Question about Raymarine St40 Depth Display E22038
I bought a st40 for my wooden boat but am now told that i should have a bronze transducer and not nylon (plastic) for this application. Is that right?
  • 64 Answers
Either transducer will work. Just make sure you seal the transducer properly and everything will be ok.
Posted on Jun 14, 2010
Testimonial: ".. we have installed the nylon transducer keeping in mind the swell of the wooden hull and have not experienced any problems ..yet !! :O)"
Why does my st40 bidata read a maximum 1.3 knots in any conditions. I have checked the paddle wheel, it is running free and all 4 paddles are in place?
Even the smallest amount of friction can keep the paddle wheel from turning properly. See if it will turn if you blow on it. If not, there might be something impeeding it from turning easily.
Apr 29, 2014 | Raymarine St40 Bidata System Depth/Speed...
Gps problem
If the new harness / parts are listed for use with this model GPS, it should work - unless you have miswired something. Double-check your work. Make sure all connections are made up tight. Pay particular attention to the ground wire. Relying on the boat to pass ground it not reliable. Look for damaged or cut cable from power source and transducer. You may wish to troubleshoot with a meter or a test light to be sure power is available at the GPS. Good luck!
May 29, 2013 | Humminbird 1198C SI Side Imaging High...
Raymarine ST40 Bidata Manual
Hi
I realize this question has gone unanswered for quite awhile, but here is the link to ST40 owners manuals.
-Steve
https://flir.app.box.com/s/w7dp1h5hwi1f3fmda4x1/1/402191597
Jun 18, 2012 | Raymarine St40 Bidata System Depth/Speed...
Is it posible to conect garmin 420s gpsmap to st40 deth transducer
No. St series from Raymarine are made for digital depth only, not fish finding and do not talk nmea. The only way to get that Garmin of yours to see depth would be to go from an ST40 nmea out to that garmin nmea in. Or purchase a nmea 0183 smart sensor and hook it to the garmin.
Apr 08, 2012 | Garmin GPSMAP 420s GPS Receiver
I have just bought a LSS for my boat .On the transom i have already a transducer for my HDS and also a speed wheel .my question is can i remove the speed wheel and put my side scanner next to the HDS...
well if the side scanner is a stern mount. Then opposite side would be best and scanning away from other transducer. Too much wattage and they will mix signals and give you two blank screens. You can mount together but run one at a time. Aloha
Feb 09, 2018 | Lowrance LSS1 StructureScan Sonar (Lss1...
Hello, our Raymarine ST40 depth sounder on our trailer sailer has stopped working only shows 0.00 depth on the display screen. However the metres symbol now flashes on/off. I have checked the cable...
now there is a chance that the transducer is bad ,, but I would check the battery voltage and make sure you have a soild 12 volts to the unit. also in my many years of working with and installing these units on boats I have see the needle pins ( where the plug inserts in the back of the display unit ) bend and/or break off completely. look in the plug area of the display unit and make sure all pins are intact. one more place to look for the problem is in the plug itself, take the plug apart and inspect the wire connection and make sure they are all good. if after all the above has been checked then I would assume that it is the transducer itself.
if you have anymore questions with this problem, please feel free to write back and ask,
c...
Jan 30, 2011 | Raymarine St40 Depth Display E22038
My marine speed transducer needs to be replaced. I have a Beneteua 351 which is 16 years old. I have cleaned the transducer several times and then reinstalled. It will work for a couple of minutes and then...
Yes. You need to make sure you get the same transducer though. With you system being that old, you may have a transducer that is old where there is not a direct replacement. You need to make sure you get the correct transducer. You may need to get a "flapper" kit to update your housing to the new style.
Jun 15, 2010 | Raymarine St300/P371 Speed Nylon Thru Hull...
My problem is I bought a 600l furuno and it came w/a thru-hull transducer and I wanted a transom mounted trans.I all ready bought a tr/mount and I need to sell the thru/hull.It's the 2" w/speed and temp...
i will exchange this for you, free shipping no charge, just ship it to me to inspect and i will send you the transom ducer no charge, if you have a bronze thru hull with speed and temp to trade for a plastic transom mount with speed and temp, let me know
Jul 29, 2009 | Furuno 520 5psd Plastic Thru Hull...
Raymarine St40 trouble
50/200 combination will work fine but 170/200 may be a little close in frequency and give you some trouble. "May be OK" doesn't leave me with a lot of confidence.
Jul 24, 2008 | Raymarine St40 Depth Display E22038
Raymarine St40 Depth Display E22038 Logo
130 people viewed this question
Top Raymarine Boating Experts
Steve
Steve
David Burbee
David Burbee
Are you a Raymarine Boating Expert? Answer questions, earn points and help others
