Question about Boating
Polaris 2 stroke jetski bogs down if more than 1/4 throttle, have cleaned carb,new plugs, reeds are not missing, still get some back draft
  • 3,740 Answers
This is typical fuel starvation.
Possible causes:
1. Clogged Fuel filter
2. Dirty fuel tank fuel pick up screen or tank outlet hole
3. Cracked fuel line
4. Fuel mainfold screen clogged on the side of the carb. Plastic screen is inside of the manifold where the mounting bolt is
5. Pinched fuel line
One other thing it can be is a severely clogged clogged air filter. Usually if the air filter is clogged the plugs will foul often and fuel consumption will be high with low engine power.
Thanks for using FixYa.
Kelly
Posted on May 04, 2010
  • Kelly
    Kelly May 08, 2010
    Last thing that can cause it is debris in the float needle.
    or....
    the float level is too low.
    If the float level is too low any banking from hard or sharp turns would cause hesitation or stalls.
    Kelly
2001 Yamaha XL700 Waverunner bogs down after running for 30 min
did you replace all diaphrams in carbs and fuel pump ? balanced the carbs ?
Jun 07, 2012 | Yamaha Boating
I hve a yamaha 1995 jetski an bogs down sumtimes on acceleratiotion.
Sounds like you might have a little water in your fuel system, check the fuel filter for water then clean carbs, dont forget to check the gas tank for anything sitting in the bottom.
May 01, 2012 | Yamaha 12V Air Pump
Need a new carb or find a cheap rebuilt one at
check if ur gas line is workin rite take off tank, off n on 'switch if not that clean ur carb i had same problem clean off n on switch on gas tank if that aint problem ur carb is clogg some weres or just dirty
Apr 11, 2011 | Polaris ATV
2001 polaris scrambler 90 will crank and idle all day long, but when you try to throttle up, it bogs down and dies. carb has been cleaned, new plug, exaust is clear of blockage, still has same problem
I dont have a solution but mine is doing the same as the posted ones--runs at idle but bogs down with fast fuel feed!! does anyone know the solution?
Sep 05, 2010 | Polaris ATV
Hi I recently bought a Kawasaki kdx 80.I've been riding it for about a week and has been fine,but a few days ago I filled the tank with premix 35:1 I think and not saying that's what did it but since then...
Black dry deposits are indicitive of a very rich mixture. On your two stroke, rich is a asset but you can go too rich. It sounds like for some reason you're getting too much fuel.
I think I ran into something like this before on a Kawasaki 80. Check the screws that holds the choke plate inside the carb. They will come loose and allow the choke to close on you while riding the bike. If the screw comes out, it will go into the engine and cause serious damage. If the screws are loose, them out one at a time and put a drop of Loctite 271 (red) on them and reinstall them.
Check the float and the needle and seat to make sure that you don't have any trash in the needle and seat. Also check your tank vent. If the tank builds up vacuum, you could be running out of fuel. Sounds funny that you can be running rich but run out of fuel. The problem is that you run out of fuel so quickly that the carbon from the rich mixture doesn't have time to burn off.
Good Luck
Steve
Aug 25, 2010 | kawasaki KDX 125 Motorcycles
2004 sportsman 600, bogs down bad at half throttle.
Check that your choke is working correctly
Your timing may be way off as well
Mar 08, 2010 | Polaris ATV
330 Magnum bogs down.
NO! Check the boot between the carb and engine. Very common problem for aged rubber is non-visual cracks. Pull it off and check the boot by kneeding it and looking at it under a light.
Jan 15, 2010 | Polaris ATV
Bogs down & spits back through carb.
Sounds like you may need a valve job. Have you been keeping the valve clearances adjusted? It's important to do that on a four-stroke engine. Check your compression to find out if the valves are ok.
Sep 19, 2009 | Polaris ATV
2003 Suzuki RM 125 with no power band.
Scatter gun approach > thoughts to check out > > >
Clean and dry the air filter? Go back to a stock main jet, at least to check things out? Are "O" ring seals on the main jet going bad?Partial internal collapse in exhaust (remove exhaust pipe & do a quick run down the alley), Install a new stock NGK spark plug, Be sure battery connections are clean and tight, Be sure intake manifold and carb are good and tight.
Hope this helps!
Apr 03, 2009 | 2003 Suzuki RM 125
Boating Logo
302 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
