Question about HP PAVILION M8200N PC Desktop
Installed new hard drive. Computer won't restore
Installed new hard drive. Computer won't restore with disks from HP.
    Problem Solver:
  • 9 Answers
I'm guessing that if you look through the hard drive folders you will find the problem. Keep trying.
Posted on May 04, 2010
After installing a new hard drive in my desktop computer, it still does not work. It says no boot device available. Sata's 0 & 1 installed but 2 & 3 uninstalled
No boot device available means the boot device hard drive on your system has no bootable operating system installed on it, or it is faulty. In the BIOS setup program, does the computer recognize the hard drive you installed, and is it included in the boot device list? If you installed a new hard drive because of a failure of the C: drive, the new hard disk does not come with an operating system. You have to install that on the new hard drive from the manufacturer's system restore disks. SATA channels 1 and 2 are just the connections on the motherboard for devices, and usually have a hard drive on one connection and a cd rom drive on the other. Giving the model and manufacturer of your computer might provide more clues.
Feb 04, 2017 | Hard Computers & Internet
Recovery discs won't install windows on new hard drive
sad to say but probably have to buy a new operating system disk .
May 13, 2015 | HP Computers & Internet
Windows vista recovery cd I created won't install on new hard drive
Which software did you use to create the recovery disk? Is the recovery disk a CD or DVD?
Just to recover a vista system from recovery DVDs would require at least two DVDs. Your files would be in addition to this so I would be very surprised if you have only a single disk containing both the operating system and all of your files.
A simple recovery disk would only be useful for restoring lost operating system files to a hard disk that had corrupted or deleted files. It would let you restore to a new blank disk.
If the disk only contains a backup of your data then you would need to first install an operating system (Vista or Windows 7) and then install the backup software you used to create the disk and then you could recover your data from the disk.
Jan 05, 2013 | HP Computers & Internet
I get a disk read erroroccurred after I have installed a new hard disk. How can I get my computer going again?
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Aug 15, 2012 | HP Compaq nx6325 Notebook
Laptop won't boot. Caps lock and numeric lock lights are blinking. It was working fine after I installed a new hard disk and restored the whole system using my recovery disks and backup. I installed...
Don't restore the system to a hard disk of different size. You may fix the old disk again and use it while using the new (probably larger) disk as an external disk (by fixing a driver bay).
If you want to use the new disk you will have to install the operating system and software from scratch.
Jul 27, 2011 | HP Pavilion dv5-1004nr Notebook
I bought a new hardrive for my m2000 and when i load it it is giving me a "media test failure" response..... how do i load it properly?
If you bought a new hard drive (meaning the internal hard disk), it won't have anything on it. If you just install it and try booting your computer, there won't be an operating system to load. The BIOS (the operating system built into the motherboard) is set up to try loading the operating from connected devices in a certain order. Usually it tries the optical drive first, then the hard drive, and finally it tries to boot over a network connection. The media test failure message means it tried that last resort and still didn't find an operating system, and it's telling you that maybe you have a bad network cable.
You'll need to reinstall your operating system and applications so that the computer will start normally. If your computer came with a restore disc set, or you made a set yourself, you'd use those. If you don't have restore discs, you can do a fresh installation of Windows from CD. You need to find the disc for the version that came installed on your computer, since you'll need to use the product key from the sticker on the bottom. Drivers and utility programs you can download from Compaq's (HP, actually) support and drivers website.
Once you've got a bootable Windows system on the new drive, you won't get that strange message any more.
Jun 03, 2011 | Compaq Presario M2000 Notebook
My HP notebook does not play DVD's.
Does it play CDs perfectly fine ?
Did you check with other good (branded) DVDs ?
If possible, remove this dvd-drive, connect it with another laptop, and check.
If problem started after you installed anything, try undoing it through System Restore (All Programs - Accessories - System Restore).
Boot the computer in safe mode (tap F1 or F11, select Safe Mode), log in as Administrator.
Check if it reads DVDs here or not.
Create a new user account (Control Panel - User Accounts). Restart computer normally, and log in using this new account. Now check if DVDs work or not.
If still not working, backup your important data (write on blank CDs, or copy in USB pen drives), and then format the hard drive. (Restart the computer, and tap F10 to initiate recovery from hard drive partition.)
You may also use the Recovery Disk you got with this notebook. (Insert disk 1 in the drive, and restart the computer, and just follow the instructions).
If still no progress, chances are the DVD-drive lens has gone for a toss. Buy a new dvd-drive.
Hope this solution helps you.
Nov 15, 2010 | Computers & Internet
Added a new hard drive to my desktop compaq presario sr1620nx and trying to install my operating system and its says no operating system found or corrupt partition and when i hit r to recover its brings me...
You can't transfer the operating system. You have to reinstall it on the new hard drive. Most of the time the disks that come with a computer are just restore disks. Without the restore partition that comes on the hard drive that came with the computer, those disks are usually useless. Or if you want, you can keep both hard drives, and just setup the jumper settings on the hard drives so that the old hard drive is the primary, and the new one is the secondary. Then you will still have the operating system and you will use the new hard drive for storage.
Apr 21, 2009 | HP Compaq Presario SR1620NX...
Have A HP 735P made recovery disks when computer was new the 1st time booted it up. Installed new hard drive. When I attempt to use the recovery disks I made from this computer I get a messege ''Recovery...
The most likely cause of this, is that the new hard drive is not the same as the orginal. Restore media is setup to install only on OEM. Orginal Equipement. If the new hard drive is larger or smaller then the orginal it will not properly load.
The easiest solution to this is if the new hard drive is larger, use a disk setup utility and create a partition the same size as the old drive.
If your drive was retail the software to do this will have been in the box. If you purchased an oem drive you can download the drive setup tools from the manufacturers site.
The drive setup utility is easy to use. Boot to it and choose setup drive. When selected it then procedes to the screen where you will need to set the size of the partition. 1024MB is 1 GB. This will help you detemine the size of the partition you need to set.
Good luck
Apr 02, 2009 | HP Pavilion 735n PC Desktop
Hard Drive Error during system recovery
You need to run a hard drive diagnostic disk in dos,(before windows starts) First check with HP, You can also use a program called HDD Regenerator 1.51. This will check the drive for bad sectors, and then you can try and repair them. This way you might
be able to see some of the data you want. If the sectors that where
repaired had the operating system on them, you should just get a new drive,(if not under warranty) then after you have a new OS installed on the new drive, you can plug in the old drive and see what you can recover.
Feb 25, 2009 | HP Pavilion a1610n PC Desktop
HP PAVILION M8200N  PC Desktop Logo
95 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
