Question about Dishwashers
Diplomat dishwasher ADP 8332
I have a leak in the bottom of the dishwasher, after removing the door panel and bottom panel i found a big pool of water, I mopped up the water, reset the machine, tried to use the dishwasher whilst the panel was still off only to see water still leaking leaking through the pipes, is there anyway this can be fixed?
  • 1 more comment
  • nevj Mar 26, 2008
    same problem, but can see water flowing over the top of the pipe which is the inlet. I have tried reducing the water pressure, but still the water flows into the dishwasher, but also backs up and floods
  • Anonymous Mar 22, 2014
    water on top dishwasher is not coming into machine
  • Anonymous Mar 26, 2014
    water is leaking from bottom of door
  • 25 Answers
If the pipes are cracked you may be able to get new ones from a local appliance parts dealer. If the fittings are the problem Check with the formentioned.
Posted on Mar 26, 2008
SOURCE:
I have a Diplomat Fully integrated dishwasher model ADP 8242 when put on any program it fills and seems to be washing then stops after 5 minutes and the dispenser door has not opened. There is a lot of...
Check the small drain pump. Possibly its asking the pump do drain to allow for fresh water, but because low level is not detected it shuts down. The dispenser draw normall opens when the hot wash cycle starts.When you think its washing,briefly open door and see if eater is spraying out of the nozzels.If no water visible, check the main wash motor for sticking
Sep 24, 2009 | Dishwashers
Diplomat dishwasher bleeping showing FA
We have just experienced an FA audible error on our Diplomat ADP 8332 dishwasher...after pulling the dishwasher out and removing the low front panel we found the drip tray full of water. We tipped the dishwasher onto it's front and removed the drip tray and found a float pressure switch...it appears that once the drip tray is full the float switch activates and causes the FA fault (prevents the dishwasher from continuing) drain off your drip tray replace all covers and you should be good to go!!
Sep 16, 2009 | Dishwashers
Diplomat adp 8520 dishwasher no hot water
two things to check
check continuity thru heater
remove outer door panel and check for faults in wiring loom
get back to me is these are both ok
Nov 14, 2008 | Dishwashers
I have a Diplomat ADP 8520 dishwasher (possibly SMEG manufacture) which will not stop trying to empty. There are 4 leds lit reading left to right and it beeps. I have read on some forums about pressing the...
fault is probably water in the bottom tray operating the anti-flood device. take bottom front panel off and mop out the water and it will work. if fault reoccurs then you have a leak
Nov 05, 2008 | Dishwashers
Diplomat Dishwasher Model ADP 8132
Please can you give me the dimentions of this Dishwasher Diplomat Model ADP 8132, as I have got to get a replacement and have been told that the Hotpoint FDL570X is the replacement offered,Many Thanks,
Mar 28, 2008 | Dishwashers
Diplomat dishwasher adp 8322
i had same problem and have found that under the lower basket the connecting bar to the spray arm had become detached this can be reattached by inserting the two nozzles back into position and pushing down youll see what i mean ! however i have found i now have to do this after every wash ,am currently onto diplomat to rectify this completely , hope this is any use.
Mar 09, 2008 | Dishwashers
Dishwashers Logo
880 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
