question mark on the screen. We've changed the batteries and the old game cartridges are working fine. Please...
its not recognizing the game, contact is probably dirty. take an eraser and rub the contacts of the cartridge and get them super clean, blow out ALL the debris and that should fix it.
good luck!
Jan 29, 2011 | Leapster Learning System
Leapster 2 will shut off right after the "important" screen
Are you using it with a game? Will it stay on if NO game cartridge is in & are U able to access & play Pre-installed games?
If so, it may be the cartridge is DIRTY. I discovered this with our Leapster 2. What works for us is getting a Q-TIP & RUBBING ALCOHOL, you want to saturate Q-tip with the rubbing alcohol & clean the CARTRIDGE (NOT the Hand held ).
You want to clean the computer chip @ the bottom by inserting Alcohol soaked Q-tip on each side of contact strip (the part that inserts into the hand held) & with the dry end of Q-tip go over it again, for more cleaning & to wipe up any EXCESS Alcohol. REPEAT this process until Q-TIP comes back CLEAN.
I was really surprised @ ALL the BLACK grime that came off cartridge.
I hope this helps.
Good Luck.
-The Johnson Family :-)
Apr 06, 2009 | LeapFrog Leapster 2 Learning System
How do I delete a name from Leapster? I bought it used.
Question How do I delete or change a player name on Leapster™ cartridges? trnsp.gif Answer It is possible to remove a player once you have added three player names to the cartridge. If there is a name on the cartridge that you want to remove, take these steps.
1- Add new players until there are three players on the cartridge.
2- Once you have three players on the cartridge, an "X" will appear below each player's name.
3- Touch the "X", then touch the name of the player you want to delete. Touch "Yes" to delete the name. Then add a new name, or touch OK twice to go back to the sign-in screen without adding a name. Two names will always remain on the cartridge.
Dec 23, 2008 | LeapFrog LeapSter L-Max Console
Batman Leapster Cartridge broken?
Take the cartridge out of the Leapster, blow into the opening with your mouth. Do the same with the Leapster (blow into it). Insert the cartridge and see if that works.
Jul 19, 2008 | LeapFrog Leapster The Batman Strength in...
LeapFrog LeapSter L-Max Console Logo
289 people viewed this question
Top LeapFrog Video Game Consoles & Games Experts
Ted Maxwell
Andrew Taylor
Andrew Taylor
Morgan T Bradshaw
Are you a LeapFrog Video Game Console and Game Expert? Answer questions, earn points and help others
