Question about Plumbing
How can you fix a moving base of a tap on a sink, tried tighten it and still did not work.
  • 2,100 Answers
Is it a conventional tap with the 3 pipes or just the one hole in the middle with a cover for the other holes in a replacement? Are the nuts on the bottom of the pipes? To tighten it up? Or did the plumber just put on the supply lines and hope that would work?? Check it out, I made a wrench out of a piece of 1 inch pvc schedule 80, cut a slot with the band saw on one side about 4 inches for the supply line, then cut out the other side about 1 inch for the wing on the nut. It worked perfect. I couldn't get up there to replace the faucet, and that wrench with the T-handle didn't do diddly. Check it out, see what he did under there and tighten it up. Hope this helps.
Posted on May 04, 2010
Moen cathedral keeps coming loose and it base moves when you rotate the spout from sink to sink.
tighten the lock down nut under the sink , also,, unscrew the cap (at the base of the spout,, and Lube the O ring ( with either plummer grease if you have it, or if not with vasoline) this should cure your problem
May 04, 2011 | Moen Monticello Single-Handle Kitchen...
Single lever moen kitchen tap base of unite moves when swinging tap from side to side. Looking under sink I see a nut attached to a threaded spindle, how do i tighten it up, there is very little space for...
A "basin wrench" is the special tool you need. They are pretty cheap. Any hardware or home improvement store carries them. They might even have them at Walmart. Google images for basin wrench and you will see lots of illustrations, including how to use it. Good luck Please vote if you found this helpful Al K
Apr 01, 2011 | Garden
I have a pegasus sink and I'm having a hard time getting the drain not to leak. The base of sink if thicker in the front than the back so when we tighten the drain it will only tighten so much in the back...
You need to take it off copletly and clean it then take 100% clear silicon put it down on the sink base and on th e bottem lipe of the basket strainer tighten down till silicon sqeezes out top of sink wipe with paper towel and wate 24 hours befor use.
Jan 21, 2011 | Pegasus Technologies Pegasus Kitchen Sink...
The base of the faucet which fastens to the top of the granite is loose and moves around. Is there a nut under the faucet that tightens to keep it firm to the granite? How do I fix this?
yes there is, with a pair of slip joints you can tighten from underneath, it is above the supply line, the best thing to do is turn off the water, disconnect the supply line and tighten the nut, then reconnect the supply line and turn back on the water. Good Luck Tim
Oct 31, 2010 | Grohe 32 999 KD0 Alira Pull-Out Spray...
I can't get the faucet to not move from side to side after it is tightened donw on the granite vanity top. The base is tight and does not move, but the faucet part still moves a little. How can this be...
The faucet should have come with a rubber gasket which goes between the faucet body and the granite top. Make sure it's properly aligned and has not slipped out of place. Be carefull when tightening the faucet to the granite, since granite is easily cracked.
Aug 10, 2010 | Moen 6102AZ Kingsley Single Handle...
Hi While I try to rotate the tap , the whole base is rotating with it ( delta 470 ss)
A "basin" wrench will be needed to get up under the sink/faucet base to tighten the nuts that hold the faucet in place. It's a simple job but requires the agility of a contortionist to get at.
Apr 26, 2010 | Delta Model 470: Signature Kitchen...
I have a Moen Monticello bathroom faucet. I am
Moving left to right: I am not an expert, but I have installed a fair number of faucets. Seems like a basic issue of just getting under the sink and tightening up. Make sure someone is topside to assure the faucet stays straight and does not move as you tighten up below. It is never easy to get a wrench and your hands in the proper position to tighten up the nut, but don't give up try a smaller Channel lock wrench if necessary.
Sink Stopper: http://www.lowes.com/lowes/lkn?action=howTo&p=Improve/PopUpStop.html
Jan 02, 2010 | Moen Bathroom Sink Faucet - 4-inch...
I have mixer taps fitted to my kitchen sink which leak from under the mounting seal when the taps are turned on.when the taps are turned off the leak gradualy stops and the actual tap never leaks,do the...
It appears that the seal at the base of the tap is worn or the screw collar is loose - try hand-tightening it. It may cure your problem. Plumbers tape is a white tape that helps seal water pipe joints!
Oct 08, 2009 | Plumbing
Can't tighten single handle moehn kitchen faucet
there is supposed to be a nut with a washer under the sink in the center, the metal plate is just for decoration, the nut and washer have to be installed before the sprayer is attached the stem that it connects to has threads on it for the nut your faucet should have came with a long socket made of plastic to install the nut
May 30, 2009 | Moen 87530 Touch Control Single Handle...
Plumbing Logo
113 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
