Question about Poulan Garden
42" deck belt shredding
42" deck belt keeps getting shredded after just a few passes. The belt also gets hot.
  • 2,100 Answers
One of your pulleys is frozen and the belt is just going around it without it turning. Pull the belt out, remember where it goes, and find the pulley that is frozen. Get it replaced. Hope this helps.
Posted on May 04, 2010
Primary belt rubs on bracket n keeps shredding/// new replace ment deck...just purchesed
Look under the the left foot rest,there is a belt installation diagram. It will show how to install the belt correctly. It is real simple to replace belt,but the belt must be installed on the pulleys,correctly or it will fail,every time. Sincerely,Brad Locke
Jul 27, 2015 | Craftsman Garden
My 22 hp craftsman riding lawn mower gets really hot after10 to 20 minutes and backfires and loses power
You may have a mouse problem. Check the shroud (motor cover) to see if there is shredded paper or other material under shroud. If the mouse shreddings get in the fins on flywheel it will cause the engine to overheat. Remove shroud and clean underneath.
Sep 03, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Shredding new belt on john deere x300 mulcking deck
Is the belt tight enough? Is it aligned to all the pulleys? Make sure these are ok and I am sure you will find the problem.
May 18, 2012 | Garden
My deck mower(craftsman 917.271530)keeps shredding deck belts
You either have a bad bearing on one of the pulleys or one is loose and moving up and down drawing the belt when it is engaged. I would pull the mower deck off and go through it .
Apr 17, 2012 | Sears Garden
Deck belt shredding after putting a new one on. what did we do wrong?
Check by hand for proper installation, verifying that any belt retainers and covers are good. I had a belt drop low and rub on me, did a heck of a job on a new belt.
Jul 30, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
How do you adjust the pulleys on a 42" 20 HP craftsman tractor mower. The belt burned off and when I replaced it with a new one the new one began to shred
There is no adjustment on these pulleys. Sounds like the belt was over the blade pulley brake arms or idler pulley guide. They will shred a belt in nothing flat.
Sep 17, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
Craftsman 19.5hp 42 drive belt shredded
most likely the belt was put on the wrong side of the belt retainer clips on one of the two pullys. I've done the same thing more than once. Make sure on next belt there are no sharp edges touching anywhere and while engaged or not.
Oct 22, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Shredding belts
first make sure the belt is not hitting anything when the blade is engaged (engine off), the if ok remove belt and look in pulley grooves for rocks or chips., then run finger all around groove to make sure there is no catches or spurs. If that is all ok then with belt on and engine idleing as slow as possible and blade engaged look and see if pulley is wobbling, BE CAREFULL !! look at the engine pulley first then with EXTREME CAUTION look under deck from opposte side of chute. ( Check with deck at highest setting)
Jul 24, 2009 | Mtd Garden
Garden Logo
219 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
