Question about Zebra Z4Mplus Label Printer
Won't print It just won't print, I've checked everything has ribbon, paper lables, then i calibrated it , and nothing. it just wont print. it says ribbon empty error
    Champion:
  • Zebra Expert
  • 285 Answers
Reset the printer to factory defult
Posted on Mar 26, 2011
Paper out error
Have you tried a full media calibration from the menu (removing 8" of label from the backing)? Also if a label has left any pieces behind on the rollers, strike plate, etc it can cause this problem. I use a solvent like Goo Gone to make it clean, but be careful not to wipe the sensors with it. Also I have seen this when my users miss a roller when loading the ribbon. Make it clean, load it carefully and usually it works.
Jul 25, 2012 | Zebra 170XiIIIPlus Thermal Label Printer
Can't get the Zebra S4m printer to align? How should I trouble shoot this? Sonya
I am assuming you mean misalignment of lable top or start of print moving on label.
check sensor for lable debris.
if OK then perform media calibration:
Enter menu and scroll to ADVANCED
press enter and use password 9999
scroll to MEDIA and RIBBON CALIBRATE
Remove a few labels and remove ribbon
Press right arrow to continue display CALIBRATING PLEASE WAIT.
When complete reload ribbon and labels press right arrow printer will feed approx 39"
printer should now print OK.
Aug 08, 2011 | Zebra S4M Thermal Label Printer
I have a Zebra Z4M printer. We use it to print on various labels - pre-printed and blank labels (semi-gloss). I've been struggling to print on one of the pre-printed labels. Everything else prints...
some labels are hard to calibrate, nee to calibrate the sensors with manual calibration.
1} go to the MEDIA AND RIBBON CALIBRATION,
2}take 2 or 3 labels from the base paber, load the way to the based paper stay unther the sensors, 3}close printhead.
4} press ok.
5} Move the ribbon out from sensors and close the printhead.
6) press ok
7) wen printer ask RELOAD ALL, load the labels correcly and the ribbon, close the printhead and the top door, and press ok. The printer run the calibration it self.
wen finish, saved (press setub twice) and test.
Jan 21, 2011 | Zebra Z4M Printer
Have X3 Zebra 140Xilll printers. These printers will stop printing with a message "Error condition Paper out". But the paper is loaded. Everything seems fine. What can I do? Thanks Steve Rolland
Check and clean the sensors, also the reflective surface. Make sure there are no lables stuck to the reflective surface. Use Isopropyl Alcohol to clean.
Jan 21, 2010 | Zebra 140XiIII Plus Thermal Label Printer
Using a eltron tlp2742. The printer spits out about twenty lables then prints one halway in the middle of a tag then stops. I have chaecked all paper, ribbon, connections and settings on printer I can...
It sounds like you should recalibrate the printer, to do this press and hold the button and turn the printer on. When the light flashes Red let go and the printer will calibrate and do a printout at the end
Oct 06, 2009 | Zebra Eltron LP 2824 Thermal Printer
My printer appears to be printing the lables but
Make sure you are using thermal paper roll and not regular label roll.
Oct 05, 2009 | Zebra TLP 2824 Thermal Label Printer
Hi, we have tbl 2844-z and trying to calibrate but the ribbon never starts at the right beginning of the label, how to calibrate?
To calibrate, press and hold the green feed button until it flashes 4 time and let go, it will reset the factory defaults and calibrate. If the print is starting lower on the lable than you want, you will need to adjust the label layout from the application.
Jul 10, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Dell Photo 926 AIO "Load Paper" error
Solved myself: I reseated the 4 internal wire harnesses and ribbon cables. None of these were obviously loose, but it seemed to do the trick.
Jan 06, 2009 | Dell 926 All-In-One InkJet Printer
PRINT WILL NOT STAY ALIGNED ON EACH LABEL-RUNS ONTO NEXT LABEL
Check the tension on the Ribbon Take-up Spindle there is a nut on it that sometimes can loosen or tighten its self and will throw off the lables. Its a nut that has a of couple Hex nuts on the corner, screw the nut to about the 3rd thread from the top of the bolt facing you then tighten the hex nuts on the corners of the nut. Then try printing the labels make sure the media guide also is set to the lable size that is installed.
Dec 19, 2008 | Zebra 105SL Thermal Label Printer
My hp 1610 all in one
Is the color missing on the calibration page? Maybe some color or cartridge is empty and the printer can not calibrate... Without calibration no work !!!
Sep 04, 2007 | HP PSC 1610 All-In-One InkJet Printer
Zebra Z4Mplus Label Printer Logo
210 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
