Spilt liquid on remote control for DV832B Digital Freeview Receiver. Is it possible to get replacement remote control
PURCHASED NEW REMOTE CONTROL
Posted on Mar 27, 2008
Hi I need a remote code for veon sat101 freeview box please. I have a all in 1 remote but there are no codes for veon Sat/ freeview boxes
You may have to try a different universal remote control. All universal remote controls do not contain all possible codes.
Jun 10, 2017 | Televison & Video
I hava psvr71 vcr and a new Sharp Asquos tv and I cannot get the vcr to record. It will play back but not record.
The VCR doesn't have a digital tuner. It has an analogue tuner. So it won't pick up the digital TV transmissions. You need a Freeview box connected to the house aerial system, and then connected to the VCR by a SCART lead. Put the VCR on one of the AV channels so it "sees" the signal from the Freeview box as a predicament for its own tuner.
Some older TVs had a video out function. This no longer applies to new TVs.
Sep 15, 2014 | Proscan New Original PSVR71 Remote Control
How do you switch Orion tv back to freeview without the remote? Because I have lost the original remote
remotes.com will have a replacement remote. At least they should. You can check on ebay or amazon too. Otherwise google the model number of your freeview receiver AND remote And you should pop up with several options. If your TV doesn't have the buttons you need to switch over than you absolutely will need a new remote. AND as an FYI, not all universal remotes work with freeview so it's better to find one compatible with your specific device.
Wish you luck.
Mar 10, 2011 | Televison & Video
Cant get freeview channels using one for all remote
Not all Universal remotes can work with your Freeview Devices. You need to find one that will work for your specific device AND your TV. Many Universal Remote Designs predate Freeview construction so a lot of them only have basic function. You need to Google the model number of your Freeview Receiver AND "Remote" to get a remote that will operate it.
Very common and yes probably irritating too. Sometimes technology just doesn't evolve as fast as others do. This is unfortunate. Wish you good luck!
Mar 10, 2011 | Universal Remote Control Universal Remote...
Can not turn tv off with remote control
Check the remote if it is putting out pulsating infrared. Point it to a pc cam and you should see the pusating light it is emmiting if it is good. Pc cam can detect infrared waves. This will at least confirm if the remote is functioning. If everything else is working exept the power button then carefully open the remote control and clean the contact to where the power button is. Sometimes liquid spilt on the remote dries up causing bad contact.
Mar 06, 2010 | Televison & Video
Retuned my Freeview receiver but now have black bars.
The retuning process is as follows:
  1. Press the [i+] or MENU button on the remote control to display the DIGITAL INFO menu.
  2. Press the BLUE button to display the MAIN MENU.
  3. Press the UP or DOWN buttons to highlight AUTO TUNING then press the OK button to display the AUTO TUNING MENU.
  4. Press the RED button to start the auto tuning process for all available digital channels.
  5. Wait for the process to complete.
If you wish to CANCEL the auto tuning process whilst it is processing then press the BLUE button at any time.
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box.
For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/
For specific model information visit http://tvretune.co.uk/productmanuals/
Oct 01, 2009 | Sony BRAVIA KDL-40V4000E 40 in. LCD TV
WHARFEDALE FREEVIEW DV832B USER MANUAL
Please find the link to the manual as requested:
http://new.superfi.co.uk/extras/Wharfedale/wharfedale-DV832B-manual.pdf
Please let me know if this is the information you are looking for.
Please rate me if you are happy with the resolution.
Sep 13, 2009 | Televison & Video
Remote control doesn't work
If you feel confident about taking it apart and putting it back together, I suspect "gummy" keypad and touch pad on circuit board. Use rubbing alcohol and clean both keypad and cct. board with a tissue. Let dry and inspect for black traces on circuit pad. re-assemble and test. This is not a long term solution.
The other possibility is that liquid was spilled on the unit and into it.
Good luck.
Oct 29, 2017 | Televison & Video
I have a Wharfedale Digital Freeview Receiver LPDV832B, having set this up following the instructions provided it appears I am not receiving all the freeview channels available ie BBC1, please advise.
It is very possible that you require an aerial upgrade to receiver all the digital channels available, you should check with a local aerial installer.
SUPER8
Nov 16, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
