Question about Compaq Presario 700 470024-192 Notebook
Audio driver for compaq presario c700 PC Note book
I am using above mentioned model the problem i am facing is in audio... it show there is not driver installed, though i have the driver cd with me it is not supporting for win.xp.pro. where can i get the drivers for the same.
  • 13 more comments
  • tings101 May 08, 2008
    i have the same problem with the others...my notebook is complete formatted with windows xp...but the problem is the audio drivers...how can i solve this problem pls help me....
  • hishareef Aug 23, 2008
    i want audio drivers for compaq presario C700 note book
  • Anonymous Oct 03, 2008
    MY COMPAQ C700 PC NOTEBOOK NOT ACCEPTED HD AUDIO DRIVERES.
  • Anonymous Oct 10, 2008
    yes i have a pb when i installed aaudio device it told me that media device is not found and not i get sound. what can i do?
  • amandeepsand Nov 03, 2008
    i was installing sound drivers but no media was found to support
  • Anonymous Jan 01, 2009
    same as mentioned
  • Anonymous Jan 20, 2009
    please send me the driver of compaq Presario C700 driver for XP
  • palpalisalik Jan 24, 2009
    I am not able to install sound and modem drive after i installed windows xp. My notebook is compaq c700 series.
  • Anonymous Jan 25, 2009
    Hi, i am not able to instal audio driver , when i instal ,msg comes by saying that media driver not found for this device.
    please advise.
    i am not able to install sound driver for win xp
    same problem
  • mukhraiya Feb 10, 2009
    Yes i have this problem.My sound driver is not install in my laptop
  • Anonymous Mar 11, 2009
    my problem is that if you check in Sound and Devices in Control Panel it shows no Audio device installed. When i have installed it. Please help me out.
  • shivgabbur Mar 25, 2009
    iam having acompaq presario bazel c700 sound driver & conexant also but it cant work or play songs
  • saurabhve94 May 11, 2010
    audio driver for compaq presario c 700 pc note book
I have successfully installed all the XP drivers on the Compaq Presario c700 and successfully removed the bloated pig P.O.S. known as Vista.
You must download the following from Compaq's site:
Driver numbers:
sp34510 - Wireless assistant
sp33411 - Nvidia Chipset
sp33258 - Quick launch
sp35444 - Touchpad
sp36684 - Wireless LAN
sp35682 - Win Audio Bus + updates
sp33549 - Nvidia Video (Go 6150)
sp35270 - Conexant HD Audio
sp34427 - Conexant Modem
These are found all over the HP/Compaq web sites. You'll need to search for the number "sp35410", etc. Some of these are available under the driver pages for the F557US. You'll need to look under both the XP AND Vista sections!!!!
Now, the tricky part!! Listen CAREFULLY!!!! You must:
1. Install all of these drivers one by one, making sure NOT to run the sp33549 (Nvidia VIDEO), sp35270 - Conexant HD Audio, and sp34427 - Conexant Modem drivers!!!! Important! Then, reboot.
2. Run the sp33549 Nvidia Video driver file. It will FAIL! Once it has run, it will create a folder with this path: C:/swsetup/sp33549. Open the control panel, then system, then hardware, then open the device manager. Find the video controller with the yellow exclamation point. Right click, and select properties. Click the 'driver' tab at the top, and then select "update driver". Select 'not this time', then 'Install from a specific location', then select 'don't search', and then finally, select 'have disk'. Select the folder above, and that will manually install the video driver.
3. Do the exact same procedure for the sp35270 Conexant audio card, which will be in the device manager under 'PCI device'. Of course, make sure to use the C:/swsetup/35270 folder this time.
4. You can just double click the modem driver sp34427 to install it, but this must be done AFTER you manually install the Conexant audio!!!!
5. Since it took me three hours to figure all this out, you then send me an e-mail to thank me!
Vista sucks. Be happy you now have XP on this new laptop!!!!!!!
Posted on Dec 23, 2008
    President:
  • 1,944 Answers
Search for the drivers via Windows Update. It will find the right soundmax driver for your sound card. I had this exact problem yesterday on the same laptop.
