Question about Cuisinart DCC-1200 Coffee Maker
My cuisinart coffee maker won't brew coffee. Suddenly it stopped working (only about a mo. old) the water all fills up, but won't blew the coffee, so I'm left pouring it all out of the top?
THEY WANT ME TO PAY TO SHIP IT TO THEM AND TEN DOLLARS FOR GETTING IT BACK!!!!!!!!!! GET A MR COFFEE- I AM GOING TO SEND IT NEXT WEEK, BUT THIS IS BAD CUST SERVICE- HOWEVERA CAPS sorry- no coffee ye, your orig post helped me alot- thanks
Posted on May 28, 2014
  • 13 Answers
SOURCE: Cuisinart coffee maker turns on but will not brew.
Well, you could try unplugging for an hour. Sometimes that helps, but these have been having a lot of problems (but don't ask their customer service that, they can't admit it but I'm pretty sure they all know it!). I would say call customer service anyway if it's under 3 years old (800-726-0190) after you've unplugged it and let them know what's going on (model and serial # are both located on the bottom of the unit, stamped in the black part). If it's under warranty they can offer you a replacement and from what I hear Cuisinart has been getting in new coffee on demand units (like the one you have) that have fixed the problems. They're on back order right now though, so there will be a wait. Other than that, I would say you don't have many options, unless the store is willing to take it back, because this one is pretty much a goner. Not the first time I've seen it. :(
Posted on Aug 28, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: cuisinart Grind and Brew 10
Replacement time. a certain percentage of thse have this problem. There is a small, non-replaceable tube in the inside toward the bottom that has become melted/damaged.
Posted on Dec 17, 2008
  • 4 Answers
SOURCE: my 12 cup cuisinart coffee pot keeps shutting off
I have the same pot except for the 10 cup model, and it has been doing the same thing. I realized that I have never changed the charcoal filter inside, and I believe that may have been the problem. I removed the filter, ran vinegar through the pot several times as well as cleaned some nasty looking scum out of the water reservoir. I ran 3 pots of water after that. The problem has not recurred so far. I think it may be fixed although time will tell for certain.
Posted on Mar 27, 2010
SOURCE: Leaking cuisinart grind and brew
Our Cuisinart grind and brew was leaving a puddle under it after making a pot of coffee. I called Cuisinart this week and it turns out the handle of the carafe has to be lined up in the middle of the opening for the carafe. It will be under the word Cuisinart, in the middle.
We have now made several pots with NO residual puddle of water or coffee. It also seems to be making the pots quicker.
Before trying this I had run 2 pots of water with 1/2 cup white vinegar in it also. But it still puddled until we lined up the carafe as noted above.
Posted on Jan 16, 2009
SOURCE: the heater plate on cuisinart cbc-1600 coffee
Called the company and the representative told me that on the CBC 1600 series, it is intentially designed to turn off the hot plate after brewing because the stainless steel carafe will keep the coffee hot. If you are experiencing poor heating, her suggestion was to preheat the pot with really hot water before putting it under the basket. I can't help wondering if they have turned a bug into a feature
Posted on Jun 16, 2010
We've had a Cuisinart DCC-2000 coffee maker for less than a year: 1) it stops brewing about halfway through the brewing cycle (with plenty of water still in the reservoir, and 2) the "Clean" light
This problem is caused by a clogged water filter in the unit.
Unplug the coffee maker.
Open the top panel where you normally pour in the water and set the coffee filter.
Gently pull up on the tap that sticks up in the back left corner of the open top. This will free a long plastic part that has a compartment at the bottom that contains a filter filled with charcoal.
Unsnap the small compartment that holds the filter and clean it gently under running water with light brushing.
If there is a lot of coffee build-up, the water chamber where you normally pour in fresh water needs to be cleaned out. Pour in a cup of water and invert the unit over a large sink pouring out the water through the opening you normally use to fill the unit.
Repeat this until you remove the coffee grounds.
Let the unit dry fully before plugging in to run again.
Sep 30, 2012 | Cuisinart DCC-1200 Coffee Maker
Won't finish brewing
We were having the same problem of it quitting the brew cycle about 1/2 way through. We put a mixture of 5 cups vinegar & 5 cups water through followed by a pot of just water and now it works like new. The vineagr must clean some sort of built in sensor.
May 30, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
DC2000 Cuisinart Coffee On Demand will not brew
on my dcc2000 when brewing on automatic timer it only brews a part of the reservoir . Say 2 or 3 cups out of the 6 I fill to.
Apr 14, 2009 | Cuisinart DCC-2000
Cusinart DGB 550BK coffee maker not working properly
Cuisinart Coffeemaker Decalcification Process
Run 2 cups distilled white vinegar and 2 cups water through the system - brew it like it was regular coffee. Then run plain water through the coffemaker to rinse the vinegar out and make sure the decalcification was successful. Repeat as needed. Don't forget to remove the charcoal water filters first.
-Tha Mp3 Doctor
Jan 12, 2009 | Cuisinart Coffeemakers
When brewing, it steams and spits the water out
this is what happened to me, I didn't have the filter basket all the way down so the pot lid didn't open the valve that lets coffee flow so the coffee and grounds ran into the water resevior and plugged the filter, so I did the worst thing possible and took the filter out so the grounds got into the check valve that keeps the hot water going in the right direction. that makes it spit and sputter and brew slow.
after trying to flush it out forever I tore the metal plate on the bottom off and unhooked the rubber hoses (don't do this unless you have a needle nose pliers, you'll never get them back on) one should go to the brew head and the other is the water inlet, this has the check valve. you can tell which is which by blowing through them and seeing which one goes to the brew head. if you can blow through the other one the check valve is stuck open, I blew air into it with an air compresor and this forced the check valve shut and now it works fine. I know this is the same symptons as calcium deposits but I had cleaned it twice.
try flushing it with water first but sometimes it takes extreme measures
Jan 11, 2009 | Cuisinart DCC-1200 Coffee Maker
Cuisinart Coffe Maker has no power
Cuisinart replaced the coffee maker. It was still under the 3 year warranty so Cuisinart told me to take it back to one of the stores that sells Cuisinart coffee makers because the store I bought it at was going out of business.
Nov 21, 2008 | Coffee Makers & Espresso Machines
This happens when the machine needs cleaned. Fill coffee maker with white vineger instead of water. Turn grind off, make sure empty pot is in place. Brew a pot of hot vineger. Repeat. Brew a pot of hot water. Repeat. This process removes mineral buildups inside machine. If you have access to filtered water, start using that to brew your coffee. I do and probably do this process 1 per 6 weeks.
Oct 07, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart grind & brew coffeemaker DGB-500C
Could be electrical, but I would unplug for 20 minutes or longer and then clean with vinegar/water soltuion (2 cups vinegar, 2 cups water).
-Tha Mp3 Doctor
Jun 16, 2008 | Cuisinart DGB-500 Coffee Maker
Cuisinart DCC-1200 Coffee Maker Logo
2,625 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
