Question about Traxxas T Maxx 3.3 Monster Truck
Transmission I have a 4 year old t-maxx 3.3 with forward and reverse. I dont remember the model number of the truck. The trans is grey in color. I had the trans rebuilt last fall ran it 3 times and again its broke. Would Like a new one. Can I buy one from Traxxas and if so how much. How can I find my model number for. Thank you for your response.
  • 748 Answers
Hi
You can buy the whole transmission. It's about $100.00. You can get it from Traxxas, Tower Hobbies or your local hobby shop. The truck model number will be in the form of TRA 49xx. TRA 4910 could be yours but you can get the exact part number from the on-line Traxxas parts manual for the T-Maxx. When you download this manual you'll then have the ability to replace the transmission by yourself. Good luck
Posted on May 05, 2010
I have a 2001 Isuzu rodeo 4 wd they told me to
Your going to have to go to a transmission shop
to have it diagnosed
I would guess the trans has failed internally
Expensive to rebuild it on a vehicle close to 14
years old
Oct 04, 2014 | Cars & Trucks
Would like to find year of transmision
Depends on year, and type (4 speed, 5 speed, 6 speed, 3 speed with reverse, etc)
In 1962 Harley started stamping numbers on the transmissions (back then, the 4 speeds).
It's an alphabetical letter code followed by three or four digits.
CODE A-B = 1962-1963
CODE B-C-D = 1964
CODE C-D =1965
CODE D-E-F-G = 1966-1967
CODE J-K-L = 1969
CODE K-L = 1970
From 2000 on the transmission number system was year then 6 digit sequential transmission number, ie. 02 000123 would be a 2002 trans., 123rd built.
This should only be used as a guide only. Even Harley-Davidson admit there are some discrepancies in their numbering systems.
Feb 16, 2014 | 2000 Harley Davidson FLHTCUI Electra Glide...
I have a 1998 Oldsmobile Bravada auto trans drive works fine but no reverse
Are you sure you have all 4 forward gears? Most of the time a no reverse condition also means 1st and 3rd only.No 2nd or 4th.If you dont have all the forward gears as i suspect , the reaction shell is stripped or broken.If you do have all the forward gears then these are the two most common reasons you do not have reverse.1 reverse input clutches are damaged or burnt 2 forward cltches have slipped to the point they are welded together causing a mechanical bind in reverse and also causing the transmission to pull forward in neutral.Let me know if i can help.Good Luck.
Feb 28, 2011 | 1999 Oldsmobile Bravada
I have a 1990 Geo Metro with 3cyl and auto trans. The problem i am having wit it is I have no forward or reverse gears? I know the pump is working as i checked fluid level with engine off and on. when on...
When was the last transmission fluid ATF and transmission filter change?
The recommended interval is 2 years or 24,000 miles.
Is the ATF color a lite pink color or it's DARK RED?
Any burn smell?
Do the old fashion drop the trans pan and filter change.
DO NOT GO TO shop that use a machine to flush your automatic transmission.
Most Metro automatic can go up to 140,000 miles before needing a rebuilt.
If the ATF is in lite pink and it's not burn then the most likely cause are
1)lock up torque converter is not functioning
2)transmission filter is clogged
Please rate my answer if it's useful to you.
Thanks
MUSTGO
Dec 11, 2009 | 1990 Geo Metro
Hyundai excel 1996 automatic will engage reverse and park but no forward gears. Gearbox was overhauled 3 years ago, new seals etc. Oil level in the main transmission is ok and no apparent leaks. Problem...
It appears you have a Forward Clutch FAILURE. Replace the trans after you get it diagnosed and verified by a professional technician. By the way, do you have a Check Engine light? If so, what is the diagnostic code? The dealership can scan the system and find any codes which may have been stored in the TCM (Transmission Control Module). If there were any 'Incorrect Gear Ratio" codes, it's most probably the trans itself.
May 16, 2009 | 1994 Hyundai Excel
Kirby g3 tech drive
so when u pull it back it's like it's not engaged at all? then it maybe the reverse is out....with the fwd soon to follow. remember the vac is 20yrs old; & working that long? it definately served it's purpose.
depending how much money you wanna spend on it buying a new or used trans. plus labor...or just an ebay used unit.
Mar 31, 2009 | Kirby Generation 3 Bagged Upright Vacuum
While driving truck makes a humming sound in drive now no reverse
If you have no reverse then yes it needs to be rebuilt. as far as the whining it could be in one of the differentials. or in trans? just depends on where you hear it
Dec 08, 2008 | 1995 Chevrolet Suburban
Car won't go in reverse
If the vehcile is V6,then the trans model is the A540E,and if it is the 4 cylinder engine,the trans model is an A140E.Both are 4 speed overdrive transmissions,and sorry to report that on just abot every automatic trans on the road,reverse gear failure is almost always a mechanical problem inside the transmission because there are no shift solenoids involved with reverse as with forward gears.And you did say the forward gears were fine.Good luck.
Sep 01, 2008 | 1993 Toyota Camry V6
Automatic Transmission problem
You didnt specify which transmission your car has,the 3 speed,model A131L,or the 4 speed A245E.Both transmissions basically have the same elements applied internally when acquiring Reverse gear.Forward clutch off,Direct clutch and Low Reverse clutch applied.The major difference between the two available transmissions for your car is,the 3 speed trans is totally hydraulic,no electronic controls,while the 4 speed trans is totally electronic control.Check the fluid level first,regardless of trans model.If your car has the 3 speed trans,it is likely an internal trans problem.Same thing for the 4 speed model,with the exception that the problem could be the electronic solenoids malfunctioning.The solenoids should be deemed defective or good,before a determination is made.
Jul 13, 2008 | 2001 Toyota Corolla
Traxxas T Maxx 3.3 Monster Truck Logo
228 people viewed this question
Top Traxxas Toys Experts
Michael Brisco
Level 1 Expert
cwradio73
Are you a Traxxas Toy Expert? Answer questions, earn points and help others
