Question about RCA Televison & Video
My rca tv hd61lpw62 power button blinks five times and wont turn on tv
I have a rca hd61lpw62 makes loud noise and i lose the picture still have sound tv repair man fixed it once and said he had to soilder ballist one month later doing the same thing this time he said it was the color wheel sounds like he is just guesssing you can wait a few moments and it comes back on help please
Posted on Dec 27, 2010
Rca scenium hd50lpw166yx12 power blinks five
I have the same problem -- now it made a loud pop and just went completely black and only the sound will turn back on,... have you received any answers to this?
May 14, 2010 | RCA HD52W66 Projection Television
Power switch doesnt work. It blinks for a few seconds then turns power button goes off all together. Tv wont turn on at all.
Hi jenna;
We need a little more info like Brand, Model # and how many times the light blinks.
Good luck
Buck
Nov 14, 2009 | RCA D61W20 61" Rear Projection Television
My 52 inch rca tv power button blinks on and off
my rca tv will not power on power button blinks four times
Aug 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
The TV will not turn on.
I have the same problem, push button to turn on tv but it only does a click like it is going to turn on and then another click bit it wont turn on. Finally a red light is just blinking.
Any suggestions, is there a freeze button or code that I need to push.
Jul 03, 2009 | RCA HD52W140 52" Rear Projection...
Tv wont turn on blinks 9 times then 1 time
I was inform that it could be a sensor (bad diode), you have to get a multimeter tester and test the diodes and if current flows from both sides then replace that diode.
Nov 14, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Timer light blinks on and off and tv wont turn on
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
If ever resetting is no effect then the problem is in the "DM board"
The constant blinking green light means that the TV is not booting up. This is a common problem on this set. Hope it may help you; Regards, VOTIT
Sep 25, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Tv wont power up
if you can not turn on TV set with the power button on the TV its not astandby problem as this would by pass the standby. Theres most protec,on a set of this age, top have a poiwer regulator,vertical,horzontal/chcroma problem and is goingto need a trained tech to assist you in this repair. www.afiata.com
Aug 01, 2008 | RCA D61W20 61" Rear Projection Television
RCA remote help
I GOT THIS FROM THE RCA WEBSITE...IT WORKED FOR ME...THE CRUCIAL STEP IS TO KEEP PRESSING THE REVERSE BUTTON!!! MY REMOTE WAS THE RCA RCR312W
  1. TURN ON THE COMPONENT (THE TV, DVD, ETC)
  2. HOLD THE TV (OR DVD) BUTTON AND THE ON/OFF BUTTON AT THE SAME TIME.  IT WILL STAY LIT.
  3. PRESS THE PLAY BUTTON EVERY FIVE SECONDS until the component turns off.
  4. Each time the Play button is pressed, the illuminated ON-OFF button blinks ten times and a block of 10 codes is sent to your component. This process continues until all the codes in the Code Lists have been searched. If the component has not turned off after all codes have been searched, the illuminated ON-OFF button blinks four times, turns off, and the Auto Code Search Entry method is exited.
  5. When the component turns off, press and release the REVERSE button, then wait two seconds to see if the component turns on again.
  6. If the component does not respond, continue to press the REVERSE button EVERY TWO SECONDS until the component turns on again. This will isolate the correct code in the last block of codes sent. Each time the REVERSE button is pressed, the illuminated ON-OFF button blinks.
  7. If the REVERSE button is accidentally pressed after the component responds, press and release the FORWARD button. Wait two seconds to see if the component turns off again.
  8. To save the new code, press and release the STOP button.
  9. The illuminated ON-OFF button turns off. You must press the STOP button to save the code.
Jul 01, 2008 | RCA RCR311B Remote Control
Televison & Video Logo
215 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
