Question about Asko D1776 Built-in Dishwasher
We need new wheels for our lower basket - Asko D1776 Built-in Dishwasher
  • Asko Master
  • 2,605 Answers
Hi, Welcome to "Fixya" ! You can find these lower rack support roller & clip assemblies at "repairclinic.com" for around $10ea. Their part number is 1156665. They are really easy to change as you may already know, they snap in place. Hope that is the answer you where looking for, let me know. Thanks for visiting "fixya" with your inquiry. Please take a second and rate my answer accordingly or if more assistance is needed post a reply. Good luck. Macmarkus :)
Posted on May 04, 2010
Where can I buy new loading baskets for my DWI 160 dishwasher?
These come as several parts. Not sure if all are available anymore as Candy parts. But you can get replacement Hoover parts to fit.
Main basket from Candy
Candy DWI 160W UK Dishwasher Basket
Cutlery basket from Candy
Candy DWI 160W UK Universal Cutlery Basket
The Upper and Lower baskets may not be available from Candy but Hoover replacements are
Candy Use HVR41022779 Lower Basket
Best to ask Candy support to provide pictures of the parts for comparison with your model or purchase or a refund policy if not suitable.
There is another site worth checking (but prices seem high)
CANDY DISHWASHER BASKET LOWER for DWI160W UK
Sep 23, 2014 | Candy Dishwashers
Replace Belling/Stoves/New World dishwasher upper basket runners
Take and remove the sides. There should be small stainless steel nuts holding them.
If they are like these, it looks like you slide them off to the end of the rail. Another possibility is that you pinch that angled piece down with needle nose pliers.
8 Upper Basket Rack Wheel Small Wheels for Belling Dishwasher 25mm eBay
Feb 12, 2018 | Dishwashers
Leaking from the bottom of the disposal in the connection area.
Disposals rust out and need replacement.
Check a couple things first.
Run paper towel around top of disposal to see if moisture is leaking from around sink basket or dishwasher hose connection. Then check where tailpiece connects on side of disposal.
If these places are dry, the disposal has probably rusted out.
I wrote instructions for disposal replacement:
When I worked apartment maintenance, we replaced disposal with same brand disposal.
That way we didn't have to change out sink basket or change pipes.
How to change disposal: Disconnect p-trap and tailpiece going into disposal.
Rotate connector disk clockwise that holds disposal to sink basket.
Before installing new disposal.
Attach electric wire to new disposal.
Attach dishwasher tube to new disposal. Knock out plug inside dishwasher opening.
Push new disposal up into place, and attach to old sink basket with new connector disk.
Use new connector washer.
Re-assemble tubular pipe.
If this is your home, you want new sink basket that comes with new disposal because it looks shiny and new.
Buy a tub of plumbers putty also.
Remove old sink basket and clean opening.
Put finger-size roll of plumbers putty around sink opening, and then push new strainer basket into plumbers putty.
Tighten basket from below, wipe away excess putty around sink opening.
Install new disposal as described above.
Tips for tubular pipes:
When taking apart tubular pipes, start at p-trap and take apart as few pieces as needed to do job.
On image below loosen both upper and lower nuts, trap falls loose, and then work on disposal.
Any tubular drain pipe that gets moved while working under sink needs to be disassembled, cleaned and re-assembled.
Metal pipes have rubber washer >> always use new rubber washers.
Plastic pipes have plastic washers > plastic washers can be cleaned and re-used.
Plastic washers have flat side that goes toward nut, tapered side away from nut.
When reassembling tubular pipe, we use rectorseal on washers and joints.
Apply good amount on washer just before pushing washer in place and attaching nut.
Apply rectorseal where lower p-trap comes together.
Rectorseal will ensure tubular drain pipes won't leak.
Add a comment
Dec 12, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I have a MieleG2142. One of the racks is not sliding smoothly which I believe I have narrowed down to one of the wheels in the rail guides not turning. How are the rail guides removed?
Hi dear.Try this.Pull the top basket towards you.Check on the side (if you can) back of the basket two of the wheels on top row should be on rail guide & third one just under the rail guide to support the basket.It should be even on both side of basket to run smoothly.If not pull the basket all the way towards you & lift up the basket you are holding.Basket will be free to come out of rail guide.(Please check,are the rail guides running in & out freely without basket?If not there are two plastic wheel inside of the each rail guide one or two of it must be damaged.That needs to be replaced.Please also check side wheels on the basket,they sould be freely turning.If not needs to be replaced.) If that did not work out,try to put back the basket even way to rail guide the way took it off.Contact Miele for assitants.Thanks.Goodluck.
Aug 07, 2010 | Miele G2142 24 in Builtin Dishwasher
Electrolux dishwasher wont lock but still runs, water sprays out of the door
check that the top basket wheels are not broken a rogue wheel in the runner can stop you pushing the top basket in. this stops you closing the door. also that the retainers on the end of the runners are in the right position and not jamming the door action. failing that you will need a new door lock..
Jul 30, 2010 | Electrolux Dishwashers
Wheels and basket
go to www.buggypitstop.co.uk they sell parts for bebecar
Jan 04, 2010 | Bebecar Racer ST Jogger
Lower basket is badley damaged
Replacement baskets can be purchased from your local retailer or from Bebecar U.K. directly. 01692 408807. service@bebecar.co.uk
Mar 25, 2008 | Bebecar Raider AT Stroller
Asko D1776 Built-in Dishwasher Logo
172 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