Posted on Mar 26, 2008
    Novelist:
  • 85 Answers
First u have uninstall audio drivers from device manager......also uninstall UAA bus driver for high defination hd driver form system device in device manager......restart your laptop
and always turn off your automatic updates..in this laptop.
go to the hp.com then search box type this (sp35270) for audio, (sp33442) for modem, (sp32395) for UAA. then run all setup files......
Open device manager and right-click on Audio device on High definition Audio Bus.
Select Install from a list of specific location (Advanced) Click Next
Select Don’t Search. I will choose the driver to install.
Select Sound, Game & video controller from the list of Hardware type
Click on Have Disk
Click on Browse and navigate to C:\swsetup\sp35270 and click on .ini file OK
Click Next
It will give you an update driver warning message. Click on yes.
It will start installing the driver
Click on Finish..
follow these steps to all drivers install.
good luck..
The best earn money site..plz signup free
http://bux.to/?r=jiteshright
(Join now and receive a $0.05 Sign-up Bonus)........click on it........
Posted on Dec 17, 2008
I'm using Compaq Presario C700....but I don't have driver for its audio....although I have cd with me,it doesn't support my windows....
Posted on Oct 10, 2008
    Problem Solver:
  • 11 Answers
Friends,
Compaq Presario 700 PC Notebook's main problem is audio driver for win xp.
For Audio driver software you can visit a link by just
Click Here .
For any other problems with this Notebook you can
Click Here .
Posted on Jul 22, 2010
Go on zyxware.com
and in search box type driver for c700
the download all driver from this site
go in device manager
right click on audio device on high definition
update driver
choose from a specific location
click on have disk
click on conxeant diver
finish
Posted on Feb 10, 2009
    President:
  • 1,257 Answers
First install microsoft universal audio driver from the link below and after that install audio driver
Audio Drivers
link 1 :microsoft universal audio
ftp://ftp.hp.com/pub/softpaq/sp33501-34000/sp33566.exe
link 2 :conexant high definition audio
ftp://ftp.hp.com/pub/softpaq/sp36001-36500/sp36090.exe
_____________________________________________________
If this answers your question please rate this as fixed.
Thanks for using fixya support..You have a wonderful day
Posted on Jun 04, 2008
2 Suggested Answers
SOURCE: I have HP compaq Presario C700 note book drivers
problam the sound driver
Posted on Apr 19, 2009
Could somebody help me fix my compaq presario c700? there is no sound coming out from the lap.i am using Windows 7 operating system. i found some driver of my model in net n installed it then also i am...
here is your link and serch the audio driver, downlaod it and install. http://notebookblogonline.com/compaq-presario-c700-drivers-windows-7-free-download/
Jun 09, 2012 | Compaq Presario 700 470024-192 Notebook
Audio driver not detecting in xp of c700 laptop (vista supporting) high definition audio driver needed
Download High-Definition Audio Driver Or
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&dlc=en&cc=uk&lang=en&product=3626963
If still face the same problem then search the model no and follow the below web site.
» Compaq Presario C700 CTO Notebook PC
» Compaq Presario C700EM Notebook PC
» Compaq Presario C700ET Notebook PC
» Compaq Presario C700LA Notebook PC
» Compaq Presario C700T CTO Notebook PC
» Compaq Presario C700XX Notebook PC
Jul 11, 2009 | HP Compaq Presario C700T Notebook
what exactly is the model number ? C700 is not enough
it might be C700 CTO or C700EM or C700ET
have a look at the exact model number on the back side of the laptop
Apr 19, 2009 | Compaq Presario Notebook
Wireless drivers not available in my compaq presario notebook c700
Hello Madhu,
Here is the weblink of all the drivers for your laptop. Download the wireless drivers and also any other drivers you need:
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&dlc=en&cc=us&product=3559331
Thanking you, Best Of Luck.
Oct 26, 2008 | Compaq Presario Notebook
Compaq presario c700 notebook pc sound driver
hi
i hav a laptop Presario C700 sound drivares downloads free
pls
Sep 04, 2008 | Compaq Presario 700 470024-192 Notebook
Audio and Wirless driver for compaq c700, model - C765TU
I'm looking for a Wirless driver for compaq c700, model - C765TU. Pls help
Thank you
May 25, 2008 | Compaq Presario 700 470024-192 Notebook
Compaq Presario 700 470024-192 Notebook Logo
5,028 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
