Question about Dometic Rooftop RV Air Conditioner
The compressor tried to star but it quit right away; thank you
  • 8,404 Answers
Your start capacitor is probably cooked. It is replacable ... but be careful ... it MIGHT still be charged when you remove it.
Posted on May 04, 2010
Testimonial: "thank you very much, I'll try that"
  • A Miller May 06, 2010
    Thanks for the 4 thumbs up ... good luck with your repair ...
Compressor not running
id try a new capacitor (cheapest solution) , but sounds to me that your compressor is done for. id bet the evap coil is quite dirty , this is a usuall cause
Jul 21, 2015 | Haier ESA412K 12,000 BTU Energy Star...
My husbands Yamaha Royal Star will completely stall while riding. Any ideas?
Make sure you have fuel getting to the carb/injectors. If you have fuel and you say you fiddled with the ignition switch and it worked, you might need a new ignition switch. I hope this helps. Rod
Mar 11, 2015 | Yamaha Royal Star Venture Motorcycles
How long after plugging in fridge should compressor start ?
It should start up within a couple minutes. the electronic control board controls the compressor as well as all the other functions of the refrigerator. If the refrigerator is cold when you plug it in then it may not start right away but opening the doors for a few minutes should get it to start up. If it doesn't come on after a few minutes the control board may have issues.
Aug 15, 2014 | GE Profile¿ Arctica® Energy...
I have a single phase copland compressor NEW ( AG133ET-001)that i just replaced. i wired common leg from contactorsT3 to compressors T3(common winding,From contactors T1 to compressors T2(Run winding?)...
you will have to look at the schematic for this theirs different units that wire different way but that sounds correct the way you have it you can double check reverse the start and run always write this down when doing these the supply house can help you to be sure just ask them say hay the diagram has worn away what is t1,t2,and t3 double check your cap it could call for a different size all compressors that ive seen does take a start capacitor some even require start assist kits unless they are three phase what is this compressor going on email me I will help you more and even call my supply house if need be pendletonheatandair@hotmail.com
Sep 14, 2010 | Heating & Cooling
WHERE IS THE DRAIN PAN LOCATED???
The bottom of the refrigerator and near compressor is where the condensate drains to. The condensate begins in freezer during defrost and collects in a collection tray behind rear wall of freezer and with a drain hole and pipe that feeds through the cabinet and down to drain pan where it is warmed by the compressor heat and returned to the air inside your home. The only way to really get a good look at pan is to pull the refrigerator away from wall and remove cover over the compressor are. I recommend unplugging first before placing hands inside.Thanks, Sea Breeze
Dec 14, 2009 | GE Profile¿ Arctica® Energy...
Refridge quit cooling suddenly inboth freezer
That could be a broad range of possibilities. The defrost timer, adaptive defrost board,compressor start relay, compressor start capacitor or a mother board. Would you happen to have the model number so I can narrow down those possibilities? If you pull away from wall remove cover over the compressor and then unplug. Touch the compressor and let me know if cool, warm or too hot to touch. Thanks, Sea Breeze
Aug 19, 2009 | Kenmore Refrigerators
Frigidaire cf-5f-lx2 1989 modle
Greetings!
Since the overload was good when tested, check also the electric current if the current is in the right voltage.
If the problem still a raise, it is now the motor compressor that have problem. The motor it self cannot start or hard starting.
Thanks.
Nov 06, 2008 | Frigidaire 5 cu. ft. / 142 liter Chest...
Whirlpool Model AD40USL5 Has quit pulling out water. I cleaned the coils but if sounds as if the compressor starts and then cuts right back off
HI thanks for your question. so you did clean the coils ok. i think the problem your having is with the relay. check that. try and turn off, for a few hrs, the compressor is very hot . let it cool off. and try again. thanks the appliance doc. please rate my answer. thanks.
Oct 09, 2008 | Whirlpool Refrigerators
Q-Star Compressor
The compressor just seized, so I just bought a new much more efficient unit.
Jul 28, 2008 | Friedrich QStar SQ05J10B Air Conditioner
Freezer has quit working and now refrigerator not cooling like it should.
If you hear the start relay clicking after the compressor tries to start then you know that there is power to the compressor.
This tells you it is ether a bad start relay or a bad compressor.
At this point I use a meter to see if the compressor is shorted to ground.
If the compressor is not shorted then replace the start relay and give it a try.
You should hear the compressor start right away with a new start relay if that was the problem.
If the compressor is shorted to ground you will need to have the compressor replaced.
Given the history on whirlpool refrigerators in the 5 year old age range It may be good chance that a new start relay will fix your refrigerator.
If the start relay is bad you will hear it try to start the compressor and then click off.
If the relay is bad you will hear the clicking sound seconds after plugging it in and then again every minute or two as it keeps trying to start the compressor.
Jun 02, 2008 | Whirlpool Refrigerators
Dometic Rooftop RV Air Conditioner Logo
187 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
